  1. Even on a cold winter day I can hold 193-195*F worth of coolant temp and very steady.
  2. Should never increase fuse size to over come a problem this will result most likely either in melted wires or a possible vehicle fire. If the fuse is blowing out there must be something causing a over-current condition. Pinched wires to ground, locked rotor in the fuel pump, internal issues to the pump motor. Etc. Should always use the same size fuse or smaller. This way you never end up with a vehicle fire or mess of melted wires.
  3. Manual NV4500 hold 1 gallon and so does my rear diff. Yes I've extended my interval sometimes up wards to 40-45k miles if the fluid was not dark yet. Like on the 1996 I just extended them as well the fluid is still honey colored when I last sampled it. (Mobil Petroleum 80w-90 GL-5). I do tow but not right at GCWR of 20,000 pounds but 16,000 to 17,000 is pretty dang good pull when you start hauling up and down grade of 16% in the mountains here. My intervals are based between color, contamination, and mileage. If color and contamination but are good then push the mileage up another 5k miles. If the color or contamination is getting poor skip the mileage part and dump it now and change.
  4. G107 is located behind the starter and bolted to the block of the engine you can't visually see this ground till you remove the starter.
  5. From the end user perspective its a bit different. Most get the idea its synthetic I never have to inspect the fluid at all for 100k miles or even worry about it. This is one of the common down falls. So now the end user changes the differentials fluid tops it off good to go 100k. As long as its not leaking out the owner is happy. Opps... Bad thinking. So many times I've open up differentials around here found them overly contaminated in form or other. Just because its synthetic means you still have to do the inspections of the fluid level and color and check for contamination of the fluid.
  6. Thank you for stepping forward. I'm sure there is others here as well that appreciate the leadership for spiritual matters.
  7. Not sure. Thinking outside the box. I would have to say the CEL light is tripped and the instrument cluster was told the tach signal is faulty with the P0336 code and so the cluster is no longer reading the tach till the P0336 code is clear or dealt with. Remember the instrument panel has its own software like the ScanGauge II but also has its own rules it has to listen to as well so in the cause I would has to take a educated guess at the software holding the tach off.
  8. Ok. So verify there is power here at the yellow/white and black/white connectors. You'll need need to bump the stater to get power flowing for this plug. The first key on pump bump doesn't matter nor does it mean anything. It after the ECM sees crank signal and what it does after that.
  9. That's a old school scare... When you buy a oil pressure gauge it comes with the very same nylon tubing kit and your hooking up 0-80 PSI oil pressure line from the engine. There is never been threads or even a discussion on any of the diesel site of a direct plumbed oil pressure gauge blowing out in the cab. But now post about fuel leak in the cab its a major problem. "Oh my gawd the sky is falling"... But what about that direct plumbed oil pressure gauge its still direct plumbed to the engine? Now with mine its direct plumbed as well with the needle valve and barely cracked open if the line was to crack or open it would barely drip because of the needle being closed as far as it is. Also if there was a failure just close the valve problem contained. As for spraying out fuel you'd have huge issues with 80 PSI of unrestricted oil pressure! As for protecting your install just use 1/8" air brake line is burst rating is some where around 600-800 PSI and this is most commonly used on big rig truck for oil pressure gauges too. (Food for thought)
  10. Yes. There is a limit to all flash programmers. They have to work within the fuel table of the ECM and its limits. Hence the 60-65 HP Limit because it doesn't expand the fuel table beyond 20 PSI of boost. It just uses the last known figure on the table. Here is a example of what I mean. So the red area typically would be your defueling and error code range. The Smarty converts these values into working map. But if the truck operates above these value the ECM just uses the last known value of the table because it can't see beyond that. It also has to play by all the rules of the ECM and VP44 software. This why boxes like Edge and Quadzilla are so popular. Because now when a Edge Product gets to the end of the ECM fueling table the module takes over and calculates its own fuel map above and beyond the ends of the ECM. Since the data would cause a error for sure on the normal CANBUS it fed into the VP44 by the wire tap. This way the module can module the timing and fuel pulse length by reshaping the pulse.
