Explain to me how the 47re shifts
- Replies 28
- Views 38.8k
Evan 6 posts
Me78569 4 posts
Great work! 4 posts
Dynamic 3 posts
You basically have two different pressures at work in the VB when determining upshift and downshift points. First, there is governor pressure, which is determined by road speed. Early transmissio
Ahhhh... I understand your question now. No, governor pressure continues to rise with road speed. Also, FWIW, engine rpm has no bearing on either governor or TV pressure. Only road speed and thro
If the little metal tip of the neutral safety switch makes any contact with grounded metal: IE the rooster comb it will start. The plastic bit prevents electrical contact except where it's cut out in
Alright,
I am trying to work through an idea of mine in regards to lockup. What I am trying to do is figure out how to predict the 1-2 shift and predict the 2-3 shift. So the question I have is what happens to make the VB decide, Time to shift into 2nd. and what happens in the vb to shift from 2-3.
Is it a pressure difference between the tv and vb pressure? I don't really understand what happens in the rats nest of a VB.
So is there something I can watch VIA a pressure switch or whatever to show that the trans is going to shift? Can someone smarter than me explain the magic of how a 47re shifts in low gears?
Reason I am thinking of this is the advent of the Firepunk anteater tranny controller.
How is it that they can control all shifting 1-4 without needing a special VB? http://www.firepunk.com/anteater/
