Will Not Start- VP44 Dead? Code P1688, P1693, P0237
P1688 - Death Code for the Bosch VP44 Injection pump electronic are brain dead. Replacement is required. http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/59-obdii-error-codes/227-p1688-internal-fuel-injection-pump-failure P0237 - MAP sensor voltage is low. http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/59-obdii-error-codes/167-p0237-map-sensor-voltage-too-low As for the P0237 do the diagnostic on it first. Also if you got any modules hooked to the MAP sensor unplug them at re-test.
Slow oil pressure on start up
Fleetguard filter here ans 1-2 seconds tops.
What fuel pressure do you run if you have a gauge?
Glowshift is considered to be a low quality gauge by some. But if you get a mechanical gauge and needle valve you'd be all set. But I don't think you can beat a $40 buck ISSPro gauge...
1.000.000 Miles Yet???
OMG guys...It's time to get in those thing and drive them.
My headlights are afflicted..
Interesting I didn't know you could force those bulbs into the headlight housing?
scan gauge
OBDII socket or a cord issue?
scan gauge
Both are equal in information. But ScanGauge II is suppose to update to a data logger soon the you can plug a USB cable and download to a PC. http://www.pureenergysystems.com/store/ScanGauge/USB.htm
Presentation
I went to to translator site...
Firewood
Mine is too wet... Practically dripping wet. I've got to have a good bed of coals and drop the wet stuff in with a few pieces of dry wood. I've only got 4 cords of dry wood but got 6 cords of wet. What happens when you work all summer on the fires and get back too late to split and stack it all.
Couldn't Help Myself
Drips Oil Drops Grease Everywhere Absolutely correct...
Time to replace both bulbs with a good pair of Silverstars...
Power is out...
Tidbit...When a tree or object is shorted across the lines the power typical will go out and come back on three times. After the third time it stays out. Now some thing interesting the power breaker for the canyon (from Riggins, ID to New Meadows, ID) is located in New Meadows, ID in the middle of town more or less. Now the local power company is in McCall, ID. They stock a few things for supplies but not much. So if it serious they have to truck down to Boise, ID typically and pick it up from the main warehouse. So now knowing all this I started out with a 4Kw generator years ago. Survived the 96-97 Flood of Idaho where we lost power, phone, etc. for over 14 days and longer in other areas. After that I talked the parents into investing into the inverter, solar panels, and the hydro generator. Now looking back I'm glad I twisted there arms and got them to purchase it. We've had this system now since 1998 so nearly 15 years now. Been through 1 set of batteries lasting 13 years. Like during the summer I typically limit the city down to 20 Amps. That means any load above 20 amps I have to provide for out of my own generation or batteries. Remember when I state amps its on 120 VAC not 220 VAC. (so 2,400 watts). That's all I'll take from the Idaho Power. So typically in the summer time the power bill is $30-$40 bucks. But come winter time, no hydro, and very limited solar, power bill jumps again. But now I've been twisting Moparmom's arm to replace most of the standard light bulbs with compact florescent. I'll have to do a video of that. But when I was out in the RV I fire up the little 400w inverter and plug in MoparMom's little lamp for the kitchen. Well the first bulb was a true 60w bulb and would eat two 12V deep cycle batteries rather quickly. So I popped out the standard bulb and got a compact florescence talk about a huge drop in amp draw. Then I've got the computer rigged for power management. MoparMom's goes to sleep. Mine goes to low power mode. So all in all I've walked down to the inverter and check the household loads and lot of the times in the evening it can vary about 3-7 Amps total loads.
Presentation
That's cool Rogan... I didn't know you knew how to speak Italian...
I always self adjust my light on a empty road and make sure my lights are aimed for the bulbs not a goofy tool. So when I'm done the low beam reach out a long ways but never hit road reflectors nor taillight reflectors. I typically cover one side and adjust the other.
Power is out...
Thanks... Eight 6V batteries 810 Amp/hours. http://www.trojanbatteryre.com/PDF/datasheets/L16REB_TrojanRE_Data_Sheets.pdf Would you believe I live off of 4Kw daily? My inverter is only 120V output (no 220 VAC). So I got a step up transformer for the well pump. Everything else in the house is converted to 110VAC. As for 3 things not covered by the inverter cook stove, oven, and the drier. Those are the only things not attached to the inverter. Geez... 10 gallons of gasoline would go a very long ways for me. Typical loads here are about 3-10 Amps 120 VAC. (360-1,200 Watts) Then spike periods is in the morning with showers, coffee maker, space heater, etc. Now we are pumping maybe 25-30 Amps 120 VAC. (3,000-3,600 Watts). Like today the power was only out a short maybe 30-40 minutes. My neighbor has a propane generator that totally autostart but there is lag time. Like my computer typical can withstand the burn out where MoparMom's typical shuts down. But the only thing I do is set the timer on the oven to 0 minutes and turn of the water heater. Soon as the buzz sounds powers back on and turn the water heater back on. I've seen power outages that lasted over 24 hours. No biggy. Just fire up the generator just before bed charge the batteries up. Shut it down. Then go to bed watching movies. The neighbor has to manually shut down his propane generator at night. Stumble around with flashlights. Just normal life here. Just like being in the RV just more room! Got you beat longest outage has been 14 days...
Presentation
Welcome to the family from across the pond. Hang around and do some reading and post as many questions as you want.
Power is out...
Here is a sample of life without power here at my place. Nothing much changes. http://youtu.be/LNBnCYm0vgE
MPG fooler question
I've also got the rheostat on my floor. I can adjust the value also I do have a Scangauge II.
High idle set up
Shibby over on CF.com suppose to be making them now.
Enhanced security.
Pick one...
MPG fooler question
I think Russ has a rotary switch with a few different values going.
Truck got stolen this morning.....I'm lost
Or the other fancy tool "Jiggle Keys" http://www.youtube.com/watch?v=24ZYZMva1e0 http://youtu.be/sjOtomfRPN0 Hence why the dog rides with me while I'm out and about. Then why my truck is typically stored in the garage behind a locked door. No wiring schematics needed... Just one jiggle key and get the door open then start the truck.
Enhanced security.
Poor mans tailgate security is to wrap a hose clamp around the slotted side and set up in such a fashion that you got to lay on your back and reach up to remove it. So when the tailgate is lowered the hose clamp is facing the bed now a thief won't be able to get it off.
Firewood
... or wet firewood. But that's all I've got is a lot of wet firewood trying to dry under tarps in the yard.
Use caution when installing Raptor 100
There is something to be said about adjustable pumps. :rolleyes:Raptor has been know for unstable regulators at times. Like my AirDog old school spring and check ball tend to go lower when then get goofy.
