undercoating
How about a few pictures of it???
Newbie North Texas
Welcome to the family of Cummins owners...
Newbie with problems
P0215 http://forum.mopar1973man.com/threads/2561-P0215-Fuel-Injection-Pump-Control-Circuit P0314 (I need to dig deep for...) P1689 http://forum.mopar1973man.com/threads/2628-P1689-No-Communication-Between-ECM-and-Injection-Pump-Module P1690 http://forum.mopar1973man.com/threads/2629-P1690-Fuel-Injection-Pump-CKP-Sensor-Does-Not-Agree-With-ECM-CKP-Sensor I would try working with this information and see where it takes you... I seen more than enough people report back "Opps it was a corroded connector or a broken wire".
Trailer Brake Controllers
I've got a Prodigy P2 brake controller really good controller and works really well...
65,0000 Miles..... a Few Questions.....
According to RockAuto's page its normal for some up and down movement...
You guys think my fuel pressure low???
It starts out at 4,500 PSI and can go as high as 20,000 PSI (or more). As for the weeping it most likely a bad sealing washer...
I did my ball joints myself and my stock ones lasted till 187K miles... http://forum.mopar1973man.com/threads/4147-Ball-Joints-Nightmare!
How to jack a trailer wheel up?
I would raise the stabilizers again just leave the tongue jack down... Because the trailer is trying to lean to one side a bit and the stabilizers are most likely hanging you up... Or hitch up the trailer to the Dodge and drive the front or rear axle up on a block of wood and the other axle should hang free.
Let her breath
Thing that hang me up is all these exhaust mods will more than likely end up removing my exhaust brake to work...
Reverse switch ?
Probe the socket of the switch with a test light and check and see if there is power on one side. Then using a piece of wire and bridge across bothe pins and see if they light up with the key on. This will test to see if the light are good and if there is indeed power ther at the switch..
cmp/cam sensor reads 0 at any rpm truck runs good replace?
If there is no error codes for cam sensor I wouldn't worry much...Does the tach on the dash work?Does the volt meter rise when the truck is running?Most likely working then if yes but your ScanTool isn't capable of seeing Cummins cam sensor...
Woohoo, new parts!!
Done...
Right from the Dodge Factory service Manual... http://articles.mopar1973man.com/index.php?option=com_content&view=article&id=88:bosch-vp44-injection-pump-overflow-valve&catid=25&Itemid=107 And...
Members from the northeast
Russ is always looking for useful hands to help him out...
Code 0122....HELP
Funny how people claim that disconnecting the batteries t oreset the computers. I think what is occuring is the terminals are oxidizing/corroding and the terminal are getting weaker and weaker and them the voltage drop is slight but enough to mess thw the computers. Then you pull the cable ans place them back on the problems gone... Hence the theory of resetting computers fixed it... :rolleyes:As you see there is truely no reset (actually a APPS calibration) you just corrected a poor connection...
2002 ctd not running right
Did you try disabling all the limits and alarms on the Ardenaline? Really common for some to set a limit or a alarm too low and now the box has a hard time producing good power.RBurks has a good point to double check the valve lash... (small chance but every little bit helps!)How about errror codes? Is there something else that might be wrong keeping the truck from performing good?
Reverse switch ?
Lighting to me is very important... Hence why I just replace 4 bulbs on 2 trucks... Out here in Idaho there is no street lights and always a hidden stump, rock, hole, etc to back a truck into that might cause serious damage...
aftermarket exhaust
Nice to know the HP/TQ doesn't change on 3" to 4" pipe... Hmmm... Doesn't give me to much reason to upgrade being the 3" I got now is very controllable for EGT's...
The the winter cold coming on mine is slipping down again. Idle @ 18 and WOT @ 16... I know its the stupid check ball working its way into the spring again...
Reverse switch ?
Yes... The 2 pin switch on the top of the trans shift tower is the reverse switch. I runs back to the tail lights supplying power for all backup lighting and other options... If I remember right Black/Violet wire is the one your chasing...
What size Vent Lid do I order?
I tennd to agree with Russ... Like in my days of the ol' Dodge Jamboree I had. I blown several roof vents. But what made matter worse is the base was plastic to so eventually the whole unit should be replaced. Like my current Jayco has steel baes and plastic lids. So I wouls simply measure one of the other lids and order one to match... Or contact the manufacture of the RV and get the specs of the vents.
You might consider updating to the other spring. (17 PSI)
Pics of me towing things
Nope... Solid frame...
Donations
You slipped in under the radar... I didn't relize you called...:banghead:
New brakes are really noisy
No... There is some that have found lockup controllers to allow for Exhaust Brake usage on automatic but without the lockup controller its basically worthless... CajFlynn has/had a exhaust brake on his 01 Dodge with a Automatic but I think he wore his out. (1.1 Million miles)
