99 5.9 24 valve help wanted
- Replies 30
- Views 6.6k
AdanRod17 6 posts
Mopar1973Man 5 posts
JAG1 4 posts
Dieselfuture 4 posts
Not too sure of the year it was on the truck when I bought it but it’s the block replacement one. These are the photos of the destruction of that bearing. It sounds like you have the whole system with
Not that I want it deleted... I want the information to remain. I just can't server 17 years of data fast enough with a 8 CPUs. Now neck it down to the last year I can sever that faster. This way the
Thanks all for yalls help, I just went ahead and bought a used ecm for a 99 and she's up and running, the only thing I'm hunting down now is a whine that sounds like a boost leak, that increases with
The truck is a 1999 5.9 Cummins, for the past 6 months I've had intermittent problems which ultimately led to a no start, use to buck horribly until I turned it off and back on again, and it would run fine for sometime then back to bucking. Injectors are new, injection pump is new, so is lift pump. I recently took my ecm to get tested but they said they couldn't test it cause I tried to break into it (rookie mistake, I should've left it for the pros) which led me to buying a used one that came off a 2001 cummins, and still a no start, any help would be greatly appreciated, thank you
