Doubletrouble
Staff
Everything posted by Doubletrouble
  1. @Joe_Pool, never thought about using 2 snobbers. Great idea! I like the needle valve though in case there is a leak somewhere. Easy enough to just close it until the leak is fixed. Gloshift sells a snubber/needle valve combo I was looking at.
  2. We were down in the single digits last night. It warmed up here wednesday, rained a bunch then turned cold and snowed on top of the ice. Made a mess of things.
  3. For a fuel pressure gauge do you need both a snubber and a needle valve to offset the hammering of the VP?
  4. I know Gloshift aren't the best gauges out there, Probably not the most accurate and a budget alternative to better brands such as autometer or isspro. I need to get some gauges on soon, especially fuel pressure. I recently had a lift pump fail and don't want to be surprised like that again. I'll add a FP gauge first and boost and EGT soon to follow. Anyone here run the Gloshift gauges? How good/bad are they? I'm sure they'll do for a while until budget allows upgrades. I don't have any big mods, mainly stock truck with plans on bigger injectors and boost elbow this spring or summer to have a bit more pulling power to tow our 36' 5th wheel.
  5. We had a warm day here Wednesday, my 2 sons took their bikes out for a ride, I was out of town for work so couldn't go. Doubt I would have anyway since there is still a lot of salt on the roads from the last snowfall. I usually don't get mine out until after it warms up and some rain to wash the salt away. I was a bit envious of their ride I must admit. I can't wait until warmer weather gets here to get the Harley out and get some wind therapy. Today it's 20 degrees with 20-30 mph winds. It's cold, or at least feels like it. I've had enough winter, I'm ready for spring. In May me and the wife along with one of my sons and his wife will be taking a trip to Florida, trailering the bikes (the ladies won't ride that far). We will be staying at the top of the keys and riding down RT 1 to visit all the keys and see what there is to see there. Looking forward to the ride and warm weather!
  6. When I first bought my truck the abs light was on due to the fact that someone had changed the axle ratio and tire size in the ecm. A buddy has a good snap on scanner and was able to change both parameters to what was actually on the truck. Abs light has been off ever since. Moral of the story, if someone has a good scan tool that is able to make changes they could possibly set the speedo right for you.
  7. I am curious, what does an average ecm rebuild cost. I am not in need of one, just asking. Thanks
  8. For the time being I used male/female crimp blade connectors on it. The insulated type. It may last a long time but I guess I'd feel better with a more permanent connection to lengthen the wire then have a blade connector for disconnect on the end somewhere up away from the bottom of the engine/starter area.
  9. Thanks for posting that pic, I've been wondering what one would look like with the plastics all black. Now I know. I like it!
  10. I was xurious because when I recently put my lift pump on a relay I had to cut the power wire to the plug for the oem setup. I'd like to have something more permanent there. It's down the driver's side of the motor above the starter. I would have soldered it and shrink over but I don't think I can get in there well enough with my big gorilla hands to do it. Lol
  11. Yes it does, I didn't think about that. I believe he has finally hung up the idea of riding. I hope at least, fir his own safety.
  12. Very nice! That would be a comfortable ride! Like the color to! Tried talking my dad into a tri-glide, he thought about it for a little while but I think his back is just to bad to handle it anymore. I see myself on one at some point. I'd like to test ride one sometime, they look very comfortable and stable, be a whole different kind of riding but riding none the less. Thanks for posting it, sweet ride.
  13. That looks like a lot of fun. I used to have a couple honda 3 wheelers way back when I was young. They were a blast! I like the graphics, looks really cool.
  14. If I recall the rear wheel bearing on those vans are pretty easy to do.
  15. I've noticed these "solder seal" wire connectors and wondered if anyone on here have used them and what they think of them. They're the butt connectors with low temp solder inside. No soldering iron needed, just a heat gun. Let me know your thoughts. Thanks.
  16. Updste***** Installed the Raptor 150 today. Instalation went well despite my big hands in small places. Pump is on along with the 1/2" line from pump to filter housing. I was unable to install the larger line from filter to vp44 because to do so I would have lost the pressure test fitting at the vp44. I needed this to check/set pressure of the new pump. I will be ordering a fuel pressure gauge to mount in cab soon. Then the 1/2" line will go on to the vp44. So far all is well, pressure is rock solid at 18psi. No codes in the OBD2. I also did the lift pump relay to lighten the electrical load from the ecm. Now power to the pump is supplied directly from the battery via 15a fuse and then the relay. Triggered by the original ecm power wire for the pump as explained in the article by @IBMobile. Soooo glad to have her up and running again!
  17. Very well could be a compression issue. Maybe look on ebay for a head for it? I've found a lot of parts for older bikes and such on ebay. Good source for older machines.
  18. Those trikes are nice. Been trying to talk a buddy into one, he has back and leg issues and has trouble holding his 2 wheeler up. His wife won't have it. She says those are for old people. If that's what ya gotta do to ride then do it! If I were him I'd already have one. If she didn't like it then I guess I ride solo.
  19. Just wanted to get the word out that I started a new club in the clubs section of Mopar1973Man.com It is open to all makes and models, on or off road, 4 wheelers and side by sides included. If it takes off we can make changes as it grows for separate sections for street, off road. Open to all members, Check it out!
  20. I'm the proud owner of a mostly original 1977 Honda GL1000 (Goldwing) and a 2008 Harley Davidson FXDWG (Wide Glide) 105TH Anniversary model Number 233 of 2000 built.
  21. I have never been a big Olympics watcher but with all the politics involved now I won't watch. Athletes making their statements on the podium is just plain uncalled for. No better than NFL players taking a knee during the national anthem. If you don't like the country that put your a$$ where your at then leave.
  22. Would that have something to do with the fact that the boost is capped at about 19-20psi from the factory? Anything above that would probably be above it's intended operating range.
  23. Anyone else been following this? Truck drivers in canada have banned together in a record breaking convoy and have now occupied Ottawa. The media has suppressed most of the information on this because they don't want it to get out. lately I've only been getting little bits from tiktok videos. Do a little google search and see what you find. I support the truckers in this and commend them. I could only hope that this becomes a trend to fight the tyranny the goverments of the world are trying to impose on the people. Just thought I'd throw it out there if anyone was not aware.
