Shopping for an exhaust brake, what do you have?
- Replies 15
- Views 4.5k
Me78569 3 posts
pepsi71ocean 2 posts
01cummins4ever 2 posts
NIsaacs 1 post
HE351VE here, built in EB. It is very hard to find a better turbo for sub 450 hp when towing. You can find them all day long for $500, few hundred bucks for a controller from lilbb.com or make your
Too much power / torque down low when towing breaks things. Head gasket, trans, etc. With that in mind, I think @Me78569 has a great setup.
I have a BD that bolts to turbo with 5 bolts, it comes with a flange that replaces stock one. It is a 3" and not sure if there are any that come as 4" only inline ones are bigger. That's why I had a t
My truck is a daily driver and I tow a 30' camper and various equipment on my 10k trailer several times a month. I would like to install an engine brake. Looks like Banks, Jacobs, Pacbrake, and BD are the primary options. I have also read that some turbo setups offer some braking ability. I would like to tune and setup for better low end power and towing. I would like better spooling down low also, so a different turbo may be in the works. My exhaust off the turbo looks like it necks to 3" out of the turbo housing and then up to 4", would like to make that one size if possible.
So what would you all recommend? I searched this forum and others and most replies were from ~2012 so I thought a new discussion might benefit others also. I would like to know what options are nice, how to engage it, air vs vacuum, manual switches, ecm control, apps signal, anything to consider.
I also hear the brakes may help spooling, egt's, and power curve?
Any and all info is greatly appreciated.
-longjohn
