Fuel Pump power feed 98.5/5.9
You "could" direct wire the pump but it might create starting issues as well. VP44's injection pumps don't like the excessive pressure during starting. This why the ECM controls the lift pump and has a 50% duty cycle during cranking then when the key is released it flipped to full 100% duty cycle. Then there is a safety issue involved too. Back in the 12V relm all the pumps were mechanical so when you the engine dies so does the lift pump. But now with a keyed hot lift pump if you where in a accident and trapped in the truck the lift pump could still be pump fuel into a engine fire and be deadly. Hence why the ECM controlled lift pump so if the crank/cam sensor no longer sees RPM's the lift pump shuts down as a safety measure.Food for thought...
Transmission Maintenance?
All good suggestions...
What kind of mileage with Your RV
That's scary... I still wouldn't want to do it...
A New Low
I know this isn't quite right but the first though comes to mind is... Chinese BBQ pork http://t1.gstatic.com/images?q=tbn:ANd9GcQvRe2oHEvh2sqU5XOAKLaYDKXet3OBQPojHiVMjiii7AcaFcu-Xgym7ovz But that's hot mustard. But burns the same way... Still delicous!!!
Where is my oil going????
I tend to agree with AH64ID I think most of it going to be turbo on the exhaust side.
Air Dog Raptor 100 problem
Stock pickup and steel fuel lines are too restrictive need to consider upgrading all of it to 1/2" plumbing. I don't think so yet. I would finish up the upgrade with good 1/2" lines and it should settle down more. I would ditch the stock pickup assembly too and upgrade to 1/2" draw straw as well. If there is any quick connectors I would chop them out and upgrade to Push Loc's and JIC fittings.
The results of static timing
Interesting...
Well I'm going to have to double check up here next time I see a state police officer. The maximum lawful speed limit on interstate highways shall not exceed sixty-five (65) miles per hour for vehicles with five (5) or more axles operating at a gross weight of more than twenty-six thousand (26,000) pounds. So a triple axle RV would be bound by the law. Even though you might not meet the weight requirements. So just with that small part of it and the "or" makes it rather grey...
As for Idaho laws it applys to any trailer in tow be it a utility, RV or another vehicle. You might research the towing laws in your state. Like a clue for Idaho is Truck speed limit is towing speed limit. (65 MPH).
Hate to sound like the towing police but to keep you all out of trouble be aware there is towing speed limits for each and every state. Just because the post speed limits is 65, 75, or even 80 MPH doesn't your allowed those speeds with a trailer in tow. http://www.hitchemup.com/statetowinglaws.htm
Missing at idle. Been to 3 shops $4800 later...still no fix
As for the code here is the docs for it. http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/59-obdii-error-codes/229-p1690-vp44-ckp-sensor-does-not-agree-with-ecm-ckp-sensor
I would highly suggest a compression test before doing anything else. One of JLWelding mistakes...
Any info on the HY35?
No. But you will need a needle valve and set it up properly or you will eat the sender anyways.
Hard Start
Possible failed injector bleeding down the common rail making it hard on the CP3 to build pressure.
Inside / Outside Temperature Gauge
Mine just blew the blub out in it and now its a PITA to see most times. I'm going to carefully attempt to break the case open to repair it.
A New Low
:lmao:Get me a spoon load and big ol' steak. Yummy!
I'm getting 12-14 hauling my 31' Foot Jayco that weighs roughly 7,500# loaded with water and everything.
Little experiment with BLACK oil....
So how long till black now is the question?
Crank Case vented to unused fuel filter housing?
Huh? Explain yourself?
EMP
Cummins ISB engines have a air compressor that mounts in the vacuum/power steering hole. I got a guy in Louisana that is building a P-pumped 24V with a air compressor in a Dodge body. Yes. It does all fit under the hood. :wow:He's got to use a another means for a vacuum pump now but power steering and air compressor.
Question how are you going to prevent water from entering the bottle?
EMP
http://www.youtube.com/watch?v=36OkixH0sx8
ATF fluid and filter changes every 30K miles. Then adjust the bands. As for the lock up issues I just got the answer you want. http://forum.mopar1973man.com/threads/5937-Torque-Converter-Lock-Unlock-Issues?p=63884#post63884
Let put it this way... With my mod I don't loose enough have to add oil. But I do put a few drips on the garage floor. The problem with the factory vent its mostly panic or hard stops that slosh oil out that tube. That why the reverse direction of mine to stop that action as well as up and over the engine to force the oil to try and climb.
What Am I Waiting For?
If the outside temps are below +60*F and this is first start you should wait for the light. But if the engine is fully warmed up no need to wait just hit the key and go.All the WAIT TO START does it the ECM boots up and detect the manifold temperature if the IAT teemparture is below +60*F then the grid heaters are active for a pre-set amount of time. Then the light goes out after the time. If the IAT temperature is above +60*F then the light only comes on as a bulb check and go back off. How can you tell the grid heater pull the battery voltage way down where the bulb check doesn't.
