strange happenings
Well fuel pressure could be a factor but its unknown because of your broken gauge. MAP sensor could be another that is failed causing some of the issues. Remember a MAP sensor can fail in normal specs and not throw a code. 150*F is rather really cold for these engines your thermostat appears to be stuck open.
Hooking up my guages.....HELP
Just yank out the isolator... I'm directly plumbed to the gauge with Polyon Air Brake Line its about 57 cents a foot from a NAPA store. It rated for well over 150 PSI and will not break you can flex a piece of the line for hours and never break it. Use a needle valve for you damping valve and shut off so if there was a issue just close the valve.
Cirrus, AC & MPGs
Actually a properly running A/C unit should run constantly on a hot day and never cycle. Now cycling on a cool day is normal because the low side pressure is low or the low side temp is getting near freezing which will cause the compressor to cycle out. The whole idea is to get the evaporator near freezing without letting it freeze because as it cools the humid air it would freeze up and quit blowing. So yes in if its a mild day it should cycle in and out but a seriously 100-120*F I expect it to run constantly and never cycle because the evaporator will never reach freezing temps.
I'm Done!!!!!!!!!
Well it might be worth it to do a compression test... http://mopar.mopar1973man.com/cummins/general/compression/compression-test.htm Then have a shop actually pop and flow test the injectors...
Towing in OD or Drive for my 5th wheel
Yeah your right but want I was refering to was in another thread with ISX... But yes you've told me too... Thing is I live in a area where there is very little flat ground its either all uphill or all downhill. I'm battling to squeeze every last ounce of MPG's out of my travels like this is one of my better tanks of fuel in a long time I'm right now at 24.3 MPG I'm trying to beat my 25.3 MPG highmark then go for the big prize and beat ISX's 27 MPG which will be tough... So like going from my house (2,800 ft) to New Meadows, ID (4,000 ft) and McCall, ID (5,200 ft) I've got to climb 35 miles of highway. So if I just the set cruise at 55 MPH in 5th gear I watch my pyrometer float between 800-1000*F the whole way to McCall, ID Same thing from returning from Riggins, ID (1,800 ft) to home (2,800 ft) its a uphill battle with EGT's at about 800-900*F the whole way home. Now as for yesterday I done 2 trips to Riggins, ID (A/C Jobs). On my way down hill I would use 5th gear and set the cruise for 55 MPH EGT's float right about 500*F the whole way giving me roughly 30-32 MPG for that leg of the trip. Then on the way home I leav it in 4th gear and set the cruise at 53 MPH and surprise it dropped the EGT's from 800-900* to 600-650*F and show up home with 23-24 MPG for the return leg. Normally if I left it in 5th coming home it would be more like 19-20 MPG.
bhaf????
Just stick the filter minder in the head of the BHAF and you'll know if its restrictive or not. The filter minder works from water column not mercury column so to pull the filter minder full span takes a very little amount of vacuum no more that sucking 44oz drink straw. Seriously...
Airdog 100
Nice... The only thing I don't like about AirDog/Raptor now is that funky crimp hose and quick connector junk. Sure gives you no option for locating the pump some where different like the old school setup had the old push loc's and roll of hose so you could place it anywhere you whished. Other than that looks good...
Cleaning Turbo Compressor Housing
Hmmm... I know ISX is a turbo nut and can pull one apart blindfolded... As for the oil typically yes it would be all over everything... It sure shows how poor the oil media filter are if that much dirt is getting through. You might consider BHAF they don't need oil and last much longer...
EGT Figures for Reference
Make sense...
Ok... If it looks like there its going to be dirty all the way to the manifold... I would take the time and clean all the plumbing and the intercooler too. This is a common problem with the stock air box as the box ages it start to deform and no long hold a good seal on the filter panels so the dirt starts leaking into the turbo and the rest of the engine. Looking again.. I would say the oil might be from the turbo seal... You don't have a K&N filter do you?
