Happy New Year and conversation with engineer
- Replies 20
- Views 5.2k
JAG1 4 posts
dripley 2 posts
01cummins4ever 2 posts
015point9 2 posts
I like old engineers. If he keeps talking... you can offer for him to reach me here and i can see if he wants to write up some articles... a nerd and historical section could be fun.
I know the feeling in RV parks, I do both boondockin and RV parks, and one thing about the parks is the old dodge always starts up a conversation with someone who just enjoys talking trucks. Or just c
Ran up on a guy at gas station in south Alabama that had older land rover with a 4BT in it. Not car but not a pickup or semi.
As a new member just wanted to say thanks for all the help. I really can’t contribute much. Why? Well because I don’t know much. Even though I’ve had my 2001 since 2005 I have only done the simple maint stuff like change oil and filters. But that has changed after paying thru the nose for a bad install of fuel system.
For last 3 years we’ve wintered in Yuma to get out of the wet of the northwest. The RV park that we stay at word travels fast. When our fuel system fell apart, the next day this guy I’ve talked to many times before walks up and asks what the problem was. At the time all I knew was truck wasn’t running and the garage was supposed to be calling soon. So we sat down, drank coffee waiting for garage to call. He tells me he’s a retired Cummins engineer and if I have any questions, just ask. I had no idea what his past life was, but we talked Cummins for the next 3 hours. I’m sure when cut he bleeds Cummins colors. Here is some of what he passed on, best I can remember. Maybe you’ll agree or maybe not. He said he worked “in between” of dodge and Cummins.
Oil…brand doesn’t matter but make sure “spec” is right. Stay with dino oil. Says synthetic while an excellent good oil, it just doesn’t pay for itself in long run as it only takes a fuel injector being a little bit off to make excess soot and soot a big killer of diesel engines.
Filters…He only uses fleetgaurd. And buys in person so he can inspect before buying. Gave me the whole history of why fleetgaurd filters for the last 10 years comes in plastic bag, inside of cardboard box. Think storage and humidity.
What has he done to his. He says the psi in coolant system for the radiator is high in his opinion, so he runs next psi size smaller for rad cap. Thinks the oil line from tubro to engine is too small so he installed next larger size. Also when changing oil he disconnects oil line from engine and lets it dangle down to drain so he knows line is clear. Oil line has a bit of belly to it and doesn’t want any oil coking up, so by draining the line, he knows line is somewhat clear.
He follows the maint book less 10 percent. Which I didn’t understand at first, but here is an example, if something is due at 100,000 miles he does it at 90,000.
I could go on some more but that is jest of our talk. He had lots of stories about Cummins and Dodge. Some funny, some sad.
Just thought I’d pass it on. Remember, I’m not saying any of his advice is right.
And thanks for all the help LAST year.
