tire size and mpgs
The difference is SGII will have a USB function soon to hook to a laptop for data logging. Also SGII has programmable gauges so you can program in like rail pressure gauge, trans temp, etc... Check it out... http://www.pureenergysystems.com/store/ScanGauge/USB.htm
ALERT! Severe Weather
Interesting... Its very simular to SAR (Search And Rescue) packs... I'm geared a bit differently but typically the ATV got most of my stuff... Then both the trucks are rigged up with basic for road travel. But with sotrms like these you should be getting you property tied down and secured the best you can and consider leaving for safety. Like Flagmanruss I'm concerned about up there in Rhode Island... Rogan over there Virgina... There are many more but all you guys, gals, family be careful and be smart... MoparMom said she would say prayers for all you out there!
Just be careful out there... This is not to be taking lightly... :nono:I'll just keep saying prayers here...
Everyone on the east coast please pay attention to your weather!
tire size and mpgs
Thank you for confirming this...
Possible VP
Actually had already been warned by the ECM of the 2 issues... APPS code and the VP44 code... So actually it right on score.
HELP!! No BUS and gauges quit working
Here is what I got on CCD networks... http://articles.mopar1973man.com/general-cummins/34-engine-system/81-ccd-data-bus
ScanGauge and boost pressure
Reason being is that the 98.5 to 02 Dodges tend to use a offset voltage for boost reading so it skews the SG or UG reading. JLandry is right you should consider a actual gauge for boost, fuel and pyrometer. Now on the CR engines the SG shows correct boost and rail pressure values...
code 1693?
How about this... http://forum.mopar1973man.com/downloads.php?do=file&id=221
tire size and mpgs
From what I heard when you return the smarty back to stock you loose the speed calibration. But this is here-say...
Injectors
Maybe I shouldn't talk... :rolleyes:CajFlynn gave me his old RV275 with over 450K miles on them had them pop tested in Lewiston, ID and they passed. The misfire issue I had was cause from dirt/debris in the pintle area. So far haven't had any problems... :shrug:Make me wonder If I'm borrowed time...
Click on the links above and they will take you to the diagnostic pages of each one or... Or go here and type the P codes in the title filter box and it will show each error and diagnostic... http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/59-obdii-error-codes
delphi fuel pump
You might be waiting awhile on information on Delphi lift pumps... Most people are running FASS, AirDog or Raptor fuel systems. But just maybe someone here might have some information...
Can not find A/C leak
Assumed... Because I UV check all the stuff under the hood and couldn't find any dye so I assumed the evaporator failed twice. Because after replacing it it ran great for over 9 months then failed again... :banghead:
tire size and mpgs
Calibrate your speed on the ScanGauge II by using a GPS and have both display speed. Then go into the menu on ScanGauge II under setup and display speed. Then change the speed to match the GPS. Now you have a accuracte speedometer/odometer on the ScanGauge II... But this will not fix the stock cluster... Sorry...
Low power CTD issue - KyCTD
P0237 code... http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/59-obdii-error-codes/167-p0237-map-sensor-voltage-too-low You might want to run through the diagnostics on that page... That could be the source of your limp mode and lack of power. When the ECM can't see the boost pressure it goes to limp mode to protect itself from damage...
New Travel Trailer
Might be a good time to start a new thread on how you did your propane mod...
Mechanical FP Gauge - Air in line?
I've got black polyon line and can't see if there is air in the line or not. Did effect my reading at all...
2 Stroke and the Common Rail
The smell of burning oil might be just the vapors given off by certain engine oils. Like Rotella (Ro-Smella) has a very heavy oil smell almost like a tar smell when the engine is ruinning and vapors are blown off.As for the 2 cycle oil you could try it for the fuel system system and keeping it lubed up. But the 2cycle oil has nothing to do with the oil smell your getting most likely...
New Travel Trailer
I want to see more of the propane setup... Mom and I are taking about more outdoor cooking and portable propane stoves that allow you to cook outdoors instead of inside where it gets rather warm on a hot summers day.
Your error code definitions are off slightly... So here is the links to diagnose it... It looks more like a CCD Network problem that a failed ECM / PCM at the moment...
old to new cab replacement
The cabs might match up mount wise but I doubt the wiring and other stuff will... I would at least stay in the same range of body. 1998.5 to 2002 will all interchange...
Possible VP
Got you covered... http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/26-engine-systems/39-timbos-apps-installing
WIX Oil Filter?
I agree I would stick with Fleetguards, baldwin, donaldson, Luber Finer, etc... AH64ID has a table floating around on specs...
fuel pressure help!
Here you go... Skip the snubber install the needle valve... As for wandering if its a electric sender then you might have to replace the sender due to being damage already. Mechanical gauges you know when youe set right because the gauge no longer is buzzing.
