At least my junk isn't blowing oil all over the place. Mine does leak a bit around the gear case and burn a bit through valve seals.
Billet tappet covers aren't friendly, but they do work well for getting the pressure out. I'm going to figure something out to keep the oil in the motor.
Either reduce the blown on the piston rings or reduce the boost and drive pressures.:whistle:
Under extreme cylinder pressures blow by is going to happen no matter what.
Not going to reduce anything, just need to figure out how to keep the oil in the crankcase with that style of breather.
Edited by TFaoro
The tappet cover he has is completely open for the holes. Nothing to slow down or condense the oil before exiting. I had a similar issue when I tried to use it. I did warn him it was going to push oil out of them lol
I have the keating cover with "baffles"
Either way the engine needed something so......
I'll just leave this here.... I think UOA's like this speak volumes for synthetics. TBN is over 9 after 11.5 months.
I'll add that my average fuel economy was around 13 for this timeframe. The truck gets good mileage when empty, but I'm not empty often. This 6400 miles has some descent towing/hauling and all of it is with a 400rwhp tune. I'm not overly easy on the motor, but I don't abuse it.
Edited by AH64ID
Yes. They have a couple, but I like the AME Heavy Duty Diesel and Marine oil. It's a CI-4+ 15w-40 that does awesome even in cold soaked temps down to -20°, which is the coldest I've started it in. I've ran it down to -30° but it was "warm" when I got to those temps.
59 minutes ago, jlbayes said:
Why in the world did I think you had the open hole one like I did.....
:lmao: because you told me very specifically do NOT get the one you have.
Get @trreed to buy it from you and you can buy a Keating cover.
5w-40 and 0w-40 have the same high temperature (operating) viscosity as 15w-40, and running any of the aforementioned synthetics will, at the very least, be just as good as conventional oil. Where the synthetics excel is maintaining the proper cold viscosity at lower temperatures, eg. cold starts, as well as attaining a much higher oil degradation temperature, which you would find in your turbocharger after a hot shut down; the synthetic oil doesn't start to coke until almost 100 F higher than dino oil iirc.
Unless you've dealt with the PCV and care that much about a little weeping from a seal or two, the only thing synthetic is going to hurt is your wallet...
Edited by nukethenazis
  • 3 years later...
