There are quite a few creepers on the market these days, but most have complaints about breaking, plastic tearing near the wheels, wheels worn out in two weeks, bearings falling out, etc.
Does anyone have one they can recommend? My old wood one from Kmart I bought back in 73, has seeing its last days.
With all the bad reviews I thought of going to Snap-On for their standard duty creeper.
T.I.A for any thoughts or warnings on which one to go for or stay away from.
  • Replies 27
  • Views 5k
  • Doubletrouble
    Doubletrouble
    How bout one like this?
  • Dieselfuture
    Dieselfuture
    you can say I've done a few things I'm not proud of   it all seem to work out in the end
  • My dad's Snap-On creeper is around 30 years old.  No problems with the wheels, bearings, cracked frame welds, or anything. The padding is still good, and pad cover hasn't split - it is thick material.
 Best ever seen . See if I can look it up..........
It's called the Human Hoist. for $12,000 Bucks. I don't think I'll be doing that. It was not available when the video was made and cannot find a Vid showing anyone that has purchased one yet. I don't think they are on the market yet. That would be a good tax write off for those that have a business and have physical disabilities. May need a docs letter to be able to write the whole thing off, not sure on something like that.
Thanks Doubletrouble it's really cool.
Have you thought about one of those cloth like sliding mechanics creepers? I saw them on one of those truck shows. Seemed to work good for them but I've never known anyone that has tried one.
https://www.google.com/search?q=sliding+mechanics+creeper&source=lmns&tbm=vid&bih=512&biw=360&client=ms-android-verizon&prmd=sivn&hl=en&sa=X&ved=2ahUKEwiB0o6o8vvtAhVKG6wKHUTzBM0Q_AUoA3oECAAQBg#
I didn't like some of the reviews on those.
I found an Ergonomic Plastic molded one with good reviews Made by American Forge and Foundry. Special order only at Lowes for $145, I found for half that at Cardid It's their heavy duty one # 3909 a bit longer and wider with tool trays. I will mount some metal plates near the headrest for magnetic LEDs :drool:
2 hours ago, Dieselfuture said:
Mine is old craftsman, stella going. Not sure what I'd buy next when needed.
I heard it's got burns and beer stains from puttin out the fires when you do electrical work under yer truck..:lol:
I haven't seen one worth buying yet. They all seem to have poorly designed frames and the casters fail shortly therein because they don't like to operate at angles. Anything plastic is just a toy, they tend to flex. Mind, I'm 220 on a good day, 235 on a bad one.
I still use cardboard, or if I'm feeling fancy, a $5 walmart fleece blanket.
Edited by That Guy
The really thick stuff they use for shipping batteries and the like.... that is heaven.
30 minutes ago, Doubletrouble said:
I use cardboard alot as well.
Cardboard is all that I've used for the past 26 years.   With cardboard you don't have to jack up the car very high.  You can slid in and out from under easily.   It helps keep the concrete floor clean under the car.  When it gets dirty recycle it and get a new piece.   I get all I want from the dealer's parts department or the local Costco.
:poke:  you can say I've done a few things I'm not proud of  :clap: it all seem to work out in the end
I use Harbor Freight moving blankets.  You can usually get them on sale for a few bucks.
I like cardboard too, but my trouble is it rains often here and the driveway is wet working in between rain showers. It's nice to have a 4x4, a little higher and something I can easily dry off before laying down again.
Well last few I've picked up from HF. Don't do any plastic creepers mine was only rated for 230 pounds at the time I killed the plastic one I just crossed over 240 pounds. I've got another one from HF which is steel framed and padded back board with tilt head rest, not bad. Part that sucks is it seems to be always falling apart screws and bolts loosening up.
My dad's Snap-On creeper is around 30 years old.  No problems with the wheels, bearings, cracked frame welds, or anything. The padding is still good, and pad cover hasn't split - it is thick material. He's been well over 250 pounds the whole time.
The wheels are larger than most, and I think there are 8 wheels, not 6.
I'm on my second Craftsman in my life. First one the casters gave out and wife got me a new one for Christmas before I got them replaced. I kept it as a backup. Still didn't get the casters replaced.
I use some half inch foam. bought a short piece 2' by 6' when I reroofed the house a 3 years back. Bought another from HF they sell as a shop floor walk pad. pretty cheap and still going strong. Works great on the gravel driveway. Water does not bother them.
It's funny my old KMart creeper was great for many years, repaired it a few times. Now the same one sells around 3 times what I originally paid $24.95. Now sells on the net for 74 dollars. I'm amazed they still make those wooden ones.
I do carry a padded mat with me in the RV on long trips. IBMobile likes using it and it helps slide things in and out of storage in the RV with the 5 foot long basement.
Now you got me regretting my not getting one...... Oh well, I can try out the AFF and report about it.
