  1. Well I've been helping a neighbor do a power steering gear box project. This Ford truck is a beauty all original and in really good shape and straight. As for the power steering box it was ruined and so was the pump. The owner changed the pump and the gear box was goofy and sticky. So he got a deal on a used Saginaw box to replace the current Saginaw box... Here is the hitch the box steering back-wards! Ok... So I got creative and decided to open the other box and pull the rack and sector gear and do a switch. Talk about a all day project. Managed to get it all swapped out and ran down to the shop where the was and install it. Got it fire up and wheeled out side to add more fluid knowing it going to burp and pump foam out. System filled up and the wheel start oscillating... :banghead: The power valve inside most likely skipped the pin and causing this issue. So the truck is now in my yard and I get to start all over again... I'll get it yet! :pray:As for the steering setup is all custom fabricated from 02 Dodge steering shaft to 71 Dodge steering box... :wow:Pictures come tomorrow...
  2. Might do a voltage drop test... http://mopar.mopar1973man.com/cummins/general/voltage-drop/voltage-drop.htm This test can be done on any wiring the same way... But to see lower voltage at the pump is a concern...
  3. Might check the center bolts in the axle to be sure there not broke off...
  4. Lower the cetane the more BTU's... Summer Fuel dark green and winter fuel light green... So the more cetanr booster you add the worse the MPG's will be... But the more 2 cycle oil you add the more MPG's will be... But there is a limit of about 100:1 ratio below that the fuel is overload in oil becomes way too smokey and the MPG's start to fall again because the fuel burns too slowly.
  5. One thing nice about manuals I still run my Edge Comp wide open but I get the choice of controlling the gears and how quickly the clutch gets dropped.I'm back to running my fat 265/75 R16 Cooper STT's... :rolleyes:About 2-3" inches of snow here now this morning...
  6. What your fuel pressure from idle to WOT @ highway speed?
  7. Actualy I've seen where the ECM have failed internally from lock rotors in the the lift pump and cause excessive current flow through the ECM which fries it out... So I would bump the starter and check the lift pump connector with a DVM and see if 12 volt is seem if so then the lift pump is dead most likely...
  8. When mine was done the shop in Ontario, OR just pulled the carrier gear out and install from inside the pumpkin.
  9. Can you control cold to hot with a good amount of change?Is the blend door sticking?Is the 2 hoses to the heater core the same temp? Sign the heater core is plugged up.
  10. After making that video of my fan clutch which happens to be a nearly 10 year old fan clutch now and it still works fine for lockup while towing you can still hear it like a turbo prop plane. But after finding out that fan rolls free like that I call BS on the need for electric fan because virtually the fan is not creating any load as long as its unlocked.I ran for nearly a month in the cool of the winter and seen no change in coolant temps nor did I see a change in MPG's because the fan is not loading the engine in anyway...But if a fan is locked up or dragging yeah I can see it causes more noise and reducing MPG's slightly but as for needing to switch to electric fans no... Not required these fan clutches do there job just fine...
  11. I usually aim for about 100*F and pack up and haul tail... But yes the EB does cut warm up time considerable.
  12. MN you got to be careful the biofuel (B2) tends to thicken up more so...
  13. ISX has removed hes for over 2 years now... Winter and summer... As for MPG gains there is none if the fan is functioning properly. He's a bit crazy...
  14. So do you smoke it or what?
  15. Its go where its at...:thumbup2:As for the Honda you did good it seem to pick up a deal like that...
  16. By chance did anyone try adjusting the sector adjustment on the steering box?
  17. It was at near stall speed and the injection pump fired yet as the piston was coming up but didn't quite make it and reversed directions and started running backwards. I just thought of something to be very aware of... Once it does start to run backwards shut it down as quickly as possible. Because now that the engine is running backwards that means the oil pump is now blowing bubbles in the oil pan and sucking the oil away from all the bearings, turbo, and piston cooling nozzles...
  18. Find you a quiet stretch of road where you can let the truck roll to a stop on it own without using the brakes. Gearing down with the transmission is OK just don't use your brakes till it stops. Then get out and check the temp of the rotors/drums by carefully touching them check for extreme temperature. Of course be really careful I've seen even mine being smoking hot... Don't go out and burn yourself.
  19. I have the faint tick noise at high R's when dropping gear with the exhaust brake. Still use it in all gears even with R's as high as 3K on the tach and drop the exhaust brake on it. The tick noise with disappear as the R's fall off below 2K.As for usage you can use the exhaust brake in all gears and all R's of the tach... Even the owner manual says that the best hold back power is near 3K R's...
  20. No... I'm keeping my high MPG fan... Thank you... I guess its time to consider replacing the fan if its chewing the end of a 2x4... My buddies 92 Dodge was locked solid what I can tell that happens is over a period of time the clutch leaks out the oil inside and then seizes up on the shaft. He's fan was solid and you could turn the engine with the fan...
  21. I've seen sensors fail within specs. In other words see a IAT sensor report 110*F when the manifold is actually 50*F so in this case there is no error thrown and the only way to detect such problems is using a live data tool like a ScanGauge II and monitor the sensor for normal operation. But if a IAT , ECT, or MAP sensor does fail out of range it will throw a error code and the ...
