Only had it a week and,,,,,,,,
Best thing to do is take care of the weakness...
IAT and MAP sensor
Well since you can't get it with the DMM then use a live data tool and see what temperature your getting.
TPS question
If it driving normally and not having issues this means that for some reason the Quadzilla and Edge Juice can't see the APPS signal properly.
Intermittant "wait to start" light
If its below +30*F and the first start of the day I wait for the light. But any other time I just hit the key and go.
Leaking Overhead Cab Marker Lights
Hmmm... I bought the 1996 Dodge Ram 1500 back in 2002... It only had 112K on the clock. Now its got 148K so thats 3.6K per year... Compared to the 2002 that I bought brand new 20.8K per year with 208K on the clock.
You're a "Real" Fire Wood Burner if.........................
I think MnTom got this one... (1 point for MnTom!)
IAT and MAP sensor
Correct your high mark is outside plus 40 degrees so yes 140*F would be the highest you want. But you can play with 100-140*F and see what tinkles the truck fancy the most. Not all trucks and drivers are going to get optimal out of 140*F some might need lower. Remember this is rather still experimental being like mine works for my setup and driving habit but your driving habit and condition might be different.
M73M's Baby Picture
Ummm... Well as for the hair it won't last for me. I'm starting to thin a bit on top now but it long enough no one knows but the gal that does cut my hair. So enjoy it while you can.
Good one Tom...
I Hate My Post Office
Ummm... I've had plenty of "Govvies" as Rogan put it. When you work a wildland fire you put up with a lot of that BS. USFS is just as bad as the USPS...
No. That's a friend's kid...
1993 low power questions
Hmmm...Fuel supply pressure? 6-10 PSI is typical.Air Filter?Timing is possible but special tools are needed to set the timing.Injectors are dirty and carboned up?AFC diaphragm has a hole or tear?Boost leak?
IAT and MAP sensor
It not based on how cold your winters are. It based on what temperatures do you see in the summer time for IAT? So what your average summer temp +40*F would be a close guess to the size of resistor you want. Like myself I see 110-115*F in Riggins, ID quite often so 110 + 40 = 150*F. That would be my high mark temp. So typically IAT range 100-140*F for most people in the summer.
M73M's Baby Picture
Not for me... There still here.
High Idle & MPG Fooler
I'll have to draw up the schematic in my head on how to include the MPG fooler with the high idle setup.
Wow! I must a Redneck then with my saw sticking up out of the pile would in the back of the truck. Yes. No one I mean no one touches my saw for tuning or repairs... I will be the only one to sharpen my chain! As for me I like long wood... Also the Cummins has a second life of being a Cummins Skidder.
IAT and MAP sensor
Easier to pick out a resistor and stuff it in the plug. But remember this will disable the grid heaters. [TABLE][TR][TD=width: 50%, bgcolor: #3870cc, align: center]Temperature[/TD] [TD=width: 50%, bgcolor: #3870cc, align: center] Resistance[/TD] [/TR] [TR] [TD=width: 50%, align: center] 13°F[/TD] [TD=width: 50%, align: center] 56K ohms[/TD] [/TR] [TR] [TD=align: center] 26°F[/TD] [TD=align: center] 39K ohms[/TD] [/TR] [TR] [TD=width: 50%, align: center] 87ºF[/TD] [TD=width: 50%, align: center] 7.4K ohms[/TD] [/TR] [TR] [TD=width: 50%, align: center] 91°F[/TD] [TD=width: 50%, align: center] 6.8K ohms[/TD] [/TR] [TR] [TD=width: 50%, align: center] 100°F[/TD] [TD=width: 50%, align: center] 5.6k ohms[/TD] [/TR] [TR] [TD=width: 50%, align: center] 107°F[/TD] [TD=width: 50%, align: center] 4.7K ohms[/TD] [/TR] [TR] [TD=width: 50%, align: center] 112°F[/TD] [TD=width: 50%, align: center] 4.3K ohms[/TD] [/TR] [TR] [TD=width: 50%, align: center] 119ºF[/TD] [TD=width: 50%, align: center] 3.6K ohms[/TD] [/TR] [TR] [TD=width: 50%, align: center] 123ºF[/TD] [TD=width: 