  1. Well I've seen several truck this year lose the lift pump part of the ECM where it randomily trips the lift pump and randomly shuts it down too...
  2. Hey I know you... :thumb1:You more than welcome here... Get a few post behind you and your account will upgrade...
  3. How about just a single bolt pop out of the manifold cover and see the boost go from 30 PSI to 8 PSI.. No it doesn't take much to lose boost pressure.
  4. It might be a good idea to install a prefilter before the walbro to protect it from tank debris.
  5. Might be the evaporator is plugged up with road dust. http://t1.gstatic.com/images?q=tbn:ANd9GcS0dhysP3h9h849z4j-OkNE_XjZBolTW1r0Jy05EOszER6ptWZ3 Its a weakend project to remove the HVAC case... http-~~-//www.youtube.com/watch?v=ghDbhJDBvkc
  6. Make sure to use synthetic air (Nitrogen)
  7. I've never heard of anyone needing one yet? What's happening to your current ones?
  8. I tend to agree with CajFlynn because there is lots and lots of VP44 out there with over 200K... Like my VP44 is just a stock SO pump I've got 140K miles on it and still going... If heat was a issue we all would be dropping like flies...Like next time look at the specs of a laptop... A laptop can be stored in some pretty extreme temps like 158*F without a problem. But the actual operation requires a much lower temperature. Which once again with a good fuel pump the heat will be pull away very quickly. How about the ECM that is hang righ on the block next to 190*F coolant jacket? Hmmm... That doesn't even get a good breeze or cooling fuel...
  9. Mike, I don't have an exhaust gas pyrometer in the manifold, but do have a boost gauge in the passenger compartment. Would your question be partially founded on the concern that my EGTs might already be a little high? It's probable that I'd need to remove the turbo and maybe even the exhaust manifold in order to install the thermocouple ... correct? Oh and you possess a '73 Charger? Now that's a body style that I'd worship righ up there with the likes of Christie Brinkley and Pamala Anderson! As for the EGT's it would be a smart idea because the sole fact your change the amount of fuel and of course as you increase fuel the temps do it. As for install you should be able to do it without removal. http://mopar.mopar1973man.com/personal/2002/gauges/gauges.htm As for the Charger... Yeap it sitting out in the yard with a 383 CID and 727 Trans...
  10. Yeap there right... Your fine... Enjoy life... :thumb1:Give it a bit of time things will settle down maybe so air bubbles trapped... worse case you got a air leak but the pressure looks good.
  11. I would check the error codes but I'm going to guess its the crank sensor back behind the starter.
  12. First off you going to have to pull the whole system out. Here is how to bleed it... http://mopar.mopar1973man.com/cummins/2ndgen24v/clutch-hyd/clutch-hyd.htm Then leave the plastic tabs back on it when you install it. The pin will tear loose when you first apply the clutch.
  13. If I had a spare Cummins I would stick in my 73 Charger...
  14. Lift pump is directly controlled by the ECM. (No relay) The injection pump (VP44) is controlled by the fuel pump relay in the PDC. As for the ASD relay I'm not exactly sure what that controls since it hooked up on the PCM and not the ECM. ASD as far as I can see in all the wiring diagrams has no connection to the ECM and should not effect it. http://mopar.mopar1973man.com/cummins/2ndgen24v/wiring/wiring.htm
  15. AH64ID is right I change those 2 fluid yearly. (Brake and Power Steering)
  16. New lift pump is dead too... Too low in fuel pressure and the engine not even running... You should see about 14-15 PSI on a starter bump with a fresh lift pump.Did you try to reprime the system?
  17. Hmmm... Do you have pyrometer gauge and boost gauge present in the cab? I would be sure to have gauge first thing before even thinking about upgrading fuel system.
  18. As long as your fuel pressure is above 14 PSI you good the fuel flowing passed the electronics will be kept cooled. Remember my Edge Comp is tapped and my Edge Comp is wide open on 5x5... 140K miles and still going...
  19. Truck should run regardless of the APPS sensor it could be completely unhooked and it should still run... The up and down surge is the part that bugs me it could be a fuel pressure problem, sensor or a bad VP44...
  20. Lift pump is dead... http://mopar.mopar1973man.com/cummins/2ndgen24v/lift-pump-diag/lift-pump-diag.htm 10. Measure the amount of fuel in the container after the pump shuts off. If the amount of fuel in the container is GREATER than 1.33 liters (45 fluid ounces) and the fuel is bubble free, then the low-pressure fuel system is OK, the cause of engine performance problem lies elsewhere. No further testing of the low pressure fuel system Is required. If the amount of fuel in the container is LESS than 1.33 liters (45 fluid ounces), proceed to step 11.
  21. You be surprised at how much stuff I got here stored up...:stuned:1.5 TB drive full of goodies...
  22. Here you go gang...
  23. Ummm... It would help to have some make/model/year information... :shrug:From what I can find really quick and guessing at year and model I see that its CCD network feed.
