Water Pressure
I've heard the same thing that sometimes the cummins water pump has been known to blow freeze plugs out...As for what causes it, why or how... I'm not sure...
Finally... The first real snow storm of the year...
Can I move in? Update...
Going for a full build!
I'm still holding to my guns... That it sounds like a ground problem...Take notice both HVAC controls and Instrument cluster are on the same ground...
Bad accident...
Let put it this way I've gotten pretty squirrelly with just the truck in 2WD and using the exhaust brake on snow packed roads... Most people stay away from me after that...Also I rarely run 4WD on snow... I've never run chains yet...
Here is the plan for the morning... I got to dig my way down to the other house to get my ATV out to ride over next door to barrow the neighbors ATV and plow his yard then then mine... Daylight is here but the the visablity is moderate to low right now maybe 1 mile. Last night the power flickers and tripped all the yard floods on so I had to dig my way down to the guest house and shut off the breaker in the panel last night. That' sucks when you in flip flops and shorts at 10pm at night...:duh:Not to mention I got to careful push the snow off the RV too...I'll see about getting out the video camera later...
Bio Diesel Fuel 2010 Ram 3500
Well both Cummins and Dodge don't suggest anything above 20% because of the water problem with Bio. I remember seeing a document about if your to use fuels above this you needed to upgrade you fuel seperator to handle it better. In any case I would upgrade the fuel filter to a 2-3 micron. Common rails don't like dirty fuel at all...
2 cycle oil
When the did the testing of each product is was mix as specified by the instruction for each product. Since 2 cycle oil was a home brew they pick 200:1 to be a safe number.
Is a hx40 big enough for 80 to 100 hp injectors????
Good question... Because if you think about it I'm running my Edge Comp on 5x5 (120 HP) and running RV275 Injectors (40 HP) and all I got is 3" straight pipe exhaust, BHAF, and HX35 (stock) turbo. I will admit 100 HP injectors will flow a lot of fuel so it all based on what you plan on doing...
Good Morning all... I've got to do some digging... 8:10am 01/18/2012Front Porch...Front PorchLooking toward the RV..Toward the guest houseBack DeckBack Deck.Still coming down...
DVD-RW just died...
I shouldn't complain I bought this last Phillips back in 2007 and it finally died in 2012... I think what keep them from dying fast is I burn at the slowest speed possible. Very, very rare to fail a disc. Yeah I was surfing tigerdirect last night and was droolin' all over the keyboard then Mopar Mom spoke up and said since we are snowed in you might as well get that stuff order and get the computer fixed... (More about the snow in my other thread)
Bad accident...
Man your cruel...
Hot Run Issue?
Couple of things come to mind air leak in the low pressure side of the fuel system and fuel is draining back to the tank.Fuel pressure problems just because you got a AirDog doesn't mean the upper end fuel pressure is still good I've seen plenty of videos watch pressure go from 19 at idle to 0 at WOT.I would go back and do the basic test with error codes nad testing both idle and WOT pressures. Yeah you might end up building test gauge.
2001 QCSB or 1999 QCLB DRW
I'm curious if you actually done it yet...
It's here... Wow! There is about 1 foot of snow and it still falling... :stuned:Pics taken at 9:32pm 01/17/2012
DVD-RW just died...
Since I still hold a account with my computer part vendor down in Boise, ID for computer parts and I still got my Tax ID number why not I can buy it at wholesale and just pay the taxes later... So that what I'm up to tommorow I got to order a new hard drive to replace my blown back up drive which is currently ponied up on my storage drive. Also order the DVD-RW so I can burn backup... Here is a snoop of the vendor I've got... http://www.computercentral.com/store/ I'll take a look at TigerDirect... --- Update to the previous post... Well I might actual go with TigerDirect prices seem much lower than shopping with my old vendor...
Bad accident...
