something wrong with my truck?
What was your IAT temp? If you don't know what was the temperature outside during this time?
roller coaster temps here!
I've also seen those kind of weird swings here in Idaho go from 85-90*F weather fighting forest fires to 32-35*F and watching it snow on your fire make you really wonder.
So for with the RV275's and +50HP injectors you can make some seriously good MPG's. Nice power increase without being too wild and smoky.
Leaking vac pump / ps pump mount flange
If I remember right I think its just 2 bolts. You should be able to pull the unit back to change the one gasket.
47RE T.C. has trouble unlocking
I tend to think the same thing I would look at the solenoid and see if its sticking.
Sourcing a fuel pressure sending unit
Alarms and limits of the Edge unit are just a big PITA. I typically suggest to most to turn all that stuff off to prevent problems.
Harbor Freight Contest!
Hey Gang you might want to check over at Diesel Truck Site for there Harbor Freight Tool contest. http://www.dieseltrucksite.com/showthread.php?t=961
Getting ready to replace heater core, question about AC Freon
Yes. Slide the white collar up as tight as possible and then lightly twist the line back and forth. The rubber o-ring will tend to stick in place and need a bit of twisting action to get them started sometimes.
Alligator Diesel in Northern Idaho sells a ISSPro Fuel pressure gauge for about $43 bucks. Never did like electric gauges.
Flashing wait to start light
Should not have to do the APPS ground wire mod. Also if this is correcting the WAIT TO START issue you have a bad ground for the ECM.
Big Buddy Heater
Exactly what I got here for indoor use. Then I got a torpedo style for the shop...
Tire Prices!!!
Just for fun I stopped by the tire shop and got some quotes of tire prices... LT285/75 R16 Cooper Stampede A/T $896.00 LT285/75 R16 Cooper Mud Claw M/T $1,064.00 LT285/70 R17 Nitto Crosstek $1,188.00 (50,000 mile tire)
It would do the job but the problem is as you vent it wildly like that now you got to drain the oil from the system and remeasure it. Because you have no idea how much PAG oil has now been blown out of the system. So if you have manifold gauge set and a vacuum pump you can slowly and controlled vent the freon without venting much oil from the system. Too little oil will damage the compressor. Too much oil will put excessive strain on the compressor.
Big Buddy Heater
We got a Big Buddy heater as well for a fall back heater source in case of wood stove issues (chimney plugged up, lack of wood, etc.) I've never used one through the night but we've used it for a about 1 winter chasing the bitter cold mornings and then shutting it down. No issues here. Like its also nice for the shop for those day I just need some quick heat and don't want to fire up a wood stove. Also have a torpedo propane heater as well.
WARNING! There is roughly 90-100 PSI in the system if you release a line it will exploded with freon and oil. I typically just use a manifold gauge set and vacuum pump and draw a vacuum on the system slowly. Opps... Looks like I'm missing a bit of artwork from the old site yet.
Tank selector valve??
3 Tanks? Wow that is a rare truck. Even my old 72 was a dual tank truck with electrical solenoid valve... Multi-tank truck are rare any more.
The only thing is you need the dealer DRBIII tool to flash a used ECM or a new ECM because they are sold blank.
High Idle Kit Is Here
Yes for a A-pillar pod or steering column pod. Just the overhead console is too far on this set of leads. Also Ed has informed me he will be making a version to install in the over head console. (Coming soon)
OIl consumption issue
I personally don't get wrapped up with all the hype of synthetic oils. I look at what standard the engine needs to meet and for lubrication and give it that. So if the API Standard calls for CI-4 or CJ-4 engine oils that what it needs. As for weight of oil this gets rather messy but the first number xxW with the W stands for winter or (cold start) this is viscosity the oil will behave like at cold temps. The second number is the viscosity of the oil when at normal operation temperature. More here. (Attached file) engineoilguide_march2010.pdf
clutch slipped
Now that you making me think a bit I've got a friend that has a 1992 Dodge that had a really bad slipping clutch but come to find out it was mostly caused by a leaking tappet cover gasket or valve cover gasket. Once the oil leak was stop the clutch slippage problem seem to go away as well.
Merry Christmas to All
Suggestion send them to Dorkweed he's another fellow bird hunter...
Dave it looks like you having a time of your life there... Christmas came and it went here very quietly. No snow really. But it was a very quiet Christmas here.
With 3 Cylinder mode if you trigger it you can flip over to MPG mode shortly after triggering and allow it to finish warming up. Since 3 cylinder is not a hled mode you can flip back to MPG at anytime. It only 6 cylinder mode if you wanted to hold the high idle extended period then you would have to leave it on 6 cylinder.
Merry Christmas all... So what are you all doing for Christmas day and what kind of gifts did you get? Just a nice quiet day out here in the mountains of Idaho and cold morning temps to kick of the day.
Suggested to constant +12V power to alert you that fooler is on and should be switched off. Or you can have it on the key so it can be left in a fooled position without the light always burning. Or... Completely ignore this wire and not hook it up and no light will ever come on. Your choice. But let me tell you that if you opt for constant 12V it will take many many weeks to wipe out a pair of batteries. I leave my cellphone charger in the truck and its got a bright blue LED that glows anytime the charger is plugged in and no issues with that. So I doubt there is any issues with high idle tiny LED.
