Everything posted by wil440
98.5 QC seatbelts
Had a seat belt warning light on ever since I got the truck, now after over a year I just can't put it off anymore as I need to MOT it ( Ministry of Transport) safety check, once a year up until 40 years old then not needed. Checked it out and drivers side didn't feel right, 4 wires to the seat not 2 so I checked the ones for the belt solenoid and 12v and earth as expected, jumpered the 2 and still the same, I swapped the controller and it was still the same so took the drivers seat out and swapped it for the seat out of my 3500, still the same, finally swapped the passenger seat and now all is good, warning light goes out after the check, I suppose it could be the passenger belt on it's own but the drivers side does not feel right, the drivers out of my 3500 is power so swapped in the power seat fuse and thats all working, I probably won't leave them in the 2500 as for 1 they are leather and get way too hot in the sun and I prefer it to look as close to factory as possible, so what are my options being as I can't got to parts yards and I can't ship 2 seats to the UK, has anyone replaced the solenoid ?? Can't see any on ebay.com either
Seat belt light stays on when belt is buckled
Sorry to hyjack, I'm tryiing to sort out seatbelt light not going out on 98.5 my drivers seatbelt plug has 4 wires, orange and black, black/light green, blue/white, and green/red I've got continuity on the orange and black/light green, 7.5 to 8volts on or/bl, passenger side has the 2 wires and readings are the same, I'm now going to swap the control module, anyone know what the other two wires are on drivers side, seat has no heat and no power
04 3500 4x4
codes are Po108. Po483. Po236. Po462. Po480. Po500. Po606.
04 3500 4x4
There's a 04 3500 4x4 auto for sale over here in uk for £12995, ad says revs on it's own straight after starting and someone has confirmed engine ECU replacement, I've asked for codes but not replied as yet, if ECU does need replaced how do I do that over here, can I get a ecu from USA and give VIN ??? could I send it over there to be fixed ??? and what cost and what if anything is better on it than the 98.5 2500 4x4 or the 98 3500 4x4 gas i've already got as I see it the ride is better on my 3500 than the 2500, gas versus diesel, I'd also say (don't shoot me for this) the 3500 gas is a smoother ride overall BUT the 2500 PO was a bodger and I am slowly sorting it all out the 04 3500 is rather tidy, twin stacks, fake roll bar, lights
Fuel transfer pump relocation
Thanks for both pics, will make a start this weekend
Quick question, 98.5 24v. PO fitted a aftermarket fuel transfer pump, not sure what it is as not had a close look all i've done is fix the guys mistakes up to now, he removed the factory fuel filter and fitted a cheap *** inline filter before the pump, I've had the truck over a year but not really used it much because of this inline filter and as I work on large diesels for a living I'm not too eager to start when I get home especially as I work 12/6 and I fully get the no restriction fuel flow deal oh and I'm building a house in my spare time, I've fitted a cat fuel filter off of a 9.3 so my filter has no restrictions. The pump is bolted to the block where the factory one should be and I have a fairly long fly lead for it to move it somewhere else, question is where is best, I'm thinking under the bed right near the pickup tube so keeping the suction side as short as I can, I'll be adding a relay to take the load off of the ecu and 1/2" lines, I'm sure I have a full reel of 1/2" Moroso ally fuel line from when I did the fuel system on my roadrunner, everything already fitted is deutz plugs so easy for me working on cat equipment, I've noticed where the pump is now it vibrates a little too much for my liking especially at idle and something will break one day
W-T ground mod
just finished this on mine tonight, 150amp resettable fuse bolted to right side battery tray, nice tidy job. Next is fuel transfer pump relay, larger fuel lines from tank to pump then sort the seat belt warning light out, then I just might jump and get a quad but import duty and VAT is putting me off a bit, we'll see
24v KDP Question and Flywheel Question
Thats why I checked mine, did a water pump and noticed a weep on the flat part of the case underneath the water pump, turns out bolts around that L shaped peice of case was loose
I checked mine about 3 months ago, pin tight but 3 bolts in case were loose enough to cause concern, loctited every bolt inside the case and tabbed the pin
W-T ground mod
I have a couple of questions, just started this today 1. my charge cable is molded into a rectangular block at the alternator, do I need to pull it out of that or as I'm thinking just cut it at the junction of the larger loom at the VP and go to 150amp/200amp charge fuse then passenger battery or is it removed because a heavier cable is used ? the molded block will hold the wires quite good 2. I'm not taking the charge wire out of the loom on the drivers side I'm just going to cut it right where it enters and exits the large loom, it is too short to leave it in the large loom and use it for the timing case earth so will just make another one
