Block heater usage question
- Replies 24
- Views 5.7k
Doubletrouble 5 posts
dripley 4 posts
LorenS 4 posts
Mopar1973Man 3 posts
Supposed to be getting a big arctic blast soon. I think Mopar1973Man is going to have AC ripple from shivering so much as he has no firewood. He better get some split and standing up to dry in the ent
I’m in northwest Colorado, and -30 in the winter isn’t uncommon in this area. I leave mine plugged in all night if I’m going to use it the next day. I’ve done this with this truck since 2008 and the f
Just curious as how you all use your block heater. I am of the mind set that the more you use something the faster it will wear out so I try not to over use things if not needed. So that leads to:
Is it better to leave it plugged in all night or possibly for a day or two at a time or would it be best to just plug in an hour or so before you fire it up?
Any advantage to either practice?
This morning the outside temp is 9° so I figured on plugging in an hour before start up today just to aid in warm up and easy cranking. It should start fine without it but I know it will be easier on the engine with a little heat in there.
