Truck has random misfire when hot
Do keep in mind the APPS sensor will not create a misfire. This will only possibly correct the P0122 code. As for the misfire hot that would be still be between the VP44 and the injectors but most commonly the injectors more so.
Truck Not Running Right
Good point I've seen people screw up and crush the key thinking they had it lined up. This offset might cause issues and run poorly.
RockAuto.com cab size question - extended cab vs quad cab for headliner
JoAnne's has headliner material that you can buy in bulk. Different colors even. Just need to clean off all the old stuff and the spray contact cement and lay the new stuff down and let it set up in the warm sun. I'm lucky so far mine is in good condition yet.
Nope the wire is good. If the ohms were greater than 5 ohms then the wire would need replacing. That small bit of resistance shouldn't pull the voltage enough to set codes. Being even stock you can be as low as 0.4 volts at idle and still pass. I would try a different APPS sensor if possible first before considering the ECM. Even when that time comes I would say to call @Auto Computer Specialist and have them look it over and verify.
Compound Turbo install complete
Strange how someone like me is running +150 HP DAP Injectors (popped at 320 bar) and Quadzilla tuner on a stock HX35W (54/60/12) turbo and towing my RV (8,100 pounds) with no EGT's issues all the way to Bridgeport CA. from New Meadows, ID.
First off the top on the injectors are you running VCO or SAC tips? I've SAC tip crack rather easily. I would pull them and inspect the injectors for cracked tips. I've seen a set of 140HP injectors in a 12V crack a tip in less than a 1,000 miles. Then pop pressure that gets too low will cause it to miss. When it starts dropping down in the 280 bar realm it can start a miss at idle hot. Just talked to another member just a few days ago and found out he sent his injection pump (VP44) in for testing and found out the PSG had issues and there was no timing advancement, and didn't throw a P0216 code. After having the injectors re-popped back to 320 bar (custom set) and having the VP44 replace the PSG and calibrated again fixed a bunch of his issues. As for the P0122 most likely the APPS sensor that failed but... Wiring wise to make it simple with both ends unhooked you want 0 ohms from end (APPS) to end (ECM) for wiring. Then the other test is red probe to the wire and the black probe to the block or battery ground. It should be infinite ohms being there should be no wires shorted to the block. This will get you pass the Dodge FSM stuff that is confusing.
Sad... I wonder what that headliner actually fits without the cutouts for the rear doors? I know LMC truck has the headliner for sale as well.
1999 Dodge Grand Caravan
I've got a fur baby for the back bench. Loki, @Honey Badger dog seems to love to go trucking with me anywhere I go and love to guard the vehicle. Boy he gets mad when someone comes too close to the vehicle.
Agreed...
The worse part is the amount of water splashed everywhere. Other than that the old shampoo and soaps all rinsed out, all the dirt washed out and the seat dried in just a few hours. Yeah I used a shop vacuum to draw out the most water as possible. Even the driver seat and passenger seat were washed in the vehicle and dried within a few hours. I was driving it the very next day and not even damp. The seat bases of the seat you know how they seem to get sticky and hairy looking from spilled drinks or just dog hair sticking to stuff. All that washed out pretty quickly and look like new. Funny how you clean up a vehicle then drive it later... It feels like its running better and now I want to invest more effort into this little 4,200 pound mini-van and make it my run around rig.
As for the wood I've got some yet to be processed to see where it gets me too cord wise. Then I can see if we have enough or how much more I need to get. As for Minnie it's a good shopping rig being you can really pile in the groceries and supplies for the house. Does rather well for MPG just depending how you drive it. Drive like you got an egg under the pedal you can touch 30 MPG. So this is why I'm starting a story for Minnie I'm going to do some basic mods and some repairs.
Took my Sunday and did some work on Minnie. New headlights, LED bulb coming in a few weeks. I got aggressive and empty the Minnie out and started power washing the carpet. Boy it ran all kinds of weird brown colors. Used a shop vacuum to draw up the excess water. Also power washed all the seats, really good brighten them up a bunch. Then 5 gallon bucket of simple green and hot water and washed the inside down. My Armor All is old didn't work too good but it has some shine on the dash. Then power washed the entire body getting the black mold off the roof. Minnie cleaned up nice still has a few stains and a chemical burn in the carpet. Her she is now.
