CUMMINSDIESELPWR
  1. fuel boss, stock turbo, rv275... never below 19-20psi
  2. nice quad cab long bed!
  3. being in ham radio this is all fact, the "ripples" are called harmonics and any open electrical spar/arc can, does, and will create unwanted RF and the harmonics can go up and down the radio spectrum for ages.... that unwanted rf can be inducted into other resonant circuits and cause problems. its why i have a mechanical lift pump
  4. before i did my mod, i was rock crawling in colorado and unknowingly dumped a gallon out the front vent because i was going downhill so steep, the oil light came on. after the complete mod, ive had zero issues since, even in -17deg weather
  5. nice to hear, sometimes defects happen but the owner of fuel boss is great to work with and very helpful.
  6. i overpack, push the caps on till they seat and make sure seals dont pop out before install.
  7. i upgraded to a 3rd gen inverted t steering and a box brace. the box is worn but all the other stuff tightened things up well. just bad design with some weak components plus who the hell puts a weak a$$ balljoint on the frame side of the tracbar on a pickup truck... that is the biggest issue, a 3rg gen adjustable trackbar with 3rd gen frame adapter is needed to fix that issue....
  8. plenty o simple green and pressure washer
  9. i get sealed as well, stronger and before i install i over pack them to make sure plenty o grease. havent had a problem doing this
  10. yeah it seems the spring isnt putting enough pressure against the ball bearing to seal and build pressure. take it apart and see how easy it is to push it open, 20psi is a lot and if that spring is weak or defective it will not hold pressure. also blow into it and if air gets past then its defective. it happens sometimes
  11. that return check valve has debris in it keeping pressure from building. this happened to me when i installed mine and tested. took it apart and found some of my teflon tape in there.
  12. the amp sits under the dash and you can hear the relay click on when you turn the stereo on. what are on the speakers are low pass and high pass filters. just the the adapter from walmart $8 and you are good
  13. if you have the proper overload blocks there, they may have put the angle iron to keep from squatting so much when overloaded. those overload springs arent meant to be a constant use item, rather an emergency spring for a shock to the rear axle while carrying near or max loads to prevent axle from bottoming on frame and breaking and reversing the spring pack on themselves from overcompression. removing that iron is fine and shouldnt be there to begin with
  14. looks like they added an overload spring to the pack that wasnt there from factory and the bolt that holds that angle iron is where the overload perch block usually is. take it out and put the proper overload perch block on.
  15. i need to send mine to get rebuilt, it has no power to turn 35" tires standing still. once moving it turns ok, its just weak and is worn.
  16. took me and a friend and a tranny jack 3 hours to get it perfectly aligned to slide in with minimal force.... holy crap that thing with tcase married is heavy as hell. but we got it done right.
  17. those panhandlers make more a month than i do on my va disability.... and i WANT to work but physically cant anymore....
  18. yup agreed. and its not surprising that a shop went out of business, im sure it was for extremely poor workmanship
  19. phuck a lawsuit, id be after someone with a bat and some extremely hot hotsauce... and like mike said this is why i do all my own work as well.
  20. apple dont take sd cards sadly... is the tradeoff hey dont forget the antenna
  21. i have a 128gb iphone that has about 50gb music on it i also can stream when i want.
  22. yeah canned ham was my idea hahaha and its my hand holding the side latch the radio itself draws .5 amp while not transmitting and 9a transmitting @50w. i have 18ah total of battery and communication would be short and to the point. so when there is no sun it will be minimal operations unless other things are needed on. so the calculations for night ops are .5A for 12 hours, it requires a 14ah battery. im 5ah over that. eventually i plan to make some kind of generator that doesnt require fuel. now to float the system all i need is 18watts and it floats @12.8vdc under full load with everything hooked up to the batteries. so power requirements are very low to operate at maximum power and load. the radio has a fan on the backside of the heatsink. the case will always be open under a cover of some kind and not operated closed up.
  23. final product "canned ham" (No subject) r r Mon 2/18/2019 7:27 PM for your viewing pleasure, i present “canned ham” homebrew field ops base station eqpt list: yaesu ft7900r dual band ham radio 18w solar charger two 9ah 12v agm sealed batteries (in parallel 12v 18ah) 60w inverter for the acer acer aspire switch 10 fully functional pc with loads of ham software w ac adapter wired mouse rtlsdr v3 dongle attached to acer for sdr operations and receiving of digital modes voltmeter/switch/cig lighter socket on pwr panel 15 amp fused mains 20amp solar charge unit multitool (in solar panel pouch) a dual band ht antenna for QRP quick operations baofeng uv5r with mono cable for sstv transmission (hooked to iphone) and its own antenna iphone 5 for sstv creation/ other digital modes usb light external speaker ft7900r operation manual (pdf manual on phone also) 50’ audio cord to put uv5r up higher for better reception a couple usb charging cords for devices All this nicely placed in the can with some room to spare! i have a comet dual band antenna with 50’ of coax that will be in a separate bag and mounted on a tripod appx 30’ in the air and guyed. eventually i will have a yaesu ft857D for hf/50/144/430mhz bands and a larger solar charger for the 100w capable radio
