dripley
Retired Staff
Everything posted by dripley
  1. My Banks came with silicone tubing. It has held up just fine.
  2. I dont know. What I do know is that your apps and boost should reading near 5v. Not the numbers your seeing and it is very odd that you have no codes. Bit of mystery. Maybe something is wrong with the scanner. Just hard to say. Somebody body correct me if I am wrong on the 5v sensor voltage but the apps is in another world and the boost is in the cellar. All the sensors are on a 5v circuit.
  3. Let us knowwhere you source the lines. I have been thinking for a while now. Just a biggerjob than I can do right now.
  4. He is also getting some other weird readings on othersensors too. I looked Autel and they offer a lot of different scanners and they aint cheap. Hope that means they are of good quality.
  5. Same here, no lube and 125 ft pd's. 500k and counting.
  6. My Banks had a 2 second or so delay. I did have to get up to 35 mph before it would engage. Maybe there is a way to get yours to do that. Or just switch it when in town.
  7. Ok smart asses. I actually went to the store looking for this and found the TP at the same time. I am having to contruct a hand washing station for the job using this in a 5% mix for my crews.
  8. Do you have a needle valve on the tap for the fuel pressure gauge? If so close it and then barely crack it open. And I mean barely. You are welcome for the help. Learned most all of what I passed on to you from the members here.
  9. Something really wacky with the apps volts. Dont know how you could have 160.8 volts on a 12v system. Hownare you checking for codes?
  10. Dont know about the cloud but now my hieny has a bright spot in its life.
  11. Welcome to forum. Always good to see new folks. Your 2001 might not be seeing info on codes using the key. Some do some dont. I would advise to have the codes read somewhere or get code reader of your own. A failing map sensor can do what your seeing. So can other things. Can of hard to tell.
  12. Here in Sharpsburg Ga. I scored two four packs of TP !!!!! And I might i could have gotten more but left some for others. There was probavly 8 more 4 packs left.
  13. Just think if you didn't have that stick you could have one of those nice fold out cup holders.
  14. Traffic is only about 60% of normal. It is very strange. I wont be surprised if we do some form lock down here. Just waiting for something to happen.
  15. I am about 3k over gross at 23k with mine on. 15k is just the trailer. It works fine but I would love to lighten up a good bit.
  16. You could go over to Blue Chip diesel and checkout his VP44 trouble shooting page.very good info on the VP there. I see you have a refurbished ECM. Have you spoken to them about it? Is it still under warranty? Reread your op and see you sent the ECM back in. Who did the rebuild?
  17. I have read of some instancrs just not seen any. But it does not surprise me at all.
  18. And to think if you lived in Venezuela or some other places this is a daily occurrence for a lot a folks. If it is this way in a couple more weeks here there will be no civility at the grocery store then. Every one will be fighting over a can of vieeny weenies.
  19. Those coincidental failures are more common than you might think. My VP crapped out and the MAP sensor went with it. Many other similar instances that I have seen here thru the years. Still running the oe cam sensor in mine. Its probably next. Good to near you got it fixxed.
  20. I love to see him stopping it. Mine is 15k loaded and the pin weight is about 3k. That and with what carry in the bed puts me right 6k on the rear axle. IIRC that is about maxxed out on mine with the tow package on the dana 80.
  21. I wouldn't want to. The truck might be rated for it. There's some high ratings out there.
  22. I saw an article to that effect from the new york times yesterday and this am but it is gone now.
  23. I am in Georgia at the moment, the Atlanta area. I just heard this morning they only have 99 confirmed cases at the moment. They closed most of the schools last week. Many places of business are starting to close down voluntarily at the moment but the state is considering a major shut down in the near future. I know I have made a bit fun about it but it is a serious situation. I have not seen people getting violent with one another over groceries or the like and the two trips I made to the store everyone was shopping the isles that were not cleaned out. It will get worse before it gets better, thats for sure. Even CFA closed all ther dining rooms and sure more will follow. My sister lives in Forida and they are in the process shutting down there. She works for Verizon and they sent everyone home early last week and thats 1000's of folks. Not to mention all the theme parks have closed there. It does make me wonder how would folks react if the groceries stop coming. I still dont get the TP disappearing first though. I have seen runs on food stuffs but not the TP. Cant even find napkins here anymore.
  24. Pictured might be blurred a little. Its only 500k. I am still good with that. If I do retire next year, 600k will take a while. But you never know. My temporary remote starter wire. Got bad wire somewhere. It will start a once or twice then not again for a while. I need more than a fast weekend to dig into it. Thought the swithch was was bad and swapped. No joy.
  25. Get your pump squared away before adding anything. The reason the fuel pressure is so important is that fuel provides all the lubrication and cooling for the VP.
