Dead Pedal
Good question?
Got my RV275s installed and WOW!!!
Wait till you throw it on 5x5. It a whole new animal. I'm playing with 5x3 and the torque curve is so aggressive now that a soon as the turbo lights so do the tires in 2nd and 3rd gears. :burnout2:DieselAutoPower has always been the best vendor with the best price I've seen.
Smokeless tuning
John, have you heard anything about UDC for 2nd gens? Ive not seen anything from Mads about the possibility of this, but I sure would love it if they did! The difference between Juice and Comp is toyz and gauges. The tune software is the same. 5 Main levels with 5 sublevels (3 defuel and 2 power).
Screening mouse access in Cirrus...
Wow. Back to the chasing mice again. There has to be something you could put up inside the HVAC or cowling that would deter mice from wanting to enter. I know the screen idea. There has to be something out there mice absolutely hate that you could put in the vents or something.
Firewood
Ok Gang... I've got a video clip of MoparMom stacking firewood. Now before you press play on the video remember this is a TIME LAPSE video and you might want to put down you coffee cup or beverage before you do. Things might get rather messy for your computer. Also I was on the other side of the pile creating a second huge pile of firewood so I was out of the video mostly. Oh yeah that trailer holds 1.5 cords to the top of the boards. http://youtu.be/V78Cs1W0jsM
Rubbing through steering wheel
This should help... http://youtu.be/28cdIPJwDC4
Smokeless tuning
ScanGauge II was re-calibrated again on the 5x3 so I'm showing true numbers once again.
Smokeless tuning
Well I know my truck came factory with 265's but I still thing they are oversized. Like my door tag shows I'm suppose to have 245's for a stock tire. Just like my 96 Dodge shows it stock size is 245's as well but came with 235's. But still in all 265's are just heavier than I need for my application.Yes. The Edge Comp modifies the ECM signals for timing and fueling based on boost pressure. So its modified through the CANBus an the wire tap. This is where I would love to have EFI Live or Smarty to make corrections to the timing more so than fueling.
Crank Case vented to unused fuel filter housing?
I gather concrete... :doh:Yeah then I would consider it. Like I got to spray a little Zep on the floor of the shop and run a mop over the spot.
Bleeding two fuel lines?
That might be true but the fact the fuel is already pre-heated on the manifold all it needs is a spark to ignite the fuel. You would have a nice un-hood fire. Personally I don't like the idea of diesel fuel pre-heated to 180-190*F which is well above flash point waiting to be ignited.
Had my 99 full bore fuel pressure said 0????
Volume and pressure stability. With smaller ID plumbing you get wilder pressure swings up and down. Mainly because Bosch VP44 injection pump requires 70% of all fuel to be return to the tank for cooling and lubing reasons. So this means even with a stock fuel system you would need a supply volume of roughly 70-90 GPH. So the stock plumbing is only rated for 75 GPH but that with 0 PSI at the Bosch VP44 Injection pump and 15 PSI at the lift pump. So the increase in ID of the lines aids in pressure stability so like on my truck I start at 19 PSI at idle and 17 PSI at WOT. With the old stock lines it would start at 15 PSI and fall to 8 PSI. So you got to remember the larger line isn't for the 30% being burned but for the 70% that required for cooling and lubing.
The solution
So who's going to start biodiesel plant? Oh that means someone has to come back to the main land for methanol. Sure make a lot of soap with the waste products.
Cold start and block heater
That why I will always suggest you at least try to get out of the blowing wind or park in a enclosed area. At leas then you heat is not wasted to extreme cold outside. Like both garages here are unheated so If the temp got down cold I would plug in the trucks while parked the shop. At least now the heat not wasted outside but heating a garage. 750W heater is still a heater regardless if it household appliance or a block heater.
Terrible MPG
I'm following the same MPG's basically with a small change in driving style.
