Surging
Typically yes...So just for the sake of knowning... What's your fuel pressure and what error codes do you have?
Never seen a burnout like this
OMG! The crazy crap people can dream up to do with there Dodge vehicles...Talk about roasting the tires of the rim...
Fresh Batteries
Sure thing... Not a problem... :thumbup2:As a matter of fact Outlook scheduler is constantly nagging me to charge batteries here on the property...
valve adjustment
Normal...Watch the start of the this video...
valve adjustment
Are you by chance getting problems with trans dragging or something dragging on the engine causing the governor to keep fueling heavy?The only time I see black smoke is 3 cylinder high idle, exhaust brake on, and the grid heater hitting then the governor throttles up and blows black smoke.
Fresh Batteries
Pretty simple really...Coat the batteries terminals with engine oil and leave wet. Once or twice a month I put a battery charger on them and let them charge for over 24 hours. The reason why is that you look at all the short trips you do through out the day. You'll fire up and drive 3-5 minutes shut down. Yes, the volt meter shows 14 volts but is the amperage down to near zero? Who knows... But the simple fact is batteries can be bulked up in a hurry but the final charge require hours to complete. So hence most batteries fail quickly.Keep the electrolyte up. I check my batteries every month and top off with distilled water and then drop the charger on them. It does no good to top of the batteries with water and leave them sit. The water and acid need to be stirred into the batteries. At this point to do it right you would disconnect the batteries and place a charger on for 15.0-15.5 volts and charge till the amps where low. This will make the battery boil and become gassy but the boiling action stirs the distilled water into the acid. Like even on my RV I've got a boost mode that kicks the charger to 14.6V and it automatically drops of time but the batteries get a little gassy allowing the distilled water to sir back into the batteries.If you batteries are ever ran low. (<12 Volts standing) then you need to immediately place them on a charger. Don't just drive till 14 Volts are shown. Once again the fact remains batteries will bulk up to 13-14 Volt quickly but as for getting the final charge will take HOURS!!!
Fresh Batteries
Well I finally gone in done it... I yanked out the factory batteries and replaced them with a set of WalMart Batteries. I was shocked I to find that the Group 27 batteries where only $89 bucks a piece and they are 850 CCA batteries. I was smart and brought my tools along and changed them right in the parking lots and wheeled the tired stock batteries in the store and collected my $18 bucks worth of core charge. I got to admit the charging voltage is a bit lower and the starter seems to spin much easier. But after getting nearly 10 years from the stock batteries it was time to retire them.
fuel pressure too high
Leave it to Katoom to bring out the inaccuracy angle. I do agree with you about that that why I'm push up wards to 19 @ idle and 17 @ WOT (Warm fuel) so when cold mornings come I'm dropped down to 17 @ idle and 15 @ WOT (< +32*F). Like yesterday I made a run down to Ontario, OR as I was travel through New Meadows, ID the the cold temp you can watch the fuel pressure sick just little. But in any case my pressure fall is the same 1-2 PSI empty and 2-3 PSI loaded with the trailer. So now assuming there is a +/- 1 PSI of slop in the system (overflow valve or the gauge) I still rather happy with the setup because worse case would put me at a low of 14 and a high of 20 PSI. But The Good Lord only knows how accurate my setup really is. But going back to the OP post of reaching well above 20 PSI at idle to make 19 PSI at WOT I still think is un-needed. So if the dash gauge and a test gauge are close to right and you well above 14 PSI but below 20 PSI you going to be fine. Pulling a quote from Blue Chip... So raising fuel pressure above 14 PSI isn't going to change HP/TQ at all but it will increase the cooling ability. But once again about if a little is good then a lot more is better doesn't always work. But here again if you going to improve cooling ability you would have to create a 1/2" or 3/8" return line kit to improve return flow to the tank. Because at any rate your going to be fighting the same old 6mm ID lines back to the tank which has a flow reduced flow rate than your 1/2" big line kits.
But the pressure inside the VP44 is only going to be 14 PSI because everything else is return to the tank. So there is no since in even trying...Just as long as the fuel pressure is above 14 PSI your golden..
fuel leaks at cylinder head
Ahh... I had the same issues but got crazier... I got out the 1,200 grit and a pencil and tuned the connector tube to fit the lines. I had 3 line that when in bad shape and cleaned them up really well and carefully. A small scratch or pit in the connector tube or the high pressure line could cause what you taking about. I got to admit it takes a lot of patience with the 1,200 grit but you turn out a very smooth and tight seal fitting. Like I said take your time and do it right.As for the cause of the funk is from wahing the engine and letting it sit to air dry. If you wash the engine and drive it dry you less likely to have that issue. I had to learn this myself...
There was a guy that converted over to 12V cam and 12V lift pump and had 35-38 PSI going to the VP44. Needless to say he got ran off another forum for it. So as for knowing if it work or not I say it was running but as for long term damage I'll never know...Still I will not suggest crossing the 20 PSI mark there is no need for it...
