Everything posted by Sycostang67
Preparing for road trip.
I'm trying to prep her truck so she wont have to get anything done while she has it. She'll be living alone in the woods and my brother in law can sometimes be slow to get to fixing things. The GMC has 152k miles on it and I replaced the original water pump and hoses. I actually replaced the water pump twice, the first one only survived going around the block a couple times before the bearing let go, wobbled around and tossed the belt. I did a warranty return and upgraded to the HD version of the pump just in case. I had to do a warranty exchange on the radiator cap two times as they both leaked from the vent shaft. I went with a standard cap the third time. I put a battery tender under the hood with a plug in the lower air dam. She only drives 2-3 times a month and the car she is borrowing keeps having the battery go dead from the cold and lack of use. I got some newer used tire for it as brand new tires would rot before she ever used them up. I still need to get a new spare for it though, current one has cracks in the sidewall. I also need to check the age of the little trailer tires and it's spare as well. I did install a new Tekonsha P3 brake controller in my truck. The one that was in there came with the truck and could only be used on the lowest power setting. If you turned the power up one notch it would lock the trailer tires up when you the touched the brakes. I was gonna get the P2 but I installed a P3 in my father in laws work truck and really liked it. He was having the same problem with his old controller but I noticed it had been mounted upside down so the pendulum was probably sitting in the position to make it think it had to brake hard.
Coming in late June my brother and I will be driving from my home in Kuna ID to Lincoln Nebraska to get my mothers things to her. I will be using the Ram and pulling a 25' coleman camper. I will be followed by her 1994 GMC K1500 pulling a pickup bed trailer. I will be meeting my sister and her husband in there truck where they will take the camper and GMC to Watertown NY where my mother lives. The GMC is just about done, been prepping it so my mother shouldn't have to do anything but change the oil as long as she owns it. I've changed every fluid, filter, fixed all the leaks, replaced the cooling system, shocks, fuel pump and converted all the lights to LED. My truck is almost done, most of the fluids are fairly new in the last year. I will be getting the brakes flushed, upgrade trailer brake controller, new belt/tensioner and an oil change. Bringing extra tools, fluids, belts and fuel for the GMC, lol. What do you guys usually do to prepare for a big road trip?
My almost new steering gear
I'm so paranoid when ordering things online, I usually go back and forth checking all the info 7-8 times before I have to grapes to hit the "Place Order" button. So far I have only messed up once when ordering headlights for my mother in laws jeep, I assumed she had HID's and ended up returning them on my dime. I'm now having similar issues with a friend as we try to convert a 1982 Trans am from auto to manual using a 350 from a 1980 vette and a 5spd from a 1989 Trans am GTA. Getting the right combo of clutch and flywheel is proving tricky.
Should I get a cold air intake for my 5.9 Cummins?
O'reilly isn't much better, about $102 for the wix there, only $59 on Amazon.
Save your money, I run a BHAF as well. I tried a new AFE cold air kit with a dry synthetic filter for 6 months. When I removed it to change my oil filter it was full of dust on the turbo side and the filter still looked new. I promptly put the BHAF back on. I know the wix number for the filter is 42790, you should be able to cross reference that if you wanted a different brand.
Red Head Steering Box
I got my Red head installed over the weekend along with the upgraded 3rd gen style steering linkage. What a difference, my truck has never handled this good. No pulling and no play and my friend took the sacrificial steering fluid bath.
High idle
When the dealer did mine I had to go back because it wasn't working. Apparently the first time I went in they did everything except turn it on. I didn't have the switch when I went in the first time, when I went back I did so I was able to verify it worked before I left.
First road trip in my 2nd Gen
A remote start has other uses, like scaring coworkers who are smoking behind your truck. I think I'm the only spoiled one in here.
I assume it's the standard ratio box, what ever the computer at work called for. I didn't even know there were two ratios until I went looking for the redhead which arrived today.
Aftermarket keyless entry/alarm
I have compustar keyless/remote start on my truck and my 06 mustang with a stick, no alarms though. They both cost me about $400 installed. The unit in the truck has worked perfectly for the last three years. The one in the car works, but for some reason when I use it my tail lights don't work. If I shut the car off and start it normally they work again so it hasn't bothered me too much. It may also be related to my aftermarket tail lights, that car doesn't seem to care for LED's anyhow.
