  1. I guess all my tight maintenance has kept that little 46RE transmission going. MoparMom and I figure we'll drive these trucks till the wheels fall off. Truly they both have been rather low maintenance and failures are very very rare.
  2. As for the ASD relay swap with another relay. This should be tripping a P1389 code. As for fuel pump relay swap with another relay. This should be tripping a P1689 code. As for the overflow valve its rarely. bad but you could pull it out and test. http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/25-fuel-system/88-bosch-vp44-injection-pump-overflow-valve
  3. As for the two error code was the only thing wrong. Steve at Alpine Automotive inspected everything he could and didn't see any problems with the rest of the transmission so Governor Pressure sensor was all replaced and band adjusted and fluid change with filter. I'm planing on adding a transmission temp gauge to this truck for the safety sake. I does get use for hauling trailers now and then.
  4. For all the members in the northern states I would like to alert you to the fact we have cold weather coming so be aware and get you winter supplies together for your diesel fuel and be ready for cold temperatures. I'm forecast to be as low as 14*F above.
  5. Actually the first sign of failure for me was white smoke at 48k miles and then the P0216 code by 50k miles...
  6. I also think at least for the 24 valved truck with the VP44 and the injector return will warm the fuel eventually. This is one of the small reason I kept the stock filter can is it draw warmth from the manifold and warm the fuel as well. In 12 years of ownership I've never experienced a gel up problem. I've seen winter temperatures as low as -25*F and no issues starting or running issues. I might see a slight drop in fuel pressure but that's all.
  7. I would take a few gallons of cheap gas or ATF and rinse all the debris down through the pan with the plug out. Then drain well over night load with oil. Strap it down with 4 or so ratchet straps using blocks and everything to steady the engine. Do your test fire. Even after the engine is installed to a vehicle I would only run maybe one day then change the oil again. At least knowing you got all the debris out of the system. As you'll see you can do a test start on a pallet.
  8. Me78569 it might be time to turn that around into a article page with all the important part number can be found in one easy spot...
  9. Look up the MSDS sheet for the Cenex... http://www.cenex.com/~/media/cenex/files/sds%20library/msdswinteraidiiwinteraidiii.ashx
  10. Manuals where all HX35W turbos...
  11. Same here it makes me think trans temp is a bit too high. I wonder if the torque converter is slipping.
  12. Stock 3" exhaust, +50HP injectors, BHAF, and Edge Comp... I can pull most 6-7% grades in 4th at 55 MPH still be well below 1,200*F.
  13. Thing is I would contact the station owner. He/she should know what they are selling as for employees they are typically uneducated or don't care. You could see about getting a barrel of PPD (pour point depressant) and mix your own fuel at home. http://www.aglandsd.net/app/download/957479632/2014+Winter+Fuels+Guide_LR10151+(2).pdf
  14. The truck was delivered to Alpine Automotive tonight. As soon as I get some information from Steve or Tracy I'll let you all know. But I know I could of just bought a Governor Pressure sensor. Like I said I wanted to have it looked at for all wearable items and put back in tip top shape. What good would it be to replace the Governor pressure sensor and then have a band or torque converter give up? So its being inspected.
  15. Correction... Welcome to the trouble free side of electric gauges if installed properly. I've been picked on about that for some time now. The only reason I jump in on it was to take on another challenge of figuring out electric gauges and what causes the fuel pressure sender to fail. I still say the most trouble free set of gauges is still mechanical gauges like ISSPro EV's.
  16. Edge Comp and Edge Juice are the same for software. Just Edge Juice has the gauges and toyz which I don't suggest. The alarms and limits on the Edge Juice tend to create poor performance because most owners mis-set or mis-use the features. So I typically tell owners to turn all that off to get back to Edge Comp type performance. As for any washable air filter I suggest against too many good engine ruined by a washable filter. There is no way for a owner to know when the filter has failed to filter. So most people hang on to the filter way too long and end up dusting out the engine. BHAF is fine for most or use your stock air box. As for gauges I tend to favor the mechanical gauges more so but I'm working with ISSPro gauges and really impressed wit the EV2's series which are electric.
  17. If you got gauges (fuel pressure, pyrometer, boost) your good to go. Yes it would work just fine. I'm close to you in design check my link in my signature. Personally, I would take that out and throw it under the tire.
  18. It's soaking wet and raining. I don't have a hunting license. Then on top of it I work 6 days a week.
  19. An atheist was seated next to a little girl on an airplane and he turned to her and asked, "Do you want to talk? Flights go quicker if you strike up a conversation with your fellow passenger." The little girl, who had just started to read her book, replied to the total stranger, "What would you want to talk about?" "Oh, I don't know," said the atheist. "How about why there is no God, or no Heaven or Hell, or no life after death?" as he smiled smugly. "Okay," she said. "Those could be interesting topics but let me ask you a question first. A horse, a cow, and a deer all eat the same stuff - grass. Yet a deer excretes little pellets, while a cow turns out a flat patty, but a horse produces clumps. Why do you suppose that is?" The atheist, visibly surprised by the little girl's intelligence, thinks about it and says, "Hmmm, I actually have no idea." To which the little girl replies, "Well then, do you really feel qualified to discuss God, Heaven and Hell, or life after death, when you don't know S h i t?" And then she went back to reading her book.
  20. MoparMom says, "No hunting from the deck!" If I was to go hunting for a turkey I'd have to go up behind the house.
  21. Did you test the injectors to see the spray pattern or pop pressures? Do you have air in your fuel? You might hook up a piece of clear tubing and loop it on the windshield and see if there is any air bubbles.
  22. It seem like the ol' 1996 is finally giving me some grief. No longer have 1st gear unless I manual shift to 1 or 2 gear then it engages 1st gear. But I'm getting 2 error codes. http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/59-obdii-error-codes/385-p1762-gov-press-sen-offset-volts-too-low-or-high http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/59-obdii-error-codes/387-p1764-governor-pressure-sensor-volts-too-low With the amount of miles I've got on the truck at 156k and it the original transmission I'm opting to let Lindy's friend in McCall, ID do the service work to the transmission. If he sees anything else while the pan is off then he can go through and fix it. I know the Governor Pressure Sensor is the problem and most likely failed. But what other wearable parts and solenoids could there be? I'm not automatic trans man at all. Alpine Auto https://plus.google.com/102270410291765694865/about?gl=us&hl=en
  23. So which one should I take?
  24. Go to my computer and look at the photos. Then select them on the other window and upload. I have to do the very same thing even with Ubuntu Linux.