Pilothouse/RAM3500 build
contemplating something similar but using my 3500 4 x4 V8 and binning all the fuel injection/ecu's, there's a very old dodge dually on ebay.uk that has no rust but it's 9k. I wouldn't double door though as no skill for that, about 10 years ago I imported a job rated, 56 I think it was, but got rid as some **** had fitted a chevy 302, probably should have kept it LOL
Ram 2500 5.7 Hemi dropped a valve seat
Someone I know over here has just bought a 03 2500 5.7 Hemi, seller sold as faulty with suspected HG, turns out it's dropped a valve seat on number 1, I guess over in USA this is no biggy, here in UK it's pants down and assume the position, Rockauto has reman heads for a reasonable amount, I've advised to replace both, cylinder looks from pictures to be scored I did say rock for pistons/rings etc but then noticed they sell a cylinder repair sleeve, anyone used this ? Has the Hemi got liners or is the block bored big and the sleeve pressed in ? if thats so he would at least need info from a good shop over there for the bore size as no one here would have a clue how to do it. Any help or advice or parts appreciated
Dodge 1500 Motors
About 10 years ago Iimported into the UK a dodge half ton think it was either 48 or 52 can't remember, It had a chevy 350 fitted, sold it straight away as couldn't keep it with that engine, shame really as a few months later I got a 02 1500 4x4 ram that I broke for parts, motor out of that went in a 72 dart without the electronic rubbish. Here in the uk anything over 40 years old is road tax and MOT exempt, MOT is yearly safety/emissions check which is a lot harder than USA check, would be nice to find a 40 year old 4x4 dodge and stick the running gear of my 2500 under it, but I'd never consider running gear fron chevy or ford
Block heater
My points...... exactly, the noise,smoke and vibration on a really cold start is the dead giveaway that ole smoky aint happy and thats on any diesel, sound of a big diesel starting just before wax is not nice to listen to, and surely if there is no power then it's cold start, if at home and truck is not used for days and stood outside then why not, over here it might get plugged in 3 or 4 times a year as we don't usually get really cold
Block heater
Valid point
Block heater
I just like the idea of being able to hot start if I want and as the block has it fitted I may as well have the kit to plug it in, plus all engines are better hot start as most wear is caused cold especially diesels, 32 litre cat is the biggest I work on so know a bit about wear, Cat 769's with the 3408 rumble the precombustion chambers to bits when they are coughing and spluttering on cold starts, not quite the same technology as a 5.9 granted be also nice to use a oil accumulator to get oil pressure before a start especially in cold weather, there used to be a kit IIRC for performance 440's and the like but I've forgotten who made it or sold it, might have been Mopar Perf or maybe Ray Barton
Block heater
Thank you sir block heater here we go
Block heater
98.5 24v. truck has a block heater but it is 110volt 3 pin. I have a transformer from 240v to 110volt so no problem on that side but on the American plug what is what ? I'd guess big pin is earth and other 2 are live and neutral ? Does it matter which is which as it does here (England)
List of OBDII Scan Tool Live Data Available?
Yes. Not too much information with my snap on modis on 18.4 on my 98.5. 98 3500 v8 is ok too. 65 plate ford transit work van on the other hand is fine. Newer the better. Got a 04 hemi 1500 with a misfire to check, that will be fine
2500 payload
Here's my 3500 V8 with 2000kg/4400lb of biomass pellet for my boiler, little top heavy but no problem, not loaded my 2500 too much yet but 2 pallets of those pellets wouldn't fit in the bed anyway. I used my 3500 as a dumptruck when I cleared the site for my house build, 500 ton moved over 6 months in my spare time
Vac Actuator for the HVAC dashboard vents
but without the import duty and VAT
Hi AlpineRam..... Same here in England...... no dealers and certianly no wrecking yards with anything dodge or american for that matter, I tend to use rockauto or ebay usa
advice on rv or 5th wheel
I still haven't decided either way, which is 3 way really, full RV, 5th wheel or bumper, decided to finish our house I've been building since 2009 as I wouldn't have the time to use anything anyway, I've just spent all xmas holiday except xmas day working on house, still watching ebay etc for the rv bargains after xmas though. My brother jumped and has bought a 32 foot RV petrol with no gas conversion (LPG) 6.8 I think, here in the UK thats a static caravan due to cost of fuel
47re died this morning
Agreed but we can all help each other, Chris O asisted me, Marcus is doing the same, it also goes the other way across the pond, but given we are into american "dodge" trucks right now it looks to me like you guys can help us more than we can help you
well we did and it hurts