Dead Truck
Yes you injectors have to be re-popped because of the lower pressure of the p-pump. As for the p-pump where the gear is place on the pump shaft that is the timing its get all the way across the RPM span... As you see the pump shaft is nothing more that a camshaft. Now on the VE pump and VP44 pump they have a adjustable cam ring that move forward and backward in time to allow for timing changes. The VP44 is fully electronically controlled from ECM sensors and feedback and the old 12V had a single sensor for controlling the advancement cam and the rest was mechanical. But the P-pump its static fixed. So if the initial timing is 13* BTDC thats the timing for all the RPM span... VP44... Vp44 has a very dynamic timing table that is adjusted through engine coolant temp, Intake temp, boost pressure, throttle, and engine load. Yes I know the VP44 stock table is rather weak for MPG's why most people plug in a chip of some sort and get instant timing upgrade.
Don't need to actually remove the injectors but you'll need to wiggle the parts a bit so when you tighten again it will actually seal up. Dave from over at RamForum.com was the once that got me on the phone with the injecotr company and I listen to there conversation about leaking fuel lines. As I posted above was his suggestion and it seen to fix his problem as far as I know.
ECM Issue?
If it was me I would back out of the Quadzilla addons for testing purposes and see if the problems go away...
Ok... When you installed the injectors did you tighten the connector tube first or the injector cap first? I found out that you should tighten the connector tube before the injector cap this always the injector to move into alignment to help seal the lines. So if it was me I would consider doing that it might help...
Omgili.com
Oh you have no idea of the search I've back tracked and found that Mopar1973Man is on the first page or at the top of the list... Even worse to find 2-3 link in a row on the first page of google... I've been studying the Google webmaster page closely to get the most out of the site and its working we are getting much more impressions that we ever have. Just in the last day we went from 250,000 impressions to 300,000 and gaining 40-50%...More we post the better the odds... But there is another trick I found that works excellent. The fact we all use acronyms for most of the post to save on typing. But when we do searches for anything we all was spell it out. So if we spell out the parts completely like instead of "VP44" you type in "Bosch VP44 injection pump" so now if some searches for a Injection pump, VP44 pump, Bosch Pump, Bosch VP44, etc... There all now valid searches and the more times the words are use the better chances of getting to the top of the list even above big sites! We done it more than once already! So enjoy the new search engine... And thank you for the help in making it grow!
not a good way to end the day
You setup should be like... Return line is going to remain a banjo bolt fitting... But the supply line will up grade to rubber...
Omgili.com
Here is a weird find... I was digging around the site logs and looking at different spider that are crawling the site and found this strange little forum search engine that might prove to be useful... Take a peek and give it a test run... www.omgili.com
Hello from Houston, new member
Kind of a seal unit thing... Problem is getting the glass out without breaking it... Here is a thread I started a while back looking for mirriors... http://forum.mopar1973man.com/threads/4767-WTB-Fold-Out-Towing-Mirrors-(Heated-amp-Electric-Adjustable)
ECM Issue?
Not knowing you year of truck but I'm going to drop a link to the wire map... http://articles.mopar1973man.com/index.php?option=com_content&view=article&id=87:dodge-ram-turbo-cummins-24-valve-engine-wiring&catid=26&Itemid=107 PCM (Powertrain Control Module) is what controls the A/C, Voltage regulator, transmission,etc... ECM (Engine Control module) is what controls the engine and VP44. As for using someone elses ECM or PCM remember they are VIN locked so don't expect it to work properly either. It is a protection system added to the device to keep unauthorized software/hardware from being use accidentially causing engine or truck damage. Sounds like a wiring problem...
steering wheel nut size
I got smart early on and got a steering wheel cover for my truck. So my steering wheel is like factory fresh yet... I think the fact the 96 was already wore out on the top of the wheel got me thinking about protecting the wheel early on.
ECM Issue?
Dripley is right...
My first gasser
How about adding some pictures of this beast to the thread... I'm curious of what its... Maybe its time to update your vehicle articles...
intermittent miss on 3 different trucks
Like myself I've got a stock fuel heater with my AirDog 150 as well hooked up and even then it takes several miles like 50-60 miles to warm up that full tank of fuel from near 0*F temps. You got to remember the fuel leaving the engine and VP44 might be warm but by the time it flows back to the fuel tank through the steel return line it will be much cooler.But fuel temperature problem would be visable on the fuel pressure gauge with a serious drop lower than typical like me I lose about 3 PSI from typical with temps as low as 0*F. I don't use any fuel anti-gel either.I'm thinking its a fuel system related problem for sure but what I'm not exactly sure yet...
As far as the return line I would still call Eric at Vulcan Performance and talk to him about the issue and he might just come up with a custom kit to meet your requirements of the rotten fuel lines... Eric a good guy to know when it comes to plumbing on the Dodge Cummins trucks!
