hdpwipmonkey
Everything posted by hdpwipmonkey
  1. Or just buy an Adrenaline and check it with that
  2. I would have to agree. Nvidia is more stable as far as drivers go and if you are using the computer for gaming Nvidia has better ray tracing then AMD also. If the rumors are true and you can get a 4060 for $329 then it would be worth the wait to get a 4000 series card. Current speculation for release is Sept this year.
  3. Most GPUs are back in stock now and not at scalper prices. The next gen GPUs should be coming out in the next few months or so also.
  4. do you put the moth balls in there as a warning to the other moths?
  5. Thats a good hack. I will have to remember that when it comes time to do mine.
  6. Thanks. I am really into computer gaming so I like to have the best. I get discounts on CPUs or else I wouldn't of bought the 12900K. I would of gone your route and got an i5 or i7 and just OC'd it. I wanted a good video card for my games so I can run them all on maxed settings so I put most of the money for this build into that. I got it from EVGA, also at a discount (b-stock).
  7. Go here and input your VIN and it will spit out a build sheet. It should be listed in the build sheet. https://fcacommunity.force.com/RAM/s/equipment-listing
  8. Very nice! You have that i5 OC'd to the speeds of the i9 at half the price of one. I really like the new 12th Gen Alderlake chips (but I may be a little biased ) I just built a new system too. i9 12900K EVGA 3600 CLC AIO cooler 32 GB OLOy 3600 Ram DDR4 (not the best quality but I wanted white) Asus Prime Z690-P WiFi D4 Samsung 980-Pro M.2 1TB all in a Corsair 7000D Full-Tower case
  9. Looks like just a bolt on system. Dont look too bad of a system if you need them. https://calvertracing.com/product/caltracs-hd-5450-80/
  10. I dont get any vibration or bouncing when I spin the tires, but I'm also not trying to turn 35's.
  11. Fellow Intel worker here... although I am in the PNW, I would probably dry up like a raisin in AZ. I havent had the pleasure of meeting Mike in person yet but I see all that he does here on the forum to help folks and that speaks volumes to the kind of person he is. Welcome to the world of Diesel ownership and safe travels on your drive south.
  12. Merry Christmas everyone!
  13. did you happen to clean all the grounds? a bad ground on these trucks will give all sorts of gremlins.
  14. You are correct. Thats what I do. I have Boost, Fuel pressure, and EGT A-pillar gauges so I dont use the phone all the time. @Stanley You dont need to use any of gauges for tuning. The only thing you will need the gauges for is if you want to use the defuel setting for EGT or sensor warnings. Also if you want to use the cooldown setting in the quad you'll need the EGT probe connected (if you want to use temp vs time for cooldown trigger).
  15. It comes with an EGT probe and trans/oil temp sensor. As far as a display, you just use your phone or a tablet. You can download the software to your phone or tablet now and check it out. You dont need the Quad to check out the software. You could even add a custom tune to it and have it ready to upload to the module once you get one. This is what I did.
  16. changing them to Steelers floor mats?
  17. I dont know all of your info like if you have a family, do you have any health issues that you need to rely on the benefits, but I would say if you have nothing keeping you tied to your current job then go for it. Life's too short to be unhappy. Get after it. I also worked at Monkey Wars (Montgomery Wards) in my younger days. I was working there when I graduated from ITT (Pittsburgh) and got hired at my current job, that was 21 years ago...
  18. Congrats on the new job Mike. It sounds awesome.
  19. Glad everything turned out, for the most part, OK. It probably could of turned out worse... Don't worry about the foot, just remember, chicks dig scars!
  20. I get a slight haze when started and first put into gear (I run with grids disconnected). Once warm no haze. I also get no smoke unless I get on it with the quad turned up and then only a puff of black then away I go... When I first installed the 7x010 injectors I was worried that if I lost my quad that the truck would smoke like a train but driving around normally there is little to no smoke with the quad on 0. I have no lope and no issues with these injectors. When I bought mine I did new bodies and new cross-over tubes. I wanted to ensure I had zero issues after installing and so far so good.
  21. that is a horrible picture...
