fuel life
Before the injector is a Edge Filter too so imagine pushing though the edge filter and then the injector...
Speaking of Bad Batterys
If the battery voltage was below 12.0 Volts for any kind of extended period most likely the batteries might not charge up properly. So even if you did get them to charge I would load test them to see if they are any good. Also find out how much capacity was lost.
Once a battery was left dead for a extended period they are most likely dead for sure.. Sorry...
Possibly big problems, kinda doubt it, need 24V info from the masters
Interesting idea...
Gotta Say Thank You - Vulcan Performance
Yeap I do... http://articles.mopar1973man.com/images/2ndgen24v/bhaf/BHAF_Template.doc
Just dampen with engine oil and they will never corrode or oxidize which happens to be the black coating you saw on the positive cable.
My Nexted Welding Truck
At least all the 2 1/2 ton military truck I've driven rthe wipers ran on compressed air.
Need to wire my slide in camper
I like the ideas of the guys to just create a extension cable to just plug into the bumper socket and route back for the slide in camper.
Howdy from Charlotte
Gotta Love this group...
Sure sign of failed brushes an/or contacts...
Timing Effects
DPF filter and regen mode...
So there I was...
Your welcome... Sorry I couldn't fix the problem but at least I could provide you a meal and place to hang out till you buddy showed up with your truck... Ma had to kick her to the pile... As for your truck I love to hear what you find for solution...
Codes, codes and more codes. Don't know where to start..
Try looking at manufactures... http://mopar.mopar1973man.com/cummins/manufacture/manufacture.htm Then check out the vendors... http://mopar.mopar1973man.com/cummins/dealers/dealers.htm
Welcome to the site... Grab a beverage and start reading and posting questions... No one here bites...
Check for error codes if you can... Check the batteries condition (load test if you can)... Check main battery cable for voltage drop test... http://mopar.mopar1973man.com/cummins/general/voltage-drop/voltage-drop.htm If it runs check the charging ability (alternator fuse, charging voltage, etc)
Nope...
Geuss I lost my injector pump
Really? That's news to me...
One of these day I might lose my stock batteries in my truck I'm closing in on 10 years of service...
P1688 code http://forum.mopar1973man.com/threads/2627-P1688-Internal-Fuel-Injection-Pump-Controller-Failure P1689 code http://forum.mopar1973man.com/threads/2628-P1689-No-Communication-Between-ECM-and-Injection-Pump-Module
After the Fire
Here you go a peek from USFS Maps for Texas...
After the Fire
Yeah I know what its like to see the emptiness left by a fire and how long it takes for the land to heal itsself.I heart goes out ot all of ya...
Here is a few vendors to look at... http://mopar.mopar1973man.com/cummins/dealers/dealers.htm
mother schooled me
Sounds like we all grew up in the right type of families...
Welcome to the site... Sorry to hear about your problems. :duh:But as for the VP44 as long as VP44 is the same (SO VP44 installing to SO Engine) there should be no problems. It should work. Just make sure to keep the key match with its pump. But if the 01 happens to be a 6 speed then you need a HO VP44 pump.
mother schooled me
:lmao2:I know that so well...
