  1. Well in the current configuration (unhooked wastegate) its going to perform poorly as it reaches close to 20 PSI its starts to defuel and fall on its face. Not worth the effort. Like said above do a full Edge Comp and be done. Fully adjustable in the cab and will produce a full 32-35 PSI of boost with a Edge Products boost elbow. (typically supplied with the Comp).
  2. You have to set it up all over again and start marking your threads you want notices for. Sorry to say the two softwares are not compatible for notifications. I think you might want to extend your oil changes. In the owners manual its 7,500 miles for oil change. I'm changing at 10,000 miles. Might save you some money to change at specified intervals...
  3. No kidding Wow! http://www.speedhut.com/gauges/Boost-Gauges-2-1-16-inch/1:12|37:1
  4. Be careful there. Once you start adding fuel it doesn't take much to over spin the turbo. I would highly suggest getting a boost elbow so you can set the boost pressure. Rather cheap at about $10-20 dollars typically.
  5. No it shouldn't... But I suggest against any washable media filters.
  6. Stock boost should be roughly 18-19 PSI typically. Might check the wastegate for sticking...
  7. Could you post a web page link for us?
  8. I Agree as well BHAF is better... Also optimal IAT for MPG numbers is about 100-140*F so cold air is actually counter productive for a daily driver.
  9. I'd talked it over with Ed Grafton about the high idle stumbling out. We think it could be grid heater related, fuel injector(s), or possibly a VP44 issue. But these are just educated guess without actual testing.
  10. There is only 2 thing to make a diesel engine fire. Compression and fuel. So if the compression is weak or the fuel spray is poor then the poor performance will be noted at cold operation. It actually a 56K ohm resistor is what I use. But anything between 56k ohm and 100k ohm will trigger it. But the biggest thing I keep think about is the serve timing rattle.
  11. What is this term I see using more and more "Tuning: MY03 pistons and BBi Stage 1's in a MY05 truck." MY is that a term for a model or actually "My Truck"?
  12. Any flash work done by the dealer make sure to unhook the Edge Comp (or any enhancements) before the DRBIII is used.
  13. Ummm... No that's not normal. Any enhancement boxes, programmers or both used? Excessive timing is that hard knock as the engine switched over to 3 cylinder mode and the cold intake the timing advanced hard. I also noticed you had a un-even idling speed even on normal idle I would like to ask what injectors you have and have they been pop tested?
  14. Write will be on hook up and diagnostics. But no design for do-it-yourself... As for connections there is none that will affect the Edge Comp It hooks to the IAT sensor and the ECT sensor which neither sensor the Edge Comp even uses. No. The dealer flash and a smarty flash are exactly the same its just dealer charges for their time where a Smarty is free. All the MPG part does is fool the manifold temperature upwards to 143*F this aids in bringing the timing back to a usable level most have reported at least 1-2 MPG gain with it in cold weather Winter fronts and BHAF help even more so.
  15. As far as what I remember both DAP and Vulcan telling me they get there pumps from Industrial Injection. I just did a VP44 pump and forgot to look at the box it came in.
  16. I have the rare chance to get to use them but I've never had any issues other than the spit back it can do. Lot of time the fuel is flowing so fast and foams up the tank pretty good and when it rushes back out the filler neck it can make a huge mess. Then if you trying to top off it tend to be really hard to flow slowly to top off the tank. BURP! Again down the side of your truck.
  17. Another picture of the faces and mounting options... Cubby hole, Gauge Pod or Flat mount to a drilled hole...
  18. That's for the LED function. If you want you can hook it up to keyed power or +12V for the LED to remind you that MPG mode is on...
  19. I just found the gauge pod version... Buried in the box...
  20. Here is the link on the DAP... http://www.dieselautopower.com/SearchResults.asp?Search=high+idle
  21. Best I can say is contact DAP and find out...
  22. Update 10/15/15! The Mopar1973man.com Cummins High idle switches are for sale again in the Forum store
