Texas CTD
Everything posted by Texas CTD
  1. Thanks!I'm using the same kind of regulator you have, and right now it idles at 15 PSI, and under light throttle it'll hit 20 PSI. I can tell the regulator really starts dumping fuel at about 25 PSI. The thing is, if I try to bring down my top end pressure, I have to sacrifice idle pressure. :doh:I have a 3/8" pickup line to the filter, and will soon have a big line kit. My return line is 3/8" down to the frame rail, and then my stock return tee's into the Assassin return, and then I have 1/2" line back to the tank.I'm running my pulley's at a 1:1 ratio, and that is 212 GPH - good for 1,000 HP worth of mods. :D
  2. white buffalo, Direwolf,I don't want to take this too far off topic, but what kind of regulator are y'all using, and how is your return line setup?
  3. I would look around for a used one and try it out. You might want to go bigger after you try it. . .
  4. Is that going off of the odometer, or GPS?
  5. 1998 1 ton, 24 valve Cummins QC/DRW 2 wheel drive NV4500 5 speed standard 3.54 gear ratio 81,000 miles 53 block Stock wheels on 215/85/16 road tires DiPricol boost & EGT gauges Isspro fuel pressure gauge DTT Assassin belt driven lift pump BHAF Tow mirrors Smoked cab lights Brush guard Headache rack 5th wheel tailgate Bed toolbox New bumpers!!!
  6. :lmao2::lmao2:I feel like an idiot!So yeah, get gauges, and then a TST, and floor it!
  7. jttrucker - you're going to want to throw some money into your transmission, and you need a set of gauges.If you take Wild & Free's advice (if I had the money, I would do what he said:thumbup2:) go ahead and get the EZ, and stack it with the TST Comp. TST is fueling only; no timing. If you do that, you NEED gauges - and that setup will lay down some power, and hot EGT's.
  8. Use a washer or two to "shim" the regulator, and put your idle pressure at about 19 PSI - that'll keep you above 14 PSI at WOT.
  9. Kinda sounds like a crappy lift pump to me. . .
  10. Read the end of GreenRiver's last post.
  11. NV4500 is a synchronized transmission - I do my best to drive it how it should be driven.
  12. I have no experience with them, but from what I've heard about them, I'll just stick with a good ole standard output.
  13. I'm thinking it's a 2-3 PSI bump in pressure. . .
  14. Hey, thanks for posting those pics, Ryan.I have a big line kit I need to install, and it said to put the tapped elbow at the VP, but I want the tapped elbow at the filter housing, but I figured it didn't really matter.
  15. I have a set of manual mirrors. Electric ones sure would be nice. Or buy mine. . .
  16. http://www.cumminsperformanceparts.com/ffip59.html
  17. Or just get a BHAF.
  18. Pretty sure stock is either 245's or 265's. Personally, I'd run a 235/85/16 road tire. . .
  19. Where did you get them from? Did they come with brackets? CSM - do you need brackets? (I've been trying to get rid of my extra set )
  20. I second discount auto mirrors. (If you end up getting a set of mirrors without mounting brackets, I have a set I'll sell to you)
  21. I think I'm having the same problem, and I'm noticing some dirt too. 'Bout time for a BHAF. (not a very detailed picture)
