Everything posted by Doubletrouble
Reve X Distance plus
I will have a similar set up. Frame mounted pump with pre pump screen filter, keeping the oem filter for the heat benefit in the winter months. I just won't have the airdog system you have. At least not for now. Maybe next time. I don't remember what the filtration number was on the replacement filter in the oem housing. It was a wix, that's all I remember.
Winter weather - What do you see where your at?
That's not good. You still have a ways to go up where your at.
Dirt to snow or snow to dirt.
It does look like fun! I think I prefer a 4 wheeler though. We don't get enough snow here anymore to justify a "snow machine". A quad I could use in nearly any situation. Cool sled/bike!
Time to go out and cut/split a bit more wood to prepare. Should have had this all done but got busy and it got pushed back.
Wow, that's alot of time invested but it did yield good information. Worth it.......
I typically use the same 2 fuel stops. So far no issues. I add the 2 cycle oil to help lube the vp. Other than that, I don't know a thing about where the fuel comes from. There is a refinery right in toledo so I assume it all comes from there. Don't know for sure the cetane numbers. The clerks at the stations would just have a blank look if asked. Lol
Another hard start/loss of prime
I had to replace my drain valve last year, it was dripping fuel slowly. I to ordered from rock auto, got the right part. Easy enough fix.
Here ya go @Mopar1973Man, no more shoulder walking under a truck. Just glide under and back out again, even side to side if needed.
We're expecting some measurable snow fall here Wednesday through Friday but they aren't saying just how much yet. Might be a good time to be sick and stay home from work.
Squirrels Got Me Good
Soooo, what time will the ribs be ready? Sounds like your close. Maybe 1 wire somewhere just didnt get a good contact on the new plug setup? i have no idea what "sci recieve" would be. Sorry
Dreaded P0216 code, help/advice
That was a very risky test @Tractorman, I appreciate all this info, very interesting. I went ahead and ordered the Raptor 150 as you saw earlier in the thread. I based this on increased potential volume and someone else had stated that a Raptor 100 they had showed signs of pressure drop over a period if time. I will be doing some light mods in the future so planning ahead a little as well but the information you provided does provoke some interesting thoughts. Now in my case, I discovered after the fact that the lift pump failed. It did make it a couple miles to work afterwards so the vp was drawing fuel to some extent. It did not want to run well at all save for maybe at idle. Seemed like once the fuel pedal was pressed it didn't take long for it to starve for fuel, or so it seemed. My hope is that the vp isn't completely toast yet but with your description above comparing that to my situation it sounds like it already fried. Which very well could be the case but, the vp on my truck does appear to possibly be a reman. Judging strictly on the external appearance. The aluminum has a newer, refreshed look to it if that makes sense. That alone is what gives me a slight bit of hope that it may last a little while in order to save the money to get a new reman from a good company. I'm sure there will be other weighing in on your comments above. This conversation could get interesting. There was also another member here that had rigged a bypass for a lift pump as an emergency fix I belive. Just don't remember who it was. We shall see where this goes. Thanks for all the info tractorman. 👍
Correct. I will be doing the relay mod when I install the new pump. I am certain the 150 Raptor pulls more amps than the oem Carter did so to protect the ecm I will be doing @IBMobile'IBMobile's fuel pump relay setup. I will also order the relocation kit with the 1/2" line and a draw straw to be installed as soon as it warms up a bit. I talked to someone at @dieselautopower to see if that pump would be ok drawing through the oem fuel lines for a short time while waiting for warmer weather. They said it should be fine. This is to get the truck back on the road for now and also to see if the vp will be ok for a bit. I'm sure there was wear or damage to the timing piston during the LP failure. Just would like it to last me about 3-6 months so I can replace it. Also a fuel pressure gauge is in the works as well.
This mornings temp. -3F ugh.
No it does not. I don't believe any factory replacement lift pumps have a fuel return line. Maybe the big air dog or fass systems do. I wasn't looking to spend $700 this time around though.
Finally on my way to getting this fixed. I called DAP today and ordered my lift pump. I bought the Raptor 150 that comes with the 1/2" fuel line from the oem filter to the vp. Yhe guy I talked to said it would be fine on the oem fuel lines from the tank for now. Once the weather warms up some I will relocate the pump to the frame and drop the tank for a draw straw and full 1/2" line kit with a pre filter. A fuel pressure gauge will be on that list as well so I can keep an eye on it. Just wanted to update what was going on.
FNG
And there are no "dumb" questions here. Ask away, I have learned alot in the past couple years hanging out here reading and asking questions. Great bunch of people here. WELCOME!
Dodge Grand Caravan 3.3L - Oil Pressure issue
The Mopar1973Van? Beauty? (Then you'd have beauty & the beast) Glad to hear it was an easy fix! That would be me
Anyone with an RV near N.W. Ohio?
I have an all original 1977 I'll be selling in the spring if your interested. Lol Great bike, just like the harley more and the Honda sits.
That would be awesome
I to am ready for spring. It hasn't been a terribly rough or cold winter but I would really like some seat time on the harley. Things are backing up, my truck is down for now, to cold to want to work on it. I have other things outside that need attention as well. Just don't want to mess with them in the cold either. Also looking forward to camping season, won't be making it to Cali with you all but I am looking forward to some decompression.
To continually filter you would have to go from tank-filter-pressure regulator w/return-vp44. Which would be more work than just installing an airdog that (if I understand it correctly) already does the same thing.
I would think yes, the return type would help to continually clean or polish the fuel. As far as the cavitation, I think that would be from (forgive my layman's terms) the fuel not being able to continually move forward. A 150gph pump moves alot of fuel, that's 10 quarts or 2.5 gallons a minute. There is no way or engines use all this as we already know. The remainder is cycled through as a cooling liquid for the VP. Here's the issue. We run 1/2" line to carry this fuel, the return line is what? 5/16 coming out if the VP? There is a restriction. Which doesn't allow the fuel (150gph) to move fast enough which would create a bit of a jam at the pump impeller which in turn could be the creator of the cavitation. Based on the idea that an impeller in fluid that isn't moving at the same or similar speed as the impeller would cause turbulence and induce a cavitation effect. This is just my theory, I hope I explained it in a way that it makes sense. I have the idea in my head but can't always put them on paper. Or there is the possibility that I'm just full of crap and completely wrong.
The Fass ddrp pumps don't have a return line either. Are those also prone to cavitation? I'm trying to do this on a budget as it's been a little slow at work and so on. But I want to get the best I can for my money. I can't do a full airdog setup though. My thoughts are a replacement pump (fass ddrp, Raptor, or the like) with a pre pump filter (screen/mesh type but spin on) and 1/2" fuel line with draw straw.
@LorenS, that's exactly what I was thinking. I had talked to you before about it. I just couldn't remember who it was I had talked to. Lol I like that's it's short and doesn't hang down below the frame. Also where you mounted the pump looks pretty well protected.
What size are the inlet/outlet on those? I'm wanting to run 1/2" line so will that even work? I have a filter head from a log splitter that I scraped. Could I get a spin on filter for that? Something that isn't super fine but to catch anything that might kill the pump? I could put 1/2" barb fittings on that to easily install the new fuel line onto.
