Error code just showed up
That will do absolutely nothing but wipe out the APPS calibration. It will not reset codes, reboot computers, or fixed problems. http-~~-//www.youtube.com/watch?v=fn7J8FQ8x5w
Torque Converter Lock / Unlock Issues
I know there is a supplier for diode and can be replaced but which vendor I'm not sure... What I'm finding out now is some Digital Volt Meter are just plain poor for measuring AC voltage and tend to wonder all over the map. Like I've got $130 Fluke 75 Digital Volt Meter which is over 25 years old. But the accuracy is top notch. Where a cheap hardware store DVM might produce some poor readings.
mpgs
What I'm finding out it takes a special kind of person to drive with performance mods and get good MPG's from it. The best learning tool is the ScanGauge II that will aid you in tuning as well as how to drive the vehicle getting the most from MPG's.
AC/ Defrost controls
Correct... It vacuum controlled so if the vacuum line is damaged the the vents will not operate properly.
lift pump ?
Be aware of the double stacking lift pumps. I had a local Dodge Cummins with the exact same setup. What happen is the first pump (rear) was pushing so hard that it shoved the regulator BB out of the second pump (front stock) and started chewing up the sliding vanes till it wedge the BB between the vane and pump housing and stop pumping pressure fell to ZERO and the truck died. What I found out is Carter / Federal Mogul pumps are not design to have any inlet pressure only vacuum so watch you pressure gauge closely. I ended up doing a service call on this truck because neither the owner or the shop it was at knew enough about Cummins fuel systems to figure out why it died. But this is what I learned about double stack lift pumps (Carters) and the damages it could or can do.I ended up replacing the front lift pump and remove all the rear add on lift pump and the truck ran fine. I also warned the owner to get gauges but still hasn't.
So if the fuel pressure is low enough and the command for timing change is given and the timing doesn't change POP! P0216 code is there. Typically because the fuel pressure dropped to low and there wasn't enough pressure to push the timing cam.
Got my gauges in and swapped on the HX35 couple questions
This is what you don't want to happen... So be careful of where you put it.
Hello from Indiana
No problem... If I can haul around 8K pound travel trailer and get 13-14 MPG I'm sure you not going to have much for issues either.
1997 Dodge Cummins - Full color wiring diagrams
95 or 96 should work for you...
Sorry I don't... But there is always ISX (The Living Cummins 12V Manual!) If you find one I'll add it to the site instantly...
Not cleaning the air filter caused turbo failure!!!
There are some people on the planet that should never own a vehicle. Like a hitch cover on a friends truck says... "You can't fix stupid!"
Ride of the month contest
Right on... Maybe you'll get it.
Another one from California
Yea... I would put a test gauge on it and see where your at. Is it the gauge/isolator or the pump?
Michael.............How Close????
That's terrible. Well I'm back to creeping along with miles being I'm doing 99% of my travels on the ATV.
aux power
For gasoline engine not diesel. :rolleyes:ECM controls the Fuel pump relay for the VP44.
Welcome to the family... Well make yourself at home and ask plenty of questions and start plenty of threads!
aux power
No you can't all the fuses under the hood are live 24/7 so there is no way to shut it off... That why I told you about the fuses in the cab that are key switch active.
The TP is Smaller.............But is My Arse Getting Bigger???
Done...
PM sent...
Issue with engine missing at 1500-1700 RPM?!?! Need help!
You might consider pulling the injectors and pop testing them.
Confusion sets in...
Bands adjusted properly? Valve body issues? Pressure issues? :shrug:I know my stock 46RE in my 1996 Dodge Ram 1500 has never had any debris in the pan since I've owned it! (112K to 149K from 2002)Auto trans are not my cup of tea...
I noticed the same thing to. I know this filter is not going to filter properly either because the core roll is larger and the seal ring isn't cutting the roll like in the past and the roll being narrower is allowing it to slide in the can vertical. So now I know this fall I'll contact Debbie in Nampa, ID and find out if she has update filter part for me. www.wefilterit.com
Here is a corrected link. But your going to need to get past limited member... Let me know I'll get you hooked. http://forum.mopar1973man.com/downloads.php?do=file&id=220
Hello from Indiana
Late to the party as usual... :banghead:Hmmm... Strange as it is MoparMom is tone deaf the upper freq's she has a hard time hearing like the phone ringers (digital).But its great to have another tech to the family.
aux power
Fuse 9, 11, 17, or 19...