Injector rebuilding
Well the last time I look into replacement injector parts it seemed it was more expensive to get separate parts than it was to buy a set of injectors... But the biggest problem is re-pop testing the injectors... You would need the shims for adjusting the injectors and a pop testing bench. 24v Series... http://mopar.mopar1973man.com/cummins/2ndgen24v/injector-cleaning/injector-cleaning.htm 12v Series... http://mopar.mopar1973man.com/cummins/2ndgen12v/injector-cleaning/injector-cleaning.htm
I had fuel plate installed - not working great today.
ISX got it covered...
High EGTs
Do you have your old stock injectors or can you get ahold of a set of stock injectors? That would be a way to verify this...
Well after playing with ISX idea of keeping 2K RPM towing... Well I got to admit it works if you travel like 50-55 MPH drop down to 1:1 (4th gear - NV4500 or Drive - 47RE) the RPM's shot up and float right at 2K roughly but the pyrometer falls another 300*F and tows with better MPG's. I was truely shocked... I even tried it empty and yes it works on a empty truck climbing grades. But for flat ground you can run the top gear.
Hmmm... Playing with ISX idea... I went into town today and cruised 55 MPH and took my time EGT's hovered about 500-550*F downhill to Riggins, ID. Now once I was done came back home the same road set my cruise for 55 again but instead of 5th gear I grab 4th gear for the grade back up. This put me at about 2,100 RPM's but EGT's hover at 550-600*F for the trip home. But typically same rate of speed in 5th gear would turn out 800-850*F for the climb home.
Cummins going down hill fast at 90 degrees
WTH???
bhaf????
Same here stock hx35...
bhaf????
I didn't see any change really stock air box and BHAF... Just the BHAF breathed better and didn't leak dirt into the system. Didn't mean that but I should of explained better... When the VP44 seem to hit the high point of MPG's is right at about 100*F IAT temps. Below this the MPG's tend to fall and performance curve starts to increase HP. As for increase of EGT's I really don't see a change from using the stock box plumbed to outside air to BHAF. Now of course looking at EGT's between summer and winter it changes outside temp do have a factor of cooling the air in the intercooler even more (hence it design purpose). So the air at the BHAF might be warm but if you not using a winter front in the dead cold of winter then the air in the manifold will be roughly +40* to +50*F over outside. In the summer I see roughly +30* to +40*F on the IAT. So on a 104*F day I see 130*F in the manifold. But on a 0*F day I will see roughly 45*F in the manifold. But the fact remain the mainfolds on the 24V do have a coolant passage in it heating the air again so... The 1/2" pipe plug just forward of the IAT sensor is a coolant passage... So just remember the air inhaled and compressed is heated... Then it cooled by the intercooler and then heated again by the coolant passage in the head... Can't win for losing...
bhaf????
Strange enough warmer air produces better MPG numbers though... http://mopar.mopar1973man.com/cummins/2ndgen24v/mpg-fooler/mpg-fooler.htm Colder air tend to reduce MPG's...
Need advise, small generator
Hmmm... Well its on its way...
bhaf????
Filter minder is not measured in inches of mercury but in inches of water column. I think the filter minder is moved fully at 10 inches of water column. I've never actually measured it but the the amount of vacuum is less that sucking on a frosty milkshake but no more that sucking good sized 44 ounce drink with a long straw. The filter minder is very sensitive...
Valve Lash
Then start a new thread and link to it... I'm interested...
All hitched up and running away...
These where all developed sites... West side of the lake near Tamarack...
Delayed start
Fuel pressure is way to low... Head over here and do some reading... http://mopar.mopar1973man.com/cummins/2ndgen24v/fuel-pressure/fuel-pressure.htm As for the light that is a internal ECM thing. You might try to have a Dodge Dealer re-flash it... Typically with my truck I never even look for te ligt or even wait I just nail te key and go. So I know the WTS light issue is a ECM problem.
High EGTs
I knew AH64ID would come save the day... Thanks!