Smokeless tuning
Well I'm now really going for the gold now. I've managed to reduce from 5x5 to 5x3 on the Edge Comp and keep 20 MPG now. Certainly different driving style is required. Now for those that are not owners of Edge products let me throw this out. Edge Comp and Edge Juice are both have the same in software basically. They both have 5 main levels and 5 sublevels. MAIN LEVELS [*]40 HP [*]60 HP [*]80 HP [*]100 HP [*]120 HP SUBLEVELS [*]33% of stock fueling/timing till 20 PSI of boost [*]50% of stock fueling/timing till 15 PSI of boost [*]67% of stock fueling/timing till 10 PSI of boost [*]Some Extra fuel at 0 PSI of boost [*]Full fuel and Timing at 0 PSI of boost Now you got to remember I got winter time temps, my oversize tires 265's, and the tune of 5x3. Now I've changed over to the 5x3 and continued driving like I did previously and saw the MPG drop to nearly 16-18 MPG range. I relized that the timing curve was not available with low boos that I normal see of 1.5 to 3 PSI which is well below 10 PSI limit of the defuel mode of the Edge. So today figure I change driving style a bit and see if I could gain it back. Since my trip to McCall, ID is all up hill from home to McCall, ID all I did was left it 4th gear (NV4500) and set the cruise for 55 MPh as usual. This put my tach upwards of 2,100 RPM's and boost about 7-9 PSI the whole way up. Seems to gain slightly on the way up by the time I hit McCall, ID I had just barely touched on 15.9-16.0 MPG on the ScanGauge II. So now light foot around town and scratch up a few more tenths of MPG. Then on my way home I used 5th gear let the truck just roll down hill basically. By the time I hit the yard I was at 20.5 MPG. This is still experimental stag and I'm going to continue learning and testing to see if I can get the most of this tune. More to come... PS: Oh... I forgot to mention that with this tune I've got way more torque now and been having trouble even with my 265's tires. In 2nd and 3rd gears I just got to plant the pedal to the floor and the turbo lights and so do the tires.
Low power issue with no codes
Ask AH64ID he's the site filter guru...
3 Things kill Bosch VP44 injection pumps.1. Low fuel pressure 10 is bottom line 14 is suggested minimum.2. Fuel Lubricity Bosch states fuel needs to be 450 HFRR or less. Today fuel is 520 HFRR3. Filtration should be as low as possible. Most stock filters ar 10 micron but I suggest 2-3 micron.
Really there is no big reason for the catch bottle really I drip so very little out in 2 months it not even worth noting really.
Error Codes P0602 and P1693
I've got that low pressure light on mine too (Cummins) but Cummins ow pressure light comes on at 3.5 PSI which way too low. Lower limit is 10 PSI and suggested minimum is 14 PSI. Unless you get a adjustable Hobbs switch and set it for 10 PSI. But I still would suggest pressure gauge over any low pressure light.
ISSPRO EV2 electronic FP gauge
It's a requirement for a snubber or needle valve. But I'm finding more and more snubbers fail to portect the senders. If your needle valve is setup properly it should take 2-3 seconds to rise from 0 to what ever pressure you got. Gauge should never jst snap to position this is a bad thing. As for sender location you want to be as far back away from the injection pump as possible but still forward of the last filter.
If it going to be parked for extended periods you might consider just pull the IOD fuse out using the clip.
Cummins 2500 don't start
A little run down about ECM and Wait To Start light...When the key is twisted from OFF to ON and you normal see the wait to start light come on. There is several thing that have to happen for it to light up. first of all you got to understand the ECM is just like you home computer. ECm had a PROM (Programmable Read Only Memory) kind of like your hard drive, processor, RAM (memory), etc. So when that key is turned on the processor reads the PROM into RAM (booting) and then starts the software. One of the first task is to check IAT temps and see if grid heat is needed. Well when the Wait to stat light is lighting up is typically because there is a issue with the internal RAM and memory errors. So booting process is slowed way down trying to write the information to RAM. Eventually it does out right fail. As for a cause I finding that alternator AC noise is a big factor to electronic life span on these truck. You might have the alternator check as well as batteries and battery cables for problems too. Being the ECM and VP44 share the negative battery cable for ground.
VP44 are know to fail with out codes. As for myself my first and only VP44 failure was a P0216 failure. Fuel pressure is too low you should try to stay above 14 PSI. So I would say its possible the VP44 is wore out from marginal fuel pressure.
mopar marine
The Mopar 426 Hemi will also be king...
Brand of tires?
I typically get about 30-40K out of set of tires. My biggest problem is dirt roads and exhaust brakes usage. I really good about rotation and keeping pressures in check. I know I've posted it before but here I got again... (axle weight / 2) / tire weight capacity ) x tire max inflation = suggested inflation pressure
