Drawstraw Users - How low can you go?
- Replies 79
- Views 13.1k
Mopar1973Man 26 posts
LorenS 11 posts
Dieselfuture 9 posts
Doubletrouble 9 posts
I try to use 1/4 as an empty mark. Won't let it below that in warm weather. Cold weather I'll keep it above even that. Probably between half and quarter. I had the fuel.light come on once, made
The hole drilled for the draw straw. Not inside the sender bracket. This is the thickness of a standard quarter (coin) between the tip and the tank bottom.
Most part yes. Mine was the supplied draw draw with my AirDog but I know the truth that Eric and Vulcan Performance produce it. So yeah that is like it but mine was a bit different fitting wise as you
27.641 Gallons after hauling a car back on a trailer from Boise, ID did 14.76 MPG. Still solid fuel pressure and no issues, no pressure dropping while driving. Remember this is for old school DrawStraw users and not in the sender straws. Lets see how low you guys can go with your old school straws.
