Confusion sets in...
You've got transmission problems it sound like. 83% of throttle to hold 40 MPH running 2,748 RPM's... Holy Cow! That a lot of drag going on... Typically at 55 MPH for me is about 8-15% of throttle at 1,689 RPM's consuming roughly 2.4 GPH and load of 10-20% on semi-flat ground.
aux power
Temp fluctuation
Just yank that auto out and stuff a manual 5 speed in...
Edge Juice w/Attitude issues
Hmmm... Correct me if I'm wrong but the Edge module is under the hood too. I really do wonder if it either the module under the hood cooking or is the display cooking in the cab (A-pillar)?I know the Edge EZ had water issues with the module leaking.Edge Comp was the only series I know of that was fully in the cab. The Edge Juice went back under the hood. But thinking back I never heard of Edge EZ problems from heat. (Thinking out loud)
Smokers and Grillers Thread
Where is a slobber rag wipe up the keyboard? Oh, smoked meats and me don't last long at all.
Temp fluctuation
I would switch back to standard green or yellow coolant and see what happens... Would be weird to find out the coolant is a factor to wild swings..
I hate Pruis drivers...
No. I'm not doing maintenance this time.I'm going to stay mostly to my own fire station. They have already elected a maintenance person in Whitebird Idaho which is getting paid. Great for him. But at least I don't have to spend long hours working on trucks. All I got to do is report any issues to the Fire Chief and/or Chairman of the Board.
tires
Sorry to hear about your wife I'll keep her in my prayers... :pray:Reliable is a good thing to chase, especially when a family member health isn't good. Ok then look at it from another angle on the tires then. Look at availability and prices between 16 and 17 inch wheels. More or less why get something that might be difficult to replace or might cost more.
Fishing
Cut out Rogan... :drool:I love smoke salmon or tuna... Yummy... Thinking of that I got some in the fridge some where...
Valid point... I've measure dash temperatures as high as 140*F in the sun. That's why I moved the ScanGauge II under the dash because it would darken the LCD screen from just the sun. Since its moved no issues. Are you selling the truck?
Another 1689 dtc question
Maybe or maybe not... Depends on how hot the electronics might of gotten. It might be other things too. [h=2]Possible Causes[/h] [*] Wiring & Connectors [*] Fuel Injection Pump Relay Output Circuit Open [*] Ground Circuit Open Or High Resistance [*] Datalink (+) Circuit Open [*] Datalink (+) Circuit Shorted To Ground [*] Datalink (-) Open [*] Datalink (-) Shorted To Ground [*] ECM
(Sigh) The common display failure... It seems both Edge and Quadzilla both have the very same issues. The only suggest off the top of my head is check all wiring (disconnect and re-socket again). Slim chance that might fix it. Another thing you might try... I know the module is under the hood and might of leak water within might open the end and check the internals. Also this might be the cause of the low MPG's... Module was dying... :shrug:Truely sorry about the above post... :banghead:
Sorry... Didn't mean it that way.. But AFAIK this is a known issues with Juice modules from the beginning and I've not heard of end user fix for it yet.
Here is the diagnostics for the P1689 code... http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/59-obdii-error-codes/228-p1689-no-communication-between-ecm-and-vp44 But typically the fuel flow stops or slows to point he the pressure falls below 14 PSI the overflow valve starts closing and the cooling fuel disappears so now the computer on the VP44 (FPCM Fuel Pump Control Module) start losing its cooling fuel and the electronics starting getting hot. Yes. I know there is a P0168 code for over temp but in all these years I've never seen 1 report of it. http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/59-obdii-error-codes/155-p0168-decreased-engine-performance-due-to-high-injection-pump-fuel-temperature I consider the P0168 code worthless because you'll never see it.
Raptor 150 Died in Gellette Wyo.
I stopped by Harbor Freight and bought to 60 count boxes of fuses for like $4 bucks a piece on sale. These stay under the back seat...
tires
Remember I'm in a different class of road and travel... :wink:Flatlander's please don't come to Idaho...
