Biodiesel
Salt is a bad thing for any metals... :nono:At this point your running me thin on information so now at this point I'm going to have to step back in the crowd and take a seat and learn with you. So please post your finding...
how much can you haul in the bed?
Like in my post I'm a long bed quad cab... Rear axle rated for 6084# GAWR with overload springs. My empty weight is roughly 2,800-2,900# on the rear axle which its giving me 3184# of weight capacity for the rear axle roughly.
Turbo compressor residue
Personally I wouldn't want any of that going down in the air system towards the intercooler. Sad but it would be best to remove the turbo and wash it with a mild solvent. This means removing the compressor housing and cleaning it too. Removing the piping and clean it and possibly look in the intercooler.It might feel gritty but baby powder is really fine a smooth material but dust even that fine can ruin a set of rings.
DVD-RW just died...
What you never seen a power user before? Like I said there is roughly 2.0 TB (2,000 GB) worth of storage in the network here... 3 computers... I'd shoot a picture of the office area but my camera is a bit frosty from being out in the garage all night. :banghead:
Anyone heard of...
Runs on the auto ignition temperature laws... Just like a diesel just different fuel and different compression ratio... http://en.wikipedia.org/wiki/Autoignition_temperature
Anyone heard of...
I would love to have one in my search and rescue pack for those times I might get stuck in the back country and needing a camp fire for the night.
DVD-RW just died...
I've got plenty of horsepower under the case but the hard drives and the DVD-RW are dying one at a time. I lost my backup drive back at Jan, 1 2012. So I ponied the backup over on my 1.5 TB drive to keep rolling. So now the DVD-RW died and cutting DVD backups isn't working no more...This is just the 2 computers... (Mom's is network into mine as well) the shop computer is not on during this time... so there is another 3 hard drives missing...
Biodiesel
The biggest problems is the filtering of the final fuel and drying the fuel after washing. Most people end up with way too much water in the fuel or still got glycerin in the fuel. So if you filter it well before using and allow it to separate out the water then you should be good.
2 cycle oil
Yeah it would but my whole idea is to find someone willing to test with a DPF and prove its not going to plug up early or...
Your plastic and garbage!
Good point you could burn the fuel in say a oil heater...
DEF and Reburner
Beautiful trucks! :cool:On ford truck the DEF (Urea) fill is right next to the fuel tank. One guy mess up and put the urea in the fuel tank and ruined a engine. :rolleyes:As for the whole diesel emmision standar thing... But I would look into to it if it can be done... Or like some other fire dept have done is use smaller injectors.
Anyone heard of...
All listed right there on wikipedia... Fire pistons have a compression ratio of about 25 to 1. The piston of the firepiston is made deliberately narrow so that the force on the piston is not too great to make it impossible for unaided human strength to compress the air in the cylinder to its fullest extent. Rapid compression of a gas (known as adiabatic compression) increases its pressure and its temperature at the same time. If this compression is done too slowly the heat will dissipate to the surroundings as the gas returns to equilibrium with them. The compression of the air when the piston is quickly rammed into the cylinder causes the interior temperature to rise sharply to 260°C (500°F).
NEW Guy help please
No... Thread sealants will cause all kind of problems with electric gauges. Take it back apart and clean all the fitting assemble dry. Notice there is none on mine...
DVD-RW just died...
Well gang my PC is getting it beating tonight. I been burning backups and such and started noticing that the DVD are like a near un-burnt state in the middle ring of the disk like the lazer is getting weak and just not burning the disk strong any longer. So now next time I'm headed to Boise, ID I'm going to stop by my old computer part dealer and see about getting a new DVD-RW drive to replace this one... Well I got to admit I got 5 years from it before it final got flakey about burning...
2 cycle oil
Correct... That is how the ratio system works... So you could change it up and use liters too... But that might just mess you up realy bad... There is no such thing as a dumb question here and no your not going to get flamed just because you don't know... Well you might get slobbered on but that all...
When do you buy a new starter ?
:punish:Well get with it... I know you crippled up with your injuries but there is nothing stopping you from ordering the parts... Good ol' LarryB has them...
I say its time to give up the AMSOil filter... I'm not a fan of any washable filter just not with that kind of risk for such a expensive engine... Now since the turbo looks like than I would look at the rest of the plumbing like the tubes and intercooler to be sure there isn't a bunch of oil and girt being drawn into the engine. 10 years later and 195K miles...
How turbo function (Basics)
Basically turn the vane to it closes off the exhaust. Which it won't be able to seal it off completely but block it partially...
Interesting...
2 cycle oil
Common rail you do 200:1 ratio... On 12V and 24V you do 128:1 ratio... So 128 ozs of fuel : 1 oz of oil... Or 200 ozs of fuel : 1 oz of oil...
intermittent miss on 3 different trucks
56K ohm is for 3 cylinder high idle. 39K ohm is for 6 cylinder high idle.
Bosch certified rebuilders vp44
Just to agree with Jacob there...
I desided to sticky the thread and would like to thank Diesel Auto Power for the information... I would love to get a more detailed listing if there are more shops with the Vp44 test bench.
Basically it comes do to makeing phone calls and verifying if the VP44 shop has a VP44 injection pump test bench in shop or do they have to ship it else where to have the final bench work done. It just a matter of a phone call.Lots of injection pump shop out there but only a small handful actual have the test bench... So if people were to report back who has and who hasn't got a bench we can weed out the middle man and get right to the "Main Man"...
White smoke under acceleration until warm
Go get a code reader... 2001 are known not to show all codes because of a software issue... 1998.5 and 1999 don't work at all... 2000 some report both error codes and some only report PCM. 2001 are known to only report PCM only. 2002 will report both PCM and ECM using the key trick.
