Bought some Ether...
Or learn where the solenoid are and pull the signal lead before using...
Be careful where you plan on storing the can... Cab temps can get rather high in the summer (explosive). Have having a can of pepsi (unopened) explode in the cab of my truck I tend to becareful of what goes in the cab...
What are my options...
I got to admit after reading your post I'll admit you got you priorities right. Take care of the injury to hand and your family. Money isn't going to fix your hand nor take care of your family when your hand is injured...I agree with Gassernomore I would contact your company work comp group and talk to them again...
Kudo's to the OEM air filter!
The only thing I would do to double check the stock air box is spray a light coat of WD40 to the upper lid and leave it. The the plastic box starts to deform over time it will start to leak dust around the seal and show up in your WD40 patch on the lid. My stock airbox started to leak dust at a little over 40K miles and I had to resort to greasing the gasket of the air filter to insure good seal.I'm not knocking the stock paper elements which I know they are good but the stock air filter box could be better...
Fuel pressure diff at altitude
Next time I go to heavens gate I'll have to pay attention to this and see if its true. I know its not going to happen this year being the road is already snowed closed. Heaven's Gate is the highest point here in Idaho at 9K...
Looking for lost MPG
I find that driving habits are the worst thing that effect MPG's. How fast are you driving? How much boost and EGT's do you see?Another hidden problem is brake drag that eats away the MPG number little at a time.
1996 Dodge 1500 - Looking for MPG's
Ok... A bit of update to my 96 thread...I've been short trip running the truck mostly back and forth to a friends house a few miles away and into Riggins, ID to pick up propane. But I'm happy to report it runs better but as for MPG's I really can't report much right now because of the weather and short trips its pulled the ScanGauge down to about 13-14 at best. But I know the MPG's can be much better but weather and trip distance is a factor.
Specialty tools
Normal... I'm the same way I've got tools all over the place that I bought for both the 96 Dodge 1500 or the 02 Dodge 2500...
You guys think my fuel pressure low???
Ok here is a video I shot a while back of my fuel pressure... Just no comments about sloshing the fuel tank and sucking a air bubble.
my truck as it stands tody
No red stuff in my tank... (ATF or Offroad diesel) Just the dark royal blue of WalMart SuperTech... Boonies & Dirt roads... I must be a redneck... As for the comments thanks guy... It really does means a lot to me. I keeps me going at the site. Like last night I've bee m working on the CMS Software (Joomla) so you guys can post your own write up from here on out. Getting the software update to the most current version (vBulletin & Joomla). So you guys might not see me as much on the forum but I'm here working my tail off...
Colorado checking in!
Welcome Randy...How about some pictures of this beast of a truck?
What mods for max Economy
No... I see temps as low as -25*F and never had a issue with fan freezing solid to the hub it always unlocks shortly after being started. Let us know how the IAT fooler works out...
Good place to keep it is in the GREEN...
error codes puc 1693 and ecu 0216
One day I'll have to pull my pump and re-install it just for the pics and video of how to do it. I've done 2 pumps now and never shot a single pic or video of me doing it. :banghead:One day I'll remember to do it...
Air filters Pre-Filters
No filter should be blown off with compressed air because over time you will rip the media and create a entry hole for more dust and dirt. I would rather use stock paper element filter and then install a filter minder in every vehicle... http://www.filterminder.com/
mystery wire
Here is a article from RamForum that I did for Dave. http://www.ramforum.com/f69/fuel-psi-10066/ Before... After...
Only reason I happen to say that is I removed the fan completely last winter and ran without a fan at all like ISX has been doing for the last 2 years. So far during my short test period of running without a fan I didn't see any gain or loss of MPG's either. As for the fan running when first started. Yes it will for a few seconds as you accelerate and then it unlocks and remains unlocked. Like in the video above.
Actually I do have a write up... http://mopar.mopar1973man.com/cummins/2ndgen24v/vp44-replace/vp44-replace.htm
How much fuel pressure to high pressure pump? Your input helps
Here is a cheap solution to the problem. Adjustable overflow valve! http://www.torkteknology.com/products/TORK-TEK-CUMMINS-ADJUSTABLE-OVERFLOW-VALVE-OFV010.html
No there is no gain... http-~~-//www.youtube.com/watch?v=QeKndmCy_yk
I disappeared for a few weeks for good reason....
It's worth it trust me... You might have to drive farther to everything but you bills are less being there is less to get wrapped up with. Like here we have no TV at all and no cell service. So the only bills are power, telephone, and internet which the telephone and internet are one in the same. So basically there is 2 bills here.
valve adjustment
Like my last go around I set at .008 and .018... How I check is see if -.001 goes easy and then check to see +.001 doesn't go at all. Then you know you've hit the mark exactly... But being there is a wide range of room I'm not too considered about it..
Welcome to the family and I move the post for ya... Here is the extended definitions... P1693 P0216 Now I'm going to ask you how much fuel pressure you got? Do you even have a fuel pressure gauge?
Thank you Dripley...
Hunting season
I'll send my prayers out to your friend...