No kidding, I'm on my 3rd reman box in the 80k miles I've had my truck. The first one leaked, the second one was waaaaaay out of adjustment and the 3rd and current one causes the truck to pull to the right. I'm hoping this will be the last box I have to swap for quite some time.
I just put in a order for a red head an hour ago. I don't want to fight the crappy reman box I have on the 2400 mile trip I take this year. I will return my current box back to the store for a refund and I scored another core for $50 on facebook marketplace. When all is said and done, I should only be out about $230.
Anybody need a fuse box?
At my work we have a brand new mopar under hood fuse box for a 3rd gen cummins. We ordered it for a customer who ended up not needing it and we are unable to return it. It's the big L shaped box with a knob in the middle. My boss would rather not write it off and let me pirate fuses and relays from it. He's not terribly picky about the price but would rather get something for it as opposed to nothing. I told him I would ask here if anyone was interested. If anyone is interested and would like more info I can get some pics of it on tuesday.
What do you mean?
Next year I have to haul a 25' camper half way to NY, about 1200 miles. I'll be curious to see how I do then vs the empty return trip back. I'll be followed by a 1994 GMC with a 350 pulling a truck bed trailer. I'm sure I'll be stopping for gas a lot more than diesel.
What do you mean?
Twice now I have made the trip from Kuna to the Oregon coast(Depoe Bay) which is just over 500 miles on one tank of fuel. Both times pulling my pop up camper. I was usually just under 1/4 tank when I got there. The first time, the truck was stock except for the stacks, the second time was with my current setup.
headlight upgrade
I'll check my wiring, I remember having to fiddle with wire positions when I first tried HID bulbs too.
LED light strip
Like this? I used to have a strip on the back of the tool box but I crushed it as well hauling stuff.
headlight upgrade
Ok, I got them clocked at 3 and 9 and I notched the rings. The low beams are soooo much better now, it looks like your pics. I still have no high beams at all though. I'm not terribly concerned about it as I got used to using my light bar for high beams as the last set of lights only got worse with high beams. Took a trip through town and nobody flashed me but I feel I need to adjust them down just a bit.
headlight upgrade
Ok, I'll try clocking them at 3/9 tomorrow, I thought about notching the rings as well, it does seem to slightly tweak the angle of the bulb.
LED light strip
I had a similar strip on my truck a couple years ago. It's a really tight fit when the tailgate is opening and closing. I hauled some gravel in my truck and a few rocks got down there and got pinched and cracked the housing allowing moisture into the light. It still worked but sometimes it would turn on when I wasn't using the truck. I would walk by the window at work and notice the strip all lit up. I would like to get another one someday. I do have the 60" amber strips under my doors that act as marker lights and sequential signals. They have an access light(white) function as well but I haven't wired it up yet.
headlight upgrade
I got my new housings and the bulbs installed...I have no high beams and they cast really irregular shaped patterns. I'm wondering if they sent me the wrong bulbs. The box had the right part number on it but being in the auto parts industry, I see misboxed stuff all the time. I haven't adjusted anything yet, fingers wouldn't work in the cold. Did you have to clock your bulbs a certain way? I just turned them until they stopped, LED portions are facing are in the 12 and 6 position.
headlight upgrade
These are going in regular housing. I was concerned about the 9004/9007 difference but in reading the description it said this "9007/HB5 are Dual Beam Bulbs which can achieve Low Beam and High Beam function in one individual bulb, NOT fit vehicles which take separate bulbs for Low Beam and High Beam". . There were a couple reviews from other 2nd gen owners saying they worked great as well. I figure for the price it's worth a shot.
headlight upgrade
I just ordered new housings and them fancy LED bulbs. We'll see if I like them or if I have a new mortal enemy.
4th Gen Mirror Question (on 2nd gen) SOLVED
I have the same mirrors and would like the lights to do both functions as well.
headlight upgrade
I may have to give those a try. I plan on going back to OEM housings soon, tired of playing with the aftermarket units that are only marginally better or much worse.
