- Replies 264
- Views 48k
Mopar1973Man 81 posts
dripley 22 posts
Dieselfuture 22 posts
Scottfunk 19 posts
From reading all this it boils down to what you are doing with your truck. For me I am mostly empty these days and cruising on the 265's at 75 netting me near 20 mpg. When I tow I try to stay near 65
I just had the best luck at the junkyard today! I scoped out a Dana 70 that was under an E-350 last weekend that, according to the BOM tag, was a 70-U with 4.10 gearing. I studied up a little on it ov
I have now driven over 1,600 miles with the 245/78R16's and I am very happy with the results. About 700 miles of the driving has been towing within a 60 mile radius ranging from 15,000 to 19,600 lbs
I just got a pair of used 245/75 R16 tires from a friend. So I mounted them up on my old aluminum mags and mount the 245's on rear axle of the truck.
They are a bit shorter in height. The gains are great!
Engine load is reduced by 5% to 10% roughly.
EGT's are about 50*F lower.
Acceleration is way better and faster.
Cruising RPM's are right about 1,960 RPM at 65 MPH.
I've got to reset my cruise timing limit on the Quadzilla I need to drop from my current 25% to 20% it was holding cruise timing climbing about 2-3% grade.
I'm going to document MPG usage as well in the coming days.
