JAG1
Staff
Everything posted by JAG1
  1. Michael Nelson could narrow this down for you. You could also call Source Automotive since they have exhaustive experience. No pun intended. Talk to Rip @503 654 9009. They will know what to look for.
  2. Could the turbo charger oil to the bearings be leaking into the exhaust? How many mile on it?
  3. I only know a couple things about them, that a friend of mine bought one twice for his wife. In a head one collision the VW guy survived but the Honda mini van was gone from the rear seat forward. Like the whole front engine and front seat just disappeared.
  4. I like that you mentioned this. I was in a 20 degree cold spell when I would start up and get dead pedal. Happened twice in those cold mornings till I got saved by the Timbo APPS. I also read about strange error codes occurring with the lift pump powered off the ECM. The lift pump was going out and put a lot of power demand on the ECM causing random error codes. Guy got lucky when he thought about the lift pump playing havoc on the diagnostics of the truck.
  5. I wish they could stop the mud slingin' and stay pertinent to the issues facing America, We need total reform. Seems like all they are interested in is to keep the country divided. .
  6. Her overflow valve would be steamin' if you did Katoom I found out you can also use ceramic glass. Like that for a woodstove. The nice thing about it is that it can be easily cut to size even after it has been ceramisized. New word I guess
  7. that's not a mouse, that's a Katooms overflow valve that fell off for yelling at me the other day.
  8. We have that on our new to us 2010 Subaru Outback too. Can be up to a year and a half as some of my clients have told me. Wish we can have a recall on the air bags in Washington. I think you and I get more work done in a day that Washington accomplishes in a year.
  9. You know your pretty lucky if the guy working on your truck has all the experience. Luckier still if he if has no signs of the grey haired forgetfulness. But when that young guy who worked on your truck just a few years ago is growing 'wisdom hair" I know I'm getting old.
  10. Thanks all will try that. Yes surprisingly she does know quite a lot about using the oven. She can make things so awesome as long as company is coming or its a holiday . Other days, is like.... hum lets see what I can find for myself.. It's cool cause she works most days.
  11. Yeah I have to go meet him again at another place real soon cause its beautiful there. Like this
  12. My wifes oven door inner glass broke so now I have it apart and ready to order a new piece of 1/8th inch glass. Does anyone know if it's better to order the glass tempered? The old piece was not tempered, but, is there any special glass or something for ovens? T.I.A.
  13. Just want to add that I bought my 02 with manufacture date of October of 2002 some of the last of the second gens and the Ball Joints and tie rods only lasted for 64,000 miles. My first gen, I know has different design but didn't need anything up front till after 300 K. I think you are right Dave about quality changing.
  14. Nice pics thanks IBM. I'll be going there someday too.
  15. Katoom, what do I know anyway . My overflow always works when drinking beer I think Gus needs to revamp his entire fuel system. Without a F/P gauge I wonder if he's still running banjo bolts, no 3/8ths or 1/2'' inch lines, clogged screens in the tank. no prefilter before the lift pump, could be a lot of things that need revamping before the possibility of ruining another VP if that's what is found to be wrong. All I know is Dodge engineers screwed the fuel system in these trucks. And their solution at the dealers is to place an inside the tank fuel pump that makes it worse.
  16. When I first bought my truck I wouldn't even drive it till I got a fuel pressure gauge. Just too much risk/ expense to go without. When you first bump the starter, truck not running, the lift pump should be running for about 25 seconds after bumped. This is an advantage cause when not running it quiet enough to hear if lift pump is working. Air in lines and also not fully priming can cause a short rough engine run and then die, but, you say it runs for a full minute? Stay away from the dealers but a couple things possible: Air leaking into lines Bad overflow valve on the vp44 Tank vent causing vacuum in the tank from clogged anti roll over valve on tank top. Just remove the cap while running. Or remove fuel cap slowly after running to see if you hear tank vacuum. This problem is rare but happens. Old intank lift pump left inside the tank. Quick connect fuel lines leaking air. You got to get this truck home and talk with Eric at Vulcan performance. He's sharp and his prices are spot on good.
  17. Are you cracking a couple injectors loose to reprime?
  18. I haul a 3000 lb slide in camper. My fluid was nice and red, the way your supposed keep it but on a hot summer day I took a road so steep I had no idea they still paved 'em like that. Went for about 12 miles. I saw my temps shoot up quickly to over 180. That must be close to burning the fluid cause when I got back it was brown in the pan when serviced, yet it but looked more red on the dipstick. I was surprised fluid had burned just from those temps. I was at a 25,000 mark for miles and service.
  19. Yes and those spare tire winches go bad too. One guy saw his spare passing him on the shoulder from a rusted tire winch. That is why mine is chained up with a chain binder.
  20. I have the Mag Hytech deep dish pan on mine. Holds extra 4 qts. I believe. It is aluminum with cooling fins which helps telegraph the heat away a little.
  21. Pretty dog gone rare to get them back. That's too cool. I am glad you got it as I had a MG midget I had worked on for a long time when young. Motor was pumped . But a guy totaled it, was his fault and I never got it back. I still dream about it in my sleep. Miss that car terribly and still, after 40 yrs it exists only in my dreams. Check for error codes before you finalize the insurance adjustment Tyler.
  22. What happened IBM , did you have an extra piston layin' over by the coffee pot when it was all done
  23. As soon as mine started doing that, only two short instances did that happen, I changed over to the Timbo APPs. No problem ever since.
  24. I think they are going to look good on there too. I wouldn't know what to do either. Especially if some surfaces have a matt finish not high polish. Be careful some wheels have a clear coating on them. I wouldn't want to burn thru that type finish in some spots and other places still have the coating. Maybe call a wheel manufacturer??
