  1. Russ is right about the pre-wired connector mine is also. The socket should be near the E-brake pedal. But being trailer brakes are electrical double check everything power wise and that the controller has power and its sending power to the trailer.
  2. Sorry to say you need the $25 a quart stuff from the dealer. Castrol Syn-Torque... Part stores don't normally carry it.Now as for using something else there is conversy about if it effects the syncro's in the transmission. When in doubt use the proper fluid...
  3. Might try over in the Download area getting the Dodge FSM and seeing if there is anything listed... Since you don't have you signature post I'm not sure what year...
  4. Simple thing first you could try is a seal kit for about $10 buck and replace all the seals in the system.
  5. I'm in the same boat... I've now replaced the evaporator twice, the high side pipe (orfice tube), and Condensor. The only thing leave to replace is the rubber hoses and the compressor...I'm also still chasing a A/C leak too... :banghead:
  6. Skip Ebay and go directly to the source... www.scangauge.com At least then you got a full warranty and support when you need it.
  7. I did that too... I need a few more can and crawl under it and shoot some more difficult spots and treat some spots and control the rust from starting. :rolleyes:Thing is I've been hanging around a bunch of RV forums... Boy some guys can really spend some money on toys and such. I'm hoping to hear from you and some your ideas that are simple and down home.
  8. I went down to the local hardware store and bought a 6 foot length of clear vinyl tubing for the 96 Dodge and replace all the plastic tubing with vinyl tubing... Worked good so far no problems with sucking flat either.
  9. I need to give mine a some kylon tune up to the frame... It might be a neat idea to freshen the rim paint. :smart:I'm curious of your reports on your new TT. Any flaws, battery life? Propane? Etc... Then hear about mods that you might do... I need some ideas...
  10. Might kick it up to 5x5 and check again... Even with super cold temp of +6*F starting temp and a high of 33*F fo the day I still pulled 21.6 MPG on my last trip down to Donnelly, ID with the Cummins...Tire size... For every 4 pound of tire your get rid of mean 1 less HP required to push the truck down the road.Tread pattern... Aggressive tread pattern will create up to 20% more drag than a standard street tire.Brakes / Bearing dragging... Are you brakes working properly? Do you have bad wheel bearings?Weight / Cargo... Are you carrying excessive aomunt of junk on the truck that could be left at home or thrown out?Speed... Are you traveling faster than 55 MPH? If you are just going from 55 to 65 MPH will double your wind drag... Then from 65 to 75 MPH your wind drag doubles again (or 4x as much as 55 MPH). Slow Down!Brake usage... Are you following to close slowing down and then accelerating again? Everytime you use your brakes you convert your motion into heat on the rotors then acclerate create more load on the engine to catch up again. Using Cetane boosters or fuel additives... Don't! Cetane booster don't increase MPG actually the reverse it takes away from the MPG because the higher the cetane the lower the BTU's. 2 Cycle oil is a natural cetane REDUCER. ScanGauge II... You might try one. Once you calibrate the SGII you find it a good tool to learn how to get the most MPG's from your truck.More?
  11. Just looking at your pic you trailer is very simular to mine body wise. But I know the interior is way different since my kitchen is in the rear of the trailer.I got to admit the trailer looks good dragging behind the Cummins... :thumb1:More pictures...
  12. Come on now... We need to see pictures of it hitched up ot the Dodge at least...:piwwp:Congrads on the the new trailer... You'll love the extra room. For me to upgrade from a 20' dodge Jamboree Motorhome to a 30' Jayco trust me the extra few feet really do add up. As for camping season... It started snowing again...
  13. Now you can upload your own files and pictures to the site and then they are always here for you to use over and over...
  14. Well basically that brake controller senses the brake pedal and then after that sense the amount of G force and calculates how much braking force (or voltage) to apply to the trailer brakes. With the manual slide pulled over is ther power on the brakes? Is the fuse blown for the controller?
  15. Hex most of use moved away from isolators because the in-accurracy that they produce. Not to mention the scare they will give you when the anti-freeze disappears over time. (Low Fuel Pressure) then you got to remove the isolator test the system to relize the fuel pressure is fine but the isolator had lost its anti-freeze or failed. So the needle valve concept stared years ago with direct plumbing. Diesel fuel is not like gasoline where a simple spark are you have fire. So many people direct plumb there gauge in. Like myself I've been direct plumbed for 8 years now. As for the OP question... Even if air is left in the line the air will slowly disappear... You'll notice nice smooth gauge needle sweeps with a bit of air but as the air disappears the gauge needle will get really snappy and you'll be able to hear the water hammer if you open the needle valve to far.
  16. Here you go...[ATTACH]3648[/ATTACH] E92049.pdf
  17. Next post just scroll down when you hit the reply button there is more below the box...
  18. Well gang Idaho is heading back up again... :spend:These pictures were taken as of Feb. 28, 2012Both of these fuel stations are in McCall, ID...
  19. Are you actually cranking the engine or just bumping the starter? You must crank the engine for the injection pump to actually pump. Bumping the starter doesn't do any good...
  20. mnelson@mopar1973man.com I'll post it for you... But all you got to do is post it like attachment picture... Go down to Manage Attachments Button and then upload just like a normal picture...
  21. Here is a quick vid of it...
  22. Normal... http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/29-tsb-technical-service-bulletins/45-tsb-09-02-00-heavy-oil-or-fuel-like-odor
  23. Huh... Odd... Mine chipped the one side lost low position... Replace the resistor and been working fine... Don't ask I don't know...
  24. You might go back t othe guys again that did the work. Maybe the change the truck to work the fork lift and now doesn't work the travel trailer...
  25. Not a problem that's what we are here for... To help each other out!