Got my gauges in and swapped on the HX35 couple questions
I wasn't sure about the trans port your going to use so I typically suggest against directly inserting the probe in an port. Don't want to block a piston from moving or restrict fluid flow. So if you create a small extender with brass then I think you'll be OK.Like you I replace my silencer ring as well I wasn't to found of listening to the whistling turbo towing over steep grades with trailer in tow. Personally I would look towards a performance module like Edge Comp or such that give you control over your fuel. Because RV275 will boost fuel and power slightly but you'll still have no control to it other than your foot. It nice to have performance box for the day of snow or muddy roads where you can retard the fuel flow to aid in traction. Things to consider.
I know this isn't a solution but... All you eggs in one basket problem... :banghead: This is the one reason I will not upgrade to a juice. I'd rather have separate gauges for boost, pyrometer, fuel pressure so the chip dies I just unplug the Edge Comp and keep rolling. In your case unplug the Juice and go blind you now lost your gauges too. Being you got military background you should know to keep a backup plan... As for the solution all I can say is call Edge products and see about getting it sent in for repair. http://articles.mopar1973man.com/mopar1973mans-dealer-contacts/44-manufacture-contacts/26-edge-products
Not to hijack you thread... But since its fire related...What happen was I had a lightning strike fire right across from my house and so I got smart grabbed the scanner and proceeded to listen. There is a fire station less than 1 mile from me. Guess what? There is no one there to man it any longer! The responding people came from Slate Creek, ID nearly 40 miles away! Plus USFS from McCall, ID 35 Miles away. I'm like OMG! This is a complete mess! I call the guy I've been working with try to help him out he didn't even know there was a fire in progress (no radios or pagers)! 2 Days later USFS and 1 man from Station 5 (Slate Creek) put out the fire.So never the less I made a few more phone calls and talked to the Chairman of the board and the acting fire chief (temporary). I was correct there is no one to respond from Station 1 which is 3/4 of mile from my house. I told them if they reinstate me back to my old rank (Station Captain) and allow a second man to join under me we'll man that station. Which getting reinstated is becoming a slightly administrative problem.So never the less I've been work with Station 2 and Station 1 for the last few weeks now repairing equipment, training people how to use the trucks, (Military 2 1/2 ton) in the mean time fixing station 1 and repairing my trucks and on top of it trying to get my equipment picked out again (radio, turn outs, etc.)
Good you did find then just follow the diagnostics the best you can and see if there is a wiring issues...Might also check that alternator voltage (AC and DC).
Issue with engine missing at 1500-1700 RPM?!?! Need help!
Here is how to install and calibrate the stock APPS sensor. http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/26-engine-systems/35-apps-sensor-replacement-procedure Here is how to install and calibrate the Timbo APPS sensor. http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/26-engine-systems/39-timbos-apps-installing Thing is typically APPS sensor won't create a misfire. But VP44, injectors, or low fuel pressure most likely would.
Fishing
That's impressive! Nice Salmon... Now are you going to smoke it?
For stock its about right it might vary depending on elevation and grades. If the Superchips is programming properly it shouldn't throw any codes no matter how high the boost gets. 35 PSI is as far as you want to go with a HX35 turbo. No. Because the tip of the sender will hang up the piston in the cylinder behind the test port. Best to be in the trans line or pan if you can. I wish I can find the article about that over on www.Idahoturbodiesels.com
tires
Exactly... The 16's tires are really common out here. But as for the 17's they are not as common and most of the little shops out here don't stock them. Like Right now if I blew a tire I could drive to Riggins, ID (15 miles) and pickup a new 235/85 R16 tire I know they stock it. But as for 17's most likely I would have to place a order for it. Brakes... I got 185K from my OE brake pads. Why would I need to upgrade to 17" wheels and 3rd gen brakes? Exhaust brakes are wonderful tools!
Loss of Power
I think he meant the elbow off the turbo that comes down and turns towards the intercooler. (Educated guess)
