New Scanner - Got an error code
Wastegate is jammed or rusted closed. As for the error code yes its the same.
Hello and Help with a leak
My thought too..
How to stay in shape
Ummm... Dumb question why is the bike hanging?
CEL on Cirrus
I've got the flash code list let me find it and I'll get back to ya...
Tire Pressure Calculator
Once I get caught up I'll have to take a peek at it... Thank you...
24 valve rough idle and hard to start hot or cold
Well the only way I found was to pressurize the fuel tank and check all the fittings to see if they are wet.
Front Axle vacuum diagram/operation
You'd need a 3 port valve... So when the valve is not energized then the open port when be a vent.
Taking the back roads...
1. Sorry... 2. The camera is attached to the dash with a small squar of velcro. Its the viewfinder rattling against the dash. Next time I'll pull my sock off and lay under it.
Flywheel teeth.
Here is simple idea call your local part house and have one of the parts guys count it for ya...
Help! Return fuel line to the tank is broken at the top of the sending unit.
Ekkkk... I don't know... All I can say is that the stock modules are like gold if you do find one you going to pay for it. I know you don't want a new intank pump either... You might consider talking to Eric at VulcanPerformance.com and ask him if there is a module to be had or a way to modify around the issue...
Return line shouldn't cause problems... It would be a suction lines from the tank to the pump more than likely... Those line rarely ever leak outward but seen to suck air in and drain the prime easy. Then while running they suck more air reducing the fuel pressure.
Taking out the P7100
We all waiting on updates...
wheel bearing 06 dakota
Is it 4WD? Does have U joints or CV joints?
Voltmeter going haywire on my 01
All I can say is hook up another voltmeter and watch. As for all the communication its done over the CCD Network. So 1 bad wire would be completely system failure (NO BUS and no gauges). http://mopar.mopar1973man.com/cummins/general/ccd/ccd.htm
D'Oh!
Mystery chip installed ... ?
Hmmm... Go out and but plenty of beer... Invite your friend over to drink beer. Discuss the fact of dropping your fuel tank. Then tell your friend to do the work while you hold the camera... Wasn't hard at all... I drank beer and held the camera... Seriously... Yes the guys are right get the tank as empty as possible. Then disconnect the fuel line and temp a hose to a 5 gallon fuel can or bucket. Then bump the starter and let the lift pump pump the rest out. Now the tank is empty... Filler neck hose, vent hose, sender wiring, etc... Diconnect this stuff... As for the fuel lines leave alone for now. But unscrew the collar nut and be sure its free. This will allow the sender to come out of the tank. Now drop the tank down by pulling the 2 bands and lowering it slowly. Allow the sender to come out of the tank. Now the sender will be easy to disconnect form the fuel line and you can get your finger in there.
FP sender location - snubber won't fit! Help...
Well I suggested to her to consider the Raptor series pump then also for a just a bit more money there is the FASS 95 which is close to the Raptor in design. Thank you both for the comment they keep me going...
Need help setting up fuel psi gauge
Tell them you want to barrow the computer a sec and then take them here to this thread and show them the pic of the Air Brake line... I've done that more than once to my NAPA guys...
Vacuum Issues
Correct this is the driver side looking up under the dash and the driver side of the HVAC case...
PCM is most likely feeding the intrument cluster bad data... Being that the PCM has a problem with the regulator I'm pretty sure the PCM is the cause.
I don't see anyone around do you?
Yet Another Trip Report
- Need help setting up fuel psi gauge
Ummm... My part store is 52 miles away one direction. So a 2 hour trip just to get it... I'm in the middle of nowhere, Idaho...- My Friends Repair Nightmare
Ford really out did themselves this time... :banghead:- Vacuum Issues
Actually the HVAC vacuum has a black line that runs all the way to the driver side of the trans hump in the cab there is a connector ther you might check. - Need help setting up fuel psi gauge
