2001 Ram 2500 complete interior restoration
- Replies 54
- Views 37k
Cronus577 11 posts
portlandareae28 7 posts
SavageTusk 6 posts
dripley 5 posts
I did just that. Used the soap cannon, scrubbed, and then power washed. It takes a couple days to fully dry because of the padding. While it's drying, I'd suggest putting down some sound dampening
Quick update, found some interior at a price I couldn't pass up so I convinced the wife to let me get out and i finished up the interior. Just need to figure out how to go from non power seats to powe
You did a fantastic job and is to be commended.
Hey folks, I haven't posted in a while but i've been around tinkering with 2 out of the 3 2nd gen 24v's that I have. My latest project I've been working on is my red 2001 sport truck I thought I'd share.
I got the truck a few months ago and immediately began tearing it apart once I got it to the house. The interior was disgusting and falling apart, typical broken dash, it rattled, there was mold growing on the carpet and it even had maggots under some old food. Here's the progress so far.
Torn apart within the first 24 hours of owning it
The absolutely disgusting old carpet, I was afraid to even touch it without gloves..
How it turned out after scrubbing it and using a house carpet extractor with the hand hose, went over it twice
Got the carpet back in, did a slightly darker dye to get rid of the orange discoloration from the coolant dripping onto the passenger side, This was gone over twice and then I hit the passenger floor for a third time while it was in the truck so it's still slightly damp so it's a little bit darker right now.
Put some of the interior back in after a vacuuming as much as I could, the back seat looks brand new!
Time to work on the old cracked dashboard!
The whole dash frame got taken out, stripped, wiped down of any dirt because i'm very meticulous. If I'm going to work on something, I figure might as well do it right the first time.
The LMC dash fit perfectly with no issues at all.
At this point in time I figured I was already this close to the HVAC box, I might as well pull it out and clean it! If you look at the blend door at the top right, the foam had mold growing on it, no thank you!
More dirt, going to have to clean that!
Well, I sure was glad I decided to remove the HVAC box, Leaky heater core, dirty evaporator, bad blower motor, and a crumpling blower motor resistor. Yikes!
The entire HVAC box got taken apart, cleaned from top to bottom, and reassembled with all new everything! I even went ahead and pulled off all the old foam and put on a new sealer where the old foam was falling apart.
Now that the firewall is cleaned up, time for the HVAC box install.
Boom! Put in place and ready to go.
Remember the old moldy foam from earlier? All gone, and seals perfectly!
The midnight grind, literally...
By the morning I had everything put back in and was ready to go.
All that work and the dash bezel was still cracked, well, until I FINALLY found a wood grain bezel in 100% perfect condition with no scratches or broken tabs!
Out with the old, in with the new! The steering wheel bugged me though so I ended up getting a cover for it.
As of last night, I believe she's probably the the truck with the nicest interior. Just need to find some power seats and some agate wood door panels. Maybe do a new steering wheel and definitely need to get a 12v outlet that clips into place nicely. Every piece of the interior got pulled out and cleaned, the cup holders got disassembled and cleaned, including the rear one under the console. This interior is immaculate now.
Here's a little bonus for sticking around this long.
I also did the 4th gen steering upgrade, as well as a Dodge Off Road Track bar and a steering stabilizer. Big difference coming from the stock setup, Once I got all of it in and took it for a test drive, my power steering was leaking and my water pump went out. That's actually coolant dripping on the ground in the last picture but since then has all been fixed!
The wife will be a happy camper driving this until I sell my 99'.
Thanks for taking a look! It was a lot of work but I don't regret a single moment of it and will do it again in a heartbeat with the way it turned out.
Edited by Cronus577
