Everything posted by Doubletrouble
PS Pump Replacement
That's a nice filter set up. Looks like it could be remotely mounted anywhere within reason.
Tuner for an already tuned Cummins
Yeah, the quadzilla adrenaline would fit the bill. I don't have one personally but several on here do. I'm sure one of them with more experience will chime in soon to list alot if the advantages to having one. One day I'll pull the trigger on one.
Squirrels Got Me Good
I was more thankful 2 years ago. Just sayin
That's around $5.64 a gallon. Wow
PS Pump Replacement
Ok, so the pulley would slip over that and interlock with the tangs? Just trying to picture how it goes together is all. For future reference.
Sam's club buys it in bulk for future delivery. Locking in the price for X amount of gallons. It'll catch up once that pre paid amount is gone and they move on to the next batch so to speak. Around here it's been bouncing between $3.39 and $3.55 at gas stations that carry diesel. The truck stops are closer to $4/gallon. It used to be cheaper at the truck stops but not anymore.
Those jeeps are soooo overpriced. I haul new ones from the plant in Toledo Ohio. I see the sticker price and thank God I have a truck I love and plan on keeping it for a long time. I'll deal with the high fuel prices for a while if I have to.
PS Pump Replacement
Pics of the tangs your speaking of? Purely curious. Also, should one add an inline p/s fluid filter?
DAP Has Saved Me Money
I just ordered a radiator from them yesterday. Called to be sure it was a direct replacement since I had ordered from somewhere else and their "direct replacement" wouldn't work. The guy took the time to answer my questions and checked to be sure they had one in stock. Seem like a good bunch there. Will definitely order again. I did notice one thing though. On the DAP site very few things have reveiws so to all, if you could, take the time to write a review for them. It will help them and those of us shopping on their site as well.
Loud rotational front end sqeal
Not sure you could get a dremel in there?
Electronic Gauges
Those are super nice gauges I just don't know if I want to spend the amount they're asking for them. They're a bit pricey. Maybe I'm a bit of a cheap skate
More than likely. The harness was split into multiple pieces to be installed quickly on the assembly line. Most systems go in as modules. Engine(with wire harness), dash(fully assembled dash with instrument cluster, heater controls all installed). Anything to get their production numbers up.
2001 RAM 2500 Heat Exchanger
It worked. Was working before.......
No Start
- Loud rotational front end sqeal
I've been meaning to get one for a while. Problem is, when I go to harbor freight for a $25 tool somehow I spend $200- Loud rotational front end sqeal
Your right @JAG1, I should have mentioned it is dangerous. I don't have a laser thermometer so I never thought if that. I should pick one up someday. Would seem to be handy at times.- Loud rotational front end sqeal
Maybe they putting the rear end up on Jack stands just off the ground. Run the truck and have someone walk around to localize the noise?- Winter weather - What do you see where your at?
Yeah, I'm sure the county would have a field day. We have a small backhoe on a 3 point hitch. Rather just dig it myself and replace the drainage tiles. May have to remove some trees from the area to prevent it from happening again.- Happy New Year
Yes, already! 2021 flew by although it seems the years go by faster the older I get.- No Start
You've done some work on the fuel system, double check everything to make sure it isn't drawing in air. Sounds like it may be loosing prime when it's shut off. Rather than spraying with ether try cycling the key to start the lift pump, make sure you hear the LP running, then just bump the starter so the lift pump kicks on for 20 seconds. Then attempt to start. If it does start then your loosing prime when it sits. If you have a fuel pressure gauge I would also test that. Be sure the LP builds pressure before starting and maintains it after it's running.- 2001 RAM 2500 Heat Exchanger
Hi neighbor! I was just in Delaware yesterday. I believe there is a check valve of some sort in the heat exchanger that needs to be in the fluid circuit. For some reason I can't link the the thread. Check valve is in the fittings for the steel lines you access it from the bottom with lots of cussing. OEM hoses lasted 20 years so replace with top quality or silicone hose The above is a quate from the post.- Squirrels Got Me Good
I dont know if they work or not but they make those sonic pest repellants. Plugs into an a/c outlet. Maybe put them outside?- No Start
A little info on the truck would help also. Exactly what year, trans, milage? Maybe put it in the signature line. You will have to check for codes and once it is running look at the live data as well. That can tell you alot of the running condition. Get back to us, we will help as much as we can. Also, Happy New Year!- Garage Vehicle: Donna
Nice truck! I see your a new member. There is an introduction section further down the main forum list if you'd like to introduce yourself. Welcome!- Winter weather - What do you see where your at?
This morning, FOGGY, 43 deg, visability only about 1/4 mile. Temps are supposed to start dropping through the day, rain after about 10am, turning to snow later 2-4 inches expected. It's been a very wet fall/winter here so far, lots of rain. The ground here is soggy. When I walk through the yard I sink in an inch and water squishes out around your boot. The ground is so saturated with water at this point when we do get rain the septic and leach field get inundated with water and stops flowing. I've had to drop a submersible pump into the septic tank just far enough to pump out the rain water to get things moving again. I hate to do it but I don't have much choice at this point. I believe I'm going to have to dig up the tile around the outer perimeter of the leach and redo it. I'm sure tree roots have gotten into the tile. - Loud rotational front end sqeal