Delayed start - longer turnover.
VP44 keys are numbered and calibrated to the pump. There is a article with the part numbers for the different keys which you normally buy from Cummins not a parts store.
endless NV5600 problems.
Transfer case in neutral the transmission shouldn't spin. Also the oil pump in the transfer case is driven by the rear driveshaft. For what I know of the NV4500 even in neutral both upper and lower shafts spin when towed.
Help With Engine Load
Nope it will be fine for a test.
Like I suggested you might have to consider that Allison being your load.
Now you know why I never buy prebled systems. Very low chance it's not got air in the system between manufacture, shipping to a store, you buy it ship it home and expect it not to get air back in the system. Just temperature changes during shipping can draw air in.
Oil coming out of intake horn/grid heater spacer..
I would pull the entire air system and wash everything out with solvent and air dry. The only oil source is a failed turbo. The only reason a turbo would fail is not properly cooled off before shutdown or dust collecting on the compressor wheel and it gets out of balance. Remember turbos spin at a very high rate like 15,000 RPMs or more depending on fuel and turbo size. Dust problem typically from washable filters like K&N.
Pull the entire hydraulic system out and hang it by the reservoir and pump the slave cylinder. Quickly in, release slowly. You cannot bled in the vehicle because the line has a high spot that gathers air in.
I really don't like prebled clutch hydraulics being 80% you have to rebled again. Then most misadjust the pedal rod length. I typically use NAPA master & slave separate and works 100% of the time. As for that thin MTF it tends to wear out syncros faster than something thicker. I'm also using brass syncro allows thicker lubes, but still 1st and 2nd are carbon fiber syncros. No problems all the way down to -40°F with Mobil 50 SAE trans fluid which is 90 weight gear lube. Most of my trans issues was wear of the hard facing from using that factory Mopar fluid 75W-85 which is like 10W-30 engine oil. Now ive had most all the gears replaced from hard facing wearing out and breaking teeth.
Quadzilla economy towing tune
I wish I had more trailer time to test. I've only done the trip to California but I had high wind the whole trip. Mostly about 8 to 9 MPG because of wind. The only other time I've tow my trailer was up to Burgdorf, ID but never got a MPG. Also all up hill. So there is no good data to say it actually economy tune.
99’ 24v Alternator Went Bad, Possibly Fried PCM/ECM/VP44?
PCM does not control anything on the engine. Only charging, transmission controls, and a few minor functions. P0216 code just means the ECM commanded a timing change and the VP44 did not change in the allotted time. Yes this does mean the VP44 should be replaced. Now if you had other codes then might change the outcome.
I lost my first VP44 at 50k, stock fuel system with only 7 PSI. This was the start of the website and the very first article. I installed a AirDog 150 shortly after that VP44 failed and kept 14 to 20 PSI that got that VP44 to last 243k miles. Still going on this VP44 at 451k miles. So in nearly half a million miles only installed two VP44. With the stock filter in place I'm polishing my fuel through the AirDog and the stock filter. As for the P0216 code it's more lubricity than fuel pressure. The piston galls up and sticks or seizes up. 4 ways to kill a VP44 1. Low fuel pressure even the Dodge FSM states 10 PSI minimum. 2. Low fuel lubricity Bosch states <460 HFRR or less, US fuel is 520 HFRR. 3. High AC noise from alternator. 4. Poor filtration.
1999 Dodge 2500 4 wheel drive/ Electrical Drain
Addon. We unplugged the PCM and central timer and 50A battery fuse. Draw is gone. Plug in any of the above the draw is back. So I'm assuming PCM and central timer have issues. Another addon... just talked to the customer and just going to put a cutoff switch.
I've been helping too. It's got the draw on the 40A trailer fuse in the PDC. As mentioned the trailer brake controller has be replaced. Then we separated the trail light loom and no change so the draw is in the cab.
