just purchased airdog2 i cut factory fitting
Little information about my install... When I got my AirDog 150 I need it like yesterday so I did the pump install and figured I would do the draw straw later after the trip I had to do. I found out very quickly on that trip that the AirDog 150 was choking to death on the stock pickup tube. It physically could flow the amount of fuel that the AirDog 150 could pull through it. So after I got back home from my trip which I barely kept 12 PSI for a low end number. But I dropped the fuel tank and install the old school draw straw that was included in my kit. Every since then I've never had another pressure issue related to the plumbing. Now a few times I've had problems with the regulator spring and check ball but rare. As long as I use my head and drive like a normal human I been able to draw down to 1/8 or lower with a drawstraw. Yes I see sometime the pressure gauge flops down because of sloshing air bubbles but since I've 2 cycle oil in the fuel I'm not worried about 2-5 seconds without fuel pressure. 150K on the VP44 injection pump and still going strong!
Tranny overheat issue
I think you got a typo... 275*F would for sure set the Trans Temp light. The factory service manual states the trans temp light will come on after 265*F... So since the fluid has been scorched I would get that changed out a few times...
Finally... The first real snow storm of the year...
Close... As for GPS elvation in the yard I'm 2,800 ft.... I'm only a 3/4 mile from Pinehurst.
Hello by AsTroSS from Europe
You got me curious... So I googled it... http://maps.google.com/maps?q=Estonia,+Europe&hl=en&ll=58.562523,24.741211&spn=18.136562,56.90918&sll=59.410849,25.224609&sspn=0.549291,1.778412&oq=Estonia+e+&vpsrc=6&hnear=Estonia&t=h&z=5
P7100 Teaser Pics
Right on... Thank you for your time and effort in done these pictures...
Why coolant flushing or changes are a must...
I guess Wild & Free forgot I'm in the middle of nowhere Idaho with a well and creek...
Actually I don't blame the tap water at all but the pH level change which comes with extended coolant changes. Like the little red Dodge wound up with because of lack of use and low amount of miles it used. It was well over the time limit but I don't think it was over the mile limit.This is minor damage to the thermostat neck... Next one is the Cummins... But I already know it good because it done yearly with about 25K to 30K miles on it. I'll document the Cummins when I change it too. We'll compare the pics from the last few...
Need to buy a OBII scanner tonight
Understandable... Money is tight these days...
It now just about all gone...
Here you go gang... I got done with the manifold gasket job on the 1996 Dodge Ram 1500 a while back and knew I needed to change coolant. The coolant was like 4 years old being I only drove the truck like 3-4K a year. So why change coolant when the truck just sits. Well here is my thermostat housing... As you'll see the housing is starting to rot away from the pH imbalance of the coolant and it attacking the metals.So needless to say I got the cooling system on the 1996 Dodge 1500 flushed out and fresh coolant and tap water back in the radiator. Call me crazy but it works fine...
41te transmission
Not a good sign... I would do like your saying to do and flush it out and get the fluid and filter changed out. But I'm going to assume the metalics is a aluminum...
looking in indiana
Hang in there I know there is a few people somewhere from Indiana...
Bad miss while cruising
Ok... Even at that length of time the error should of self erased by 3 years... The PCM and ECM will self erase codes after 40 warm up cycles of the engine. So I figure in a month or two the old codes should been long gone if the truck was driven everyday. So now that you dumped the codes now take a ride for 5-10 miles and check the codes again.
Mopar Man's Got me convinced..... I need an aftermarket lift pump
Pretty simple...AirDog / Raptor or FASS... Those are the lifetime pumps...
VP44 is shot... P0251 - VP44 Pump Fuel Valve Feedback Circuit - Death Code http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/59-obdii-error-codes/169-p0251-vp44-pump-fuel-valve-feedback-circuit P0237 - Map Sensor Low http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/59-obdii-error-codes/167-p0237-map-sensor-voltage-too-low P0217 - Engine Overheat http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/59-obdii-error-codes/162-p0217-engine-overheat-condition P1691 - VP44 calibration error - Death Code http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/59-obdii-error-codes/230-p1691-vp44-controller-calibration-error Sorry...
Welcome to the family... As for adding pictures. Make sure you got Adobe Flash up to date on your browser. Then scroll down and click on Manage Attachments button. It will open up your file manager for the site. In the upper right corner is a Add Files button seleect the files from your computer and upload them. Then when the upload is done then you can hit Insert Inline button or leave...
Trackbar solutions
Installed a no name (made in Canada) track bar already had 1 warranty claim on it but oh well... :rolleyes:Still going on this one...
That should help for the engine side of things... Yellow/White is the positive Black/White is ground
Ok... I'm going to ask for a bit more information...Fuel Pressure? Do you have a fuel pressure gauge? What is you fuel pressure at idle and at highway speed WOT?Do you you have any error codes?Check in on this and let us know...
Here is a few threads on UltraGauge... (Watch there are some just because of signatures) https://www.google.com/search?q=ultragauge&sitesearch=forum.mopar1973man.com
DEAD Batteries
Actually the modern charging system is exactly the same as back then except there is a few changes. The alternator puts out much more amperage and the voltage regulator is part of the PCM now with a battery temp sensor to prevent batteries from getting gassy.But if you want to convert back to old school just got to unhook the PCM and hook up a old school regulator on the firewall to the alternator.But the reason why the amp meter was removed is because of the extreme high amperage the alternators now produce. Back in the day it was like 45-60 Amps was standard now we are up to 120 Amps and more.
Fan Clutch
That's why the truck is idling and the rubber hose is used. The hose is not going to hurt the blades but its enough to stop the fan from turning so you can check and see if the fan clutch is actually unlocking. If the fan is stuck locked it will not slow down and you'll know its time. I've found 1 fan clutch on a 92 Dodge this way and it was lock solid.
DEAD Batteries
Crack sensor / Cam sensor? Not seeing RPM to tell the PCM to flip on the ground for the field.
For a extra $10 bucks... www.scangauge.com ScanGauge II has a USB cord upgrade coming... http://www.pureenergysystems.com/store/ScanGauge/USB.htm But I would lean towards this one because its does live data from the computer. http://www.autozone.com/autozone/accessories/Actron-OBD-II-Autoscanner-plus-tool-for-1996-and-newer-vehicles-bilingual/_/N-25iq?itemIdentifier=897608&_requestid=39561
Intermittent miss at idle, stumble on accelerate
Codes and fuel pressure is a good starting place to double check the fuel system condition. But as for the miss at idle seem like dirty injectors possibly. http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/25-fuel-system/62-injector-cleaning
