What's the truth about exhaust and back pressure?
I'm right about 800-900*F on flat ground with 16K# (GCW) running 55-60 MPH in the windy roads of Idaho..
CEL on Cirrus
OBDII code reader...
New Radio
Same here...
Let's say straight piped 3" is doing just fine for me. I can avg 21-22 MPG and haul my travel trailer without any problems with EGT's or anything else. So I've not really seen a really good reason to jump to even 4" yet. If my EGT's are in check nad MPG's are up why mess up a good thing right??
New Radio
Stop by a WalMart and pick up a stereo adapter kit (wiring plugs) and the dash adapter and just wire it in. Took me a little over 1 hour to solder ans shrink tube the wires on the adapter to the radio and then just plug it in. Not hard at all.
Soft brake issue
What's your brake fluid look like? Brake fluid should be a light honey color when in good condition but as it ages it darkens. Brake fluid needs to be changed every 30K miles. Brake fluid is also hydroscopic in other works absorbs moisture from the air so as brake fliud ages it gains water but this is a problem because now the boiling point of brake fluid falls. What's your power steering fluid look like? Same here the power steering fluid should also be a honey color too but it will darken as it ages too. It needs to be changed at 30K miles.Just a few basics. But it does sound like there is either air or contaminated fluid in the system.
How I should I add my Pressure Gauge and beyond
Here you go... http://mopar.mopar1973man.com/cummins/dealers/dealers.htm Then... http://forum.mopar1973man.com/forums/67-Vendors-amp-Dealers
Rodent Combat!!
Is there a way to sandwich some material together? Aluminum or such using a screw, bolts, or pop rivets?
Map light fix?
Wel at least someone found a way to fix it... The thread I read was some trying to repair the switch...
Map light fix?
There was a thread long ago on CF.com about this and the only way to fix it was to replace the entire overhead console. There is no owner replaceable parts up there...
Going for a full build!
Hopefully CajFlynn shows up... He's a pro to what it takes to tow with a Automatic...
fuel life
Before the injector is a Edge Filter too so imagine pushing though the edge filter and then the injector...
Speaking of Bad Batterys
If the battery voltage was below 12.0 Volts for any kind of extended period most likely the batteries might not charge up properly. So even if you did get them to charge I would load test them to see if they are any good. Also find out how much capacity was lost.
Once a battery was left dead for a extended period they are most likely dead for sure.. Sorry...
Possibly big problems, kinda doubt it, need 24V info from the masters
Interesting idea...
Gotta Say Thank You - Vulcan Performance
Yeap I do... http://articles.mopar1973man.com/images/2ndgen24v/bhaf/BHAF_Template.doc
Just dampen with engine oil and they will never corrode or oxidize which happens to be the black coating you saw on the positive cable.
My Nexted Welding Truck
At least all the 2 1/2 ton military truck I've driven rthe wipers ran on compressed air.
Need to wire my slide in camper
I like the ideas of the guys to just create a extension cable to just plug into the bumper socket and route back for the slide in camper.
Howdy from Charlotte
Gotta Love this group...
Sure sign of failed brushes an/or contacts...
Timing Effects
DPF filter and regen mode...
So there I was...
Your welcome... Sorry I couldn't fix the problem but at least I could provide you a meal and place to hang out till you buddy showed up with your truck... Ma had to kick her to the pile... As for your truck I love to hear what you find for solution...
Codes, codes and more codes. Don't know where to start..
Try looking at manufactures... http://mopar.mopar1973man.com/cummins/manufacture/manufacture.htm Then check out the vendors... http://mopar.mopar1973man.com/cummins/dealers/dealers.htm
Welcome to the site... Grab a beverage and start reading and posting questions... No one here bites...