:lmao2:I'm just like you now ISX... I just kick back and cruise with the cruise control set. The only time I get a bit concerned is when I can no longer see the hood of the car behind me then he gets a warning (blink of the backup lights) still there you get a cloud from the exhaust. By then most have giving up and backed off or gotten pissed and hauled on around. But its funny now hitch up my 31' Jayco and people are nice, don't tailgate, and are understandable about be traveling slower towing a trailer than traveling slower empty. Goes back to ISX race theory... But back in the days of fire fighting we all knew we were not limited by the speed laws and could exceed them for emergency calls. But after seeing several videos and safety classes about high speed driving and safety it was shocking how many accidents happen envolving emergency vehicles fire, ambulance, and even police. At that point the laws kick in hard and heavy on you. Well knowing this when driving I ask myself if a deer pop out on the road around the corner could I stop or avoid him without causing a accident? Or what happen if I came around the corner and Grandma is pulling out on the highway could I avoid a accident? The key factor comes back every time is speed. If your driving slower you can react to conditions easier because there is more time. So now after researching the speed laws in Idaho there is no minimum speed limit and you allowed to travel as slow as you wish as long as you yield to traffic behind you if there is more than 3 vehicles. Now this is with in reason of weather, road conditions, vehicle condition, etc. But the law does state if your traveling to fast and loose control of your vehicle you will be sited with a heavy fine regardless of you lost control at speeds below speed limit. So going back to the deer thought say he did pop out on the road and the speed limit is 65 MPH and your traveling 55 MPH and you swerve to miss him and end up in the ditch stuck and with vehicle damage. You will be sited for excessive speed for road conditions.Just more to think about...
Bad accident...
Better yet... A pair of 100w bulbs looking back at you. A flip of a switch and they usually back off. I'm more and more becoming a 55 MPH person now. There is no where I can't go and get there in the roughly same amount of time as 65 MPH. So like going to Boise, ID I would leave about 30-45 minutes earlier and get there on time. I never forget get my butt chewed on by another diesel truck owner asking me why I was driving so slow. I just asked him what his MPG was and he replied with 14-16 MPG. All I could do is laugh and reply with 22 MPG and pulled my ScanGauge II out and showed him. He just turned away and shut up.
Smarty Programmer
The only thing you'll get is high idle... The ABS/Speedo will be lost on return to stock (At least what I've been told). Owner [*]Return his/her vehicle to stock. [*]Unplug as usual. You [*]Hook up the smarty and run a program. [*]Take a ride around the block. [*]Hook up again return to stock. Owner [*]Hook up and return to previous programming. VIN lock is only in effect as long as a program is in use in a vehicle. Smarty is unlocked when the vehicle is returned to stock.
Smarty Programmer
Smarty will work... Just have the owner return to stock. Then you can use it on your truck take a ride enjoy some power. Then return to stock... Then he'll be able to use it again on his vehicle again...The VIN lock function is to prevent 1 owner programming a bunch of vehicles with one tuner.
Hard Start
Call around first and see which way you want to test them either going to a Dodge Dealer and having a leak down test done or by pulling and having them bench tested.As for removal there are nearly the same as the 24V but you got 2 wire on top and near to carefully pry them up out of the holes (no bolt hole for pulling like 24v - Sorry!) There is actually a special tool to remove them but I've heard of people carefully prying them up and out...Dumb question? Do you have any error codes? Hows the fuel pressure too?
flash chat
Closing thread and go over to... http://forum.mopar1973man.com/threads/5110-Hiring-Staff-Member-Chatroom-Manager?p=46497#post46497
Milestone
Mighty Whitey is catching up with me... 195K miles as it sits today...
From NOAA... http://forecast.weather.gov/showsigwx.php?warnzone=IDZ011&warncounty=IDC003&firewxzone=IDZ401&local_place1=18+Miles+NNW+Brundage+Mountain+ID&product1=Winter+Storm+Warning I'm all set I've got plenty of food... Generator is all wired in and fueled up... Got internet and the web site to work on... Let it blow...
White smoke under acceleration until warm
Still check for codes with a OBDII reader...
Hard Start
Injectors are most likely failing (really common)... Time to have them tested... What happens is the injectors start to hang open and bleed and loose rail pressure during starting making it difficult. While this is occuring the injector is spraying down the cylinder walls with diesel fuel all the time. Why you alway see CR engines being rebuilt at 200K miles... Like I said have those injectors tested... If only a few are leaking replace them all... Because the others will be right behind them.You not going to be happy with the cost of replacement either...