50%, align: center] 3.3K ohms[/TD] [/TR] [TR] [TD=width: 50%, align: center] 127ºF[/TD] [TD=width: 50%, align: center] 3.0K ohms[/TD] [/TR] [TR] [TD=width: 50%, align: center] 132ºF[/TD] [TD=width: 50%, align: center] 2.7k ohms[/TD] [/TR] [TR] [TD=align: center] 143°F[/TD] [TD=align: center] 2.2k ohms[/TD] [/TR] [TR] [TD=align: center] 148°F[/TD] [TD=align: center] 2.0k ohms[/TD] [/TR] [TR] [TD=align: center] 163°F[/TD] [TD=align: center] 1.5k ohms[/TD] [/TR] [TR] [TD=align: center] 173°F[/TD] [TD=align: center] 1.2k ohms[/TD] [/TR] [TR] [TD=align: center] 184°F[/TD] [TD=align: center] 1.0k ohms[/TD][/TR][/TABLE]
apps high side voltage
I'm not absolutely sure but I would say start at 4.00 volts and work your way up slowly 0.1 at a time till the code trips then you'd know the limit. When you do find this limit post back here for future reference.
Go big or go home... I went home big!Take notice to the 7 year kid standing behind the tree...
IAT and MAP sensor
All for EPA and CARB reasons...
When forest fires are a good thing... Lots of firewood now!
PSA Axle Wrap-don't put off addressing it!!!!!
Ouch...
That's call a FPCM (Fuel Pump Control Module).
IAT and MAP sensor
Different animal again. Because it first off naturally aspirated and number two the fuel doesn't require activate heat energy to fire the fuel it uses a spark plug to ignite the fuel. Then on top of that gasoline flash point is seriously low so its easy to ignite regardless of outside temperature. So now looking back at diesels you need glow plugs or grid heater to warm the air enough to even start it. Then your trying to fire the fuel on the active heat energy created by the cylinder compression. Then the fuel itself has to be ignited by autoignition temperature (compression) and not flash point (spark plug). So the colder the air gets the harder it is to ignite the fuel. So to compensate for this is why the manifold is pre-heated by coolant, grid heaters, and hotter thermostats compared to previous years since the 24V SO engine has the LOWEST compression ratio to all other Cummins engines at 16.3:1 (HO is 17.0:1) so the heated air is a welcomed sight. The autoignition temperature or kindling point of a substance is the lowest temperature at which it will spontaneously ignite in a normal atmosphere without an external source of ignition, such as a flame or spark. This temperature is required to supply the activation energy needed for combustion. The temperature at which a chemical will ignite decreases as the pressure increases or oxygen concentration increases. It is usually applied to a combustible fuel mixture. The flash point of a volatile material is the lowest temperature at which it can vaporize to form an ignitable mixture in air. Measuring a flash point requires an ignition source. At the flash point, the vapor may cease to burn when the source of ignition is removed. The flash point is not to be confused with the autoignition temperature, which does not require an ignition source, or the fire point, the temperature at which the vapor continues to burn after being ignited. Neither the flash point nor the fire point is dependent on the temperature of the ignition source, which is much higher. The flash point is often used as a descriptive characteristic of liquid fuel, and it is also used to help characterize the fire hazards of liquids. “Flash point” refers to both flammable liquids and combustible liquids. There are various standards for defining each term. Liquids with a flash point less than 60.5 °C (140.9 °F) or 37.8 °C (100.0 °F)—depending upon the standard being applied—are considered flammable, while liquids with a flash point above those temperatures are considered combustible.[1]
Expanded diagonstic P code list for the 3rd generation trucks.
Very close to completion of the error code listing but most of the engine codes are present I'm only short a few of the transmission codes.
