Motor Racing Away In Abs Module..
ABS module burned up. Rather a common issue where the electronics switching of the module burns up the controller of the pump motor. Just for safety sake I would double check the alternator AC noise levels since a electronic device failed. But I look like now you need a ABS modules and a set of ABS sensors.
Big Buddy Heater
Glad you are OK Hex0rz. Little things like that can ruin a whole lifetime. Even like the Big Buddy heater I tend to still shy away from indoor burning heaters that are portable and not exhausted to the outside primary heating. I would use one if need be to warm the house up but I would rather use a fireplace than a propane heater.
Extreme Low Fp In 0 Degrees
Yes it might be true that the second fuel filter with heater doesn't do much good but as long as the fuel return to the take is above gel point it will aid in preventing gelling from occurring. The winter front idea will keep a warm pocket of air in the front of the truck. I've made mine from a old aluminum road sign. works good on both the 96 Gasser or the 02 Diesel.
Brake Caliper?
Time to pull the drum off check the shoes and hardware. Then put the drums back on and adjust up the shoe slack manual till they lightly drag. I normally don't rely on the auto-adjusters at all.
Rear Brake Issues
On my 1996 Dodge Ram 1500 its also a rear drum braking system as well. I don't rely on the auto-adjusters to do their job I just make it part of my maintenance routine to check the shoe slack and adjust them up. Just only takes a few seconds. When rotating tires I'll take the time and pull the drum off and inspect the shoes and hardware for damages.
2014 Deep Freeze
Still without snow. But been cold up here as well floating between 0-20*F,,, Might see 30's for a short bit but not enough to thaw the ic around here.
Brake Controller - Dash Panels?
Mine also came with a blue plug pigtail for the brake controller and all I had to do is wire my controller to the pigtail and plugin.
2002 Cummins Fuel In Engine Oil
Yes sir. 14-20 PSI is a good normal range of operation. Basically give you a 6 PSI swing area for fuel pressure drop. There is absolutely no reason to exceed 20 PSI it doesn't improve performance nor does it keep the pump lubed or cooled better being the return line is smaller than the supply line.
Won't Start, 1693 Code
Could be because of lack of fuel pressure or gelled fuel plugging the pump up.
I kept my stock filter and fuel heater for this exact reason because even slightly warmed fuel is better the extremely cold gelled fuel.
Ticking noise from motor all speeds
Nice to see other family members helping other out here. So then I would suggest having the injectors pop tested and the valves adjusted if they haven't been done yet.
Shut it down. Anything below 10 PSI is going to cause VP44 failure and your fuel is most likely gelling up.
Not always. Just like the CR Engine they don't skip or miss when they are stuck open and no change in smoke either. The only way to tell is to pop test them on a bench.
Quick P0336 Question...
Non-generic P0336 error code definition. http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/59-obdii-error-codes/175-p0336-crankshaft-position-sensor-signal Crank senor also controls the alternator to so watch your battery voltage.
There is only a few places where few can get back in. 1. Injector body O-Rings 2. VP44 front seal 3. Stuck Open Injector So I suggest you pull all 6 injections out have them pop tested. While they are out you can replace all the injector body o-rings. As for the front seal of the VP44 typically that will rupture for pressures in excess of 20 PSI some get luck and don't have a issues and others don't have any luck.
VP or something else??
Well both Vulcan Performance and Diesel Auto Power sell pumps with NEW electronics for much less the Blue Chip.
2014 Deep Freeze
At least I got a rise outta ya...
2014 Deep Freeze
Florida??? Block Heater??? I won't even think about a grid heater down to +32*F...
Glowshift Guages
I got lucky when I bought everything. DiPricols are still going I only had the boost gauge loose the screws in the face. Fixed that myself. AirDog 150 still going no issues. Edge Comp only had one warranty claim and still working on the box I got.
2014 Deep Freeze
Just like going down to the guest house the house was barely 35-37*F inside with 22*F outside load the 2 stoves up (house and shop) and the splash a bit of diesel on the wood and light it with a match. Another way to light a fire quick and fast without kindling.
Glowshift Guages
To bad DiPricols went out of business.
2014 Deep Freeze
That's easy... Use a weed torch it'll get that stack to draw.
2014 Deep Freeze
Thankfully it only +21*F this morning here. Still no snow on the ground. This has me worried about water for this coming summer. I'm used to seeing at least 2-3 feet of snow by November typically we seen 1 storm that drop a total of 6 inches and then it stopped and that was it. I keep seeing forecast for snow or rain but it never shows up.
Edge Products Or Actual Guages?
I tend to find that a analog display is easier on the eyes being you just get use the direction of the pointer and know where everything is at pressure wise or temp wise. Digital displays are nice for absolute number but you tend to lag longer looking at digital displays than looking a analog needle. Digital with absolute numbers make it great for diagnostic reasons but analog is better for daily driving. Old school trick is take a rotate you gauges so your red line of the gauge has the pointer straight up. This doesn't look very eye pleasing but for racing world it works awesome because at a quick glance you can look for any needles pointing up knowing that you hit your redline of that gauge.
A Great Way To Gardening...
Gardening here is really difficult. There is couple of problems. 1. Animals. If you just plant your garden in a open piece of ground then every deer and what not will come and eat it for you. So now oyu must fence off you garden and the fence has to be about 6 foot tall. So we tend to garden on the deck using flower pots and the deer typically won't come near the house. 2. Only certain thing will grow here because of the ground, temperature and short growing season. Like corn is a no go it will not mature quick enough. But now radishes, lettuce, herbs, potatoes, wheat (no comment from Dripley!) all grow really well here.
