Everything posted by Doubletrouble
Jet Stream weak again....
I have sent numerous emails to my state reps in the past several months. I to watch Newsmax, I am also a fan of OAN (One America News) they're very good to. Can't stand mainstream media. Also, for online news I like infowars.com
Parking brake cable help
10th digit is a 1 in the vin. I wasn't sure how many numbers some troll might need to do something with my vin number. I blocked out the bar code as well because it's the vin just in code. Here you can see the first 10 digits I guess it kind of explains why the 2001.5 truck got rear disk brakes and not the entire model year. 01.5 had to have been the actual model change over as far as physical parts and upgrades. Maybe they wanted to hit a certain number for production in '01 and had to change the vin designation early to meet production numbers?
I find it odd as well. I work in the automotive industry, model year change over is typically in july for most. When I first saw the build date I actually checked the title. Kinda wish it was an 01.5, rear disk brakes would be nice. This is the door sticker. I even checked to make sure the vin matched the plate on the dash just in case the door was replaced. Lol I blocked the vin in the pic but it does match.
According to a vin decoder and a dodge parts website (look up by vin) it's a 2001
It's titled and registered as an '01 though. I noticed that not long after I bought it. Didn't make sense then and still don't. Lol I wonder if I could measure while cables are still in? There are pretty big differences in length of the new ones. Might be able to tell from that. Although I would like to see the cable end within the drum as well.
I recently had the parking brake hang up a little while leaving for work in the morning. I know the cable from the left rear wheel is in bad shape, outer casing is bunched up and looks to be the culprit. I would like to just replace both cables going to the rear wheels. They aren't very expensive on RA but there are so many I'm not entirely sure which ones to order. Am I going to have to measure the cables since there seems to be different lengths? There also seems to be a cut off, parts must have changed after 7/00. Mine was built 2/00 so I at least figured that part out. Truck should be in the sig but just in case it's a 2001 (man. Date of 2/00 ) ram 3500 quad cab long bed. I don't know the wheel base (some cables show WB measurments). Just don't want to order the wrong parts. Thanks for any help.
Timbos APPS time
Ok ,thanks for the explanation.
Timbos APPS time
Ok, gonna sound stupid for a second. What is an idle validation switch? 🤔
Timbos APPS time
I've heard of the timbos apps but what is the difference or advantage over an oem replacement? Just asking.....
It's Getting Worse Out there......
Wasn't really pointing you out @Mopar1973Man, the ones around here are obviously yuppies, their houses more of a country decor display than it is anything else.
Another loaded 2nd gen
I bought some from Amazon that were plug and play. The studs were a bit short, had to compress the foam gasket to get the nut started but once tight they were fine. Been on there for 2 years now. Mine are also heated/power.
I agree with you @JAG1, I live in a fairly rural area. Mostly farm land out here. I'm the past 10-20 years some of the farmers have come on hard times and sold off frontage and now the city dwellers are building out here. It drives me nuts when I see construction start on another one. We sit on about 6 acres and will never sell an inch of it.. my uncle still owns what's left of the farm,, about 65 acres, 50 of it us tillable the rest is woods. I hope maybe he will will that to me to be sure that it never gets sold off. It cracks me up when people buy 1-2 acres out here and put a house on it and say "I live in the sticks" bunch of idiots.
Seems like if someone wanted to tinker with it on a small scale a lawn mower engine would be a good test subject.
Very cool! I don't know how it all works but it's interesting to see someone could make one at home.
That sounds interesting.
@Dieselfuture, how did a small hydrogen generator help fuel milage? Did you switch from gas to H2 completely for several miles or add the H2 to the gasoline?? Just curious.
Noob looking
Yeah I bet it was. In all honesty I like the nv4500 5 speed. The sycros are no good going into 3rd so I just either double clutch 3rd or float into it. Either way it works out. I tow through a 10 speed at work enough. I don't think I'd want to drive a 10 to get home to. Lol I like getting out of my slow, underpowered truck at work and getting in my dodge. It really feels fast then. Lol
Noob looking
That would be cool. Sound like a lot of fab work. I don't trust my own welding enough. Lol
Noob looking
It would be awesome though to have an Eaton fuller 10 speed. Don't know if it could be done with a 4x4 though.
I actually just watched the Matrix 2 days ago for that reason. I've seen it many times before. Crazy how there are so many similarities in the movie. I'm lucky, most people in my little circle are against it and alit of people I work with as well. So mm e don't want the shot simply because they don't trust it and other like me see the big picture. I don't watch mainstream media at all anymore. I like Newsmax on TV and I look at infowars.com online. I'm not affiliated with either just stating my sources of information. Very scary times, good time to get right with God or whatever your belief system may be (I still believe in freedom of religeon) and also try to be as healthy as you can. I need to work on the second one more myself. Lol
Post Mod Trans Issue
There's speed limits in Chicago? I drive through there for work, my truck is governed at 63/pedal 65/cruise and nearly get ran over. Traffic is horrible and 294 is a mess.
Need to buy grid heater
Oops! I've done a couple of Dumbazz things like that as well. Good luck, hope ya find one.
Noob looking
So Mike @Mopar1973Man, is the grar and shaft in the above pic now a paper weight on your desk?
It's all part of their plan to collapse the economy. They are also fueling the racism issue through media to keep everyone at odds with each other rather than uniting. Then toss in the controversy of the LGBTQXYZ just to get everyone even more distracted from what is really going on. I could rant about this for awhile but I'll leave it lay here for now. I tend to offend people sometimes.
