jlbayes
Everything posted by jlbayes
  1. Any of the minis from retrofit source. Others I cannot comment on. I would use only a clear lenses but that is just me.
  2. I was referring to mine this time. haha
  3. Do you have access to a drb III or equivalent tool?
  4. You really only need a different bulb and a projector. And time to install the projector. I aligned mine Saturday. Will have to drop the cut off once I get them actually mounted. I screwed up when ordering shrouds. Waiting for the new ones and I will glue the lenses back on.
  5. Hid retrofits with morimoto projectors.
  6. No actually, it will likely self migrate if the pcm you get is not originally setup for security. I would find someone with a use manual pcm from an 01 or 02. Plug it in and see if the truck will start. ECM reports to the pcm on a 2nd gen. PCM & cluster are the dominate nodes. The ecm is basically a standalone module.
  7. You have to start it for it to leak oil.
  8. Be happy I do not have one.
  9. I wasn't going to post these yet buttt......
  10. Here is your build sheet. Oddly enough it does have security. Will the emissions check, check for a vin mismatch? The ecm can be reflashed if it requires one.
  11. You want this plate gasket. Steel core 8037 https://www.flatoutgroup.com/SearchResults.aspx?k=8037
  12. Will not work. Again the heated seats are not controlled by the pcm. I am telling you what the tool will do. This is what I do for work. As soon as the tool sees the vin it will automatically select the file for YOUR truck and upload an auto file. There is no pats (different manufactures security system). There is a panic alarm (not anti theft) and then there is a security alarm. The ecm will not care what vin is in the pcm and vice versa. Only an emissions tester will. If you send me the last 8 of the vin I can tell you exactly what options your vin was built with.
  13. Purely to reduce cylinder pressure. Warranty reasons. Hard on head gaskets.
  14. Vin will select auto trans. By default if you use yours. Seats are not controlled by the pcm. Security would be the issue. If yours does or does not have it. You realistically need a vin with all the options in the pcm as yours has with the exception of a manual trans.
  15. Interesting. Wonder who is making them now. Good to know! Now the used market will drop again.
  16. Those are no longer available. Cummins quit casting them. Well I should say no new covers are available. If they have any they are used.
  17. I have never replaced as many batteries as I have Interstates. The old car quests were almost as bad. Everything from passenger cars, to otr trucks and equipment. I wish you all luck with them, really do.
  18. The pcm issue may or may not be simple depending on the options your truck has. It will need another pcm as they are locked when flashed with no way to wipe them easily. Dealer cannot.
  19. That is easy. Build date was probably early. I have an 01 that was built in Jan. of 2000.
  20. A buddy had his polished, whole thing and it really never shined. I love the way that looks over his.
