About that high idle kit
Soon to find out what the MPG fooler does to power I'm setting up to hit the dyno in April to do some testing of the effects.
911 help, dying computer, how to quick backup everything?
It's easier for me to call you and explain over the phone. Sorry...
Chainsaw sharpener..
By the time I get that far off my chains are typically toast anyways and well abused. No problem I'll keep it under my hat for ya...
Total drive size is 1,000 GB or 1 TB... First block is Root which is 83 GB in size. Root is where all the Ubuntu Linux program files are stored. Second block is Home which is 99 GB in size. Home is where all your personal folders and data is stored. Third block is Swap which is 5.4 GB in size. Swap is what windows calls virtual memory. But in Ubuntu its rarely even used. ... on and on... Thing is Windows would assign a drive letter to every partition. So root would be C: and home would be D: and so forth. In Ubuntu Linux there is no drive letters just folders. What great about this is you can force commonly changing data forward on the drive giving it better access time where storage stuff like music and download a spot to the back of the drive where it doesn't need the boost. This is true for Windows NTFS system but now with Linux Ext4 format data is written differently it starts in the middle of the disc and works outwards. So Ubuntu Linux typically has faster drive timings compared to Windows and no fragmentation problem like Windows NTFS does. Brief article on installing a Ext4 Hard drive. https://help.ubuntu.com/community/InstallingANewHardDrive Some conversation on NTFS (Windows) vs. Ext4 (Linux) http://ubuntuforums.org/showthread.php?t=1786501 Might help you.
Ummm... What happen to the good old fashion saw file? I hand sharpen everything in the field. Like I found out from experience that you can tune a chain for particular wood or jobs by changing angles. I typically keep a small flat file in my tool box for rakes.
People are hung up on several things they think are like gasoline engine.
Here is a partition drive. What partition drives do is is separate data logically so it can be two different file format say Linux or Windows. May even just separating data like I've done. There is a performance gain to separate partitions being the index is smaller it quicker to find data. In my layout I moved static stored files like pictures, videos, music and other thing like that away from the system so fragmentation didn't occur which is a big problem for Windows but not on Linux. But keeping the partition is still handy because the static files stay out of the way. As for Linux relax and install it. It will dual boot with Windows very good. Not to mention Linux can see and use all your Windows files. But Windows can't use or even see Linux. So Linux is very universal for OS software.
falls on face
Kick down cable needs adjustment it sound like...
Wood stove pipe damper problems... again...
Just using my stove for example I've got a pyrometer installed about two or so feet above the top of the stove. On my first start I can see at least 1,400 to 1,600*F worth of stove stack temps. I've even gone as far as pulling the gauge out of the stack and the probe is absolutely red hot. So if it just cheap steel with cast damper I bet the heat is enough to soften the steel rod and give you this problem.
Actually your backwards. It sets the IAT to 143*F and retards the timing. The colder the air temp gets the more and more advanced the timing gets. Which with cold air and overly advanced timing gets that heavy knock where when you flip to MPG mode the knock fades away because of the retarded timing. High cetane winter fuel will make it even more pronounced.
Not a problem I've gotten pretty good at doing remote support for Linux now.
Seriously. If you had Linux installed the SMART (Self-Monitoring, Analysis and Reporting Technology) would of warned you long before the drive was dying and given you more than enough warning to backup data before it failed. Like the 250 GB drive on my desk it fail this winter in the shop computer and both BIOS showed the failure and so did Linux at boot time then impending drive failure is going to happen backup now before the drive starts to fail. http://en.wikipedia.org/wiki/S.M.A.R.T. <- Read more... What is really weird is Microsoft doesn't use SMART technology in Windows software other than the Scan Disk for error but there is no software within Windows to monitor SMART status of the drives unless you purchase the software and install it.
Time to put the RV on a diet?!
"I've got too much Stuff in my RV!"
Believe it or not retarding timing or preventing excessive advancement from excessive cold air. Cold air tends to hurt MPG's optimal IATtemps for MPG's is about 100-140*F
Believe it or not retarding timing or preventing excessive advancement from excessive cold air. Cold air tends to hurt MPG's optimal IAT temperatures for MPG's is about 100-140*F
47RE Dipstick Tube Venting?
NO! Do not adjust the voltage! The voltage is only for the IVS of the APPS nothing more. I would run the diagnostics of the error code. http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/59-obdii-error-codes/151-p0122-apps-sensor-signal-voltage-too-low
Just change the oil, it'll be fine! ok.... what do you guys think?
Me personally would tear it down completely and start over.
How much f. pressure is too much?
There is no proof of excessive pressure blows seals but why take the chance of it happening. You only need enough pressure to keep the overflow valve open. So the suggested pressure is 14-20 PSI. Your not going to increase flow much more... Return is much much smaller...
falls on face
I would check both fuel pressure and error codes and figure out what is causing limp mode? Over Boost?
110V Question
Interesting. I really don't have a answer. Is your neutral and hot on the right sides of the outlet? (Shooting from the hip)
Don't even have a damper...
Opps my bad... Trailer rating is 13,400 and 20,000 for GCW.
Very very rare we stay in RV parks. If we do its for a short period of maybe 2 days tops. The rest of the time the RV used solely out in the forest of Idaho so I'm really not to worried about filters and such. Typically 50 gallons of water will cover us for 3 days tops. That getting a least 1 shower a piece between MoparMom and myself. On my truck I've got a trailer rating of 13,600# or GCWR of 20,000#. I tend to watch that more so. I'm finally getting the RV setup the way I like it. She bit heavy but I'm liking it. I'll go back through the cabinets and clean up a bit more.
Disassembled A Bosch Vp44 Injection Pump
Hua?? DAP $995 NEW PSG - http://www.dieselautopower.com/product-p/sovp44.htm Vulcan $999 NEW PSG - http://www.vulcanperformance.com/Bosch-VP44-p/vp44.htm BC better knock the prices down lot more to even come close. Also why would I buy a used PSG unit when I can buy NEW PSG unit for less! BC - USED PSG $1196 ??? http://bluechipdiesel.com/products.html
Weird Engine Grunt Maybe Timing?
DAP sells "tapped" injection pump warranties...