  11. I normally use just plain old clear silicone in a caulking gun. (RTV) stands for Room Temperature Vulcanization...
  12. I see Dripley took my clue. I ran till 30k miles and didn't even look dirty for fuel filters.
  13. You could download a service manual and get the procedure on how to do it. http://forum.mopar1973man.com/index.php?/topic/7157-file-downloads/?hl=downloads
  14. Here is the brake pressure test gauge by Summit Racing. Here is the boiling point information http://en.wikipedia.org/wiki/Brake_fluid
  15. I say anytime you drop the transmission pan you should always adjust the bands and inspect the condition of them as well. Foolish not to adjustment them while the pan is down.
  16. Yea... AH64ID is right. 14-20 PSI is optimal. 10-14 PSI is marginal. Then anything below 10 PSI is damaging. It's like saying the Cummins engine will function at 10 PSI of oil pressure at idle and 30 PSI at 2k RPM's. So how long do you expect the engine is going to last running at bare minimum oil pressures?
  17. Personally I don't see any reason for synthetics lubes but use standard 80w-90 GL-5 gear lube for my standard open differential axles. If you have a Limited Slip then you have to consider lube with the friction modifier or get buy the friction modifier separately. Being that petroleum lubes have done a excellent job up to 224k miles and no failures and excellent MPG's (Highmark at 27.2 MPG last summer).
  18. Remember if you using a exhaust brake on the stock turbo your going to be stuck there with the stock turbo unless you upgrade to a inline exhaust brake. With my +50HP Injectors and Edge Comp I'm pretty close to limits as well EGT's and boost wise. So I would say Wild and Free is close to the mark as well.
  19. Like on the Edge Juice the setting is where full defuel is at. So if you set at 1,200*F then it start defueling at like 1,000*F and tapering off till it gets to 1,200*F and at full defuel. So just like a limit on boost set the boost limit like at 32 PSI its start defueling at say 22-25 PSI and works it way to full defuel. So now if you had both set up now you would have two separate defueling curves affecting the upper end power. Once again its best to just disable all limits and alarms.
  20. You could drill it out while the engine is running then the pressure of the exhaust blows the chips back out and the twist of the pull the chips up as well.
  21. Right on. We'll finally find out what's inside a VP44 and get it posted up on the site with LOTS of pictures.
  22. Still kind of have to giggle to myself. Different world where I live. First of all you have to have a functional transmit and receive system going. There is no cell towers in my area for miles and miles. Like even our fire radio don't even work in certain areas because of the metals within the mountain. CB Radios are no different. So good luck for NSA they would have to be parked on the highway with a portable tower. Now I could see something like Spokane area and CDA being a issues because there is towers everywhere. Even with 3 radio towers transmitting at way more than a cell tower I cannot transmit from my handheld to Grangeville, ID for a fire call at the house I have to drive to the fire shed pick up the fire truck and still keep driving for another 5 miles to get good signal. This is true story. Even GPS signal out here is spotty because of the canyon walls and tree cover that's way SAR leader is forces us to drop the GPS and use a paper map mostly. Even the scare of the Smart Meter is not true down here because the signal can't get out of the canyon the power company has to still drive the highway and to get all the meter reading it just they don't have to drive in your yard. Even going farther. I've been studying on how hackers crack WPA and WEP WiFi signals and that doesn't take too much. Pretty easy I might say and gain much more information about a person. There is a sign over in LonePine, ID that is a huge warning sign stating, "All CB communication are null and void for the next 15 miles" This a warning for mostly logging trucks but the issue is the mountain absorbs the the signal. But now on the flip side when I leave the canyon yes I return to normal cell signal yes I can see being tracked. Be my guest your most likely find my truck parked in Ontario, OR Wal-Mart or Home Depot.
  23. More information and talk to the group that is in the know of it. http://www.smartyresource.com
  24. Another reason I'm trying hard to finish working on the site and close up the 2 forum back to private status again. Not easy re-mapping a security layout on a new software. As for cell phones and connection with law enforcement I'm really against it myself. I prefer to keep my privacy and location unknown to people. Another reason I really never got big on cellphones but I do own one but since the cell coverage is very limited I'm not to worried. Like Riggins, ID has about a 2 square mile cell coverage enter town on the south end you got cell signal leave town on the north end you lose cell signal that simple. As for Adams, Co Sheriff I've already been told a couple of time if some is to happen down here I'm basically on my own. The average response time to my place is going to be better than a hour maybe 2 hours depending. Even then they don't like coming into the canyon themselves because there is no radio signal nor cell service so they are on there own too.
