Weird Electric issues
I've got a 2006 Dodge ram here with some very strange issues electrically. All stems around the headlights and turn signals and the multi-function switch. If you turn the right turn on it actually does light the right turn signal. Now turn on the left and the right is flashing. Turn on the hazards and only the right is flashing. Now turn on the head light there is zero headlight but markers and fog lamps. Try hi or lo beam it will flash for a brief moment but turn on the wipers and spray the windshield. Can't get hi wipers at all only lo. Now what did I do so far... Changed the multi-function switch - Same issue Pulled my 2006 Dodge TIPM and swapped it - Still the same problem (Testing with my own TIPM module which works) Its like the CANBus is getting the wrong message from the multi-function switch. There is only 5 wires coming and going to the mult-function switch. I did find someone badly made headlight bypass relay. Pull all that and return to the factory wiring and got headlights for a short time only on HI beams only. by the time I pull the column apart twice I lost the heads a second time. The owner has brand new LED headlight bulbs which I've seen but hi and lo beam work. Still might get a quick flash when you pull the stalk back but wiper and spray come on. No I did accidently roll the wiper knob on or push the end of the knob in for spray. Make matter worse I've still got his other 2002 Dodge here waiting for a injection pump to come back from the rebuilder. He's got zero vehicle running now. Any info to help out here would be welcomed.
Good News Everyone!
Interesting then the other half is cannabis has been proven to help destroy prostate cancer as well. Here is what I've captured on this topic. Funny part is go to Canada and other countries and there is way more documentation about cannabis and cancer treatments. Prostate cancer http://www.ncbi.nlm.nih.gov/pubmed/12746841?dopt=Abstract http://www.ncbi.nlm.nih.gov/pmc/articles/PMC3339795/?tool=pubmed http://www.ncbi.nlm.nih.gov/pubmed/22594963 http://www.ncbi.nlm.nih.gov/pubmed/15753356 http://www.ncbi.nlm.nih.gov/pubmed/10570948 http://www.ncbi.nlm.nih.gov/pubmed/19690545
First road trip in my 2nd Gen
Why I won't have those big over sized tires on it any longer than I have to I'm ditching them as quickly as possible. Dropping the leveling kit out and taking the stress off all the front suspension and axle. When I'm done I will have it setup like what my 2002 is now. Tough, long lasting on parts etc. I'll do it twice and the problems wont be there. No steering brace, no upgraded track bar, etc all those problem will just go away... Just like the last 427k miles on my 2002 Dodge... No different.
Not far from the truth... There is a App for the website now but I'm waiting a bit longer for bugs and issues to be fixed before releasing the Mobile App for the site. Then with the Members Map I could post a location marker as I travel for other to find me. Currently if yo look at New Meadows Idaho it show my pin at home sort of. You can hit My Location up top and then tell it to update to the GPS signal on your phone and presto my location is real time. Hence why all these apps were chosen to be here. The same can be done for broke down vehicle grab the page and hit my Location and update I can see exactly where your at. https://mopar1973man.com/membermap/
My first road trip was taking off and heading to Mohave Valley AZ last year just as the riots started. Then coupled with the COVID-19 crud... It was a very poor trip but my first long haul trip in YEARS. Since MoparMom passed away I finally did get out of the Idaho area and see some different country. This year I'm gearing up to travel as well with the new 2006 Dodge Ram 3500 and doing mobile service work like @IBMobile has in his time. Travel is going to be more common for me soon.
Anyone In Tucson AZ? I Need Some Help! ***UPDATE***
Good to hear... Tidbit for the future... P0381 code is for WTS light. If the circuit is broke or the light is bad it will trip a code.
DAP 7x.010 VCO Injectors
Building a tune is easy, but getting a good tune that is efficient is a bit tougher. The bit that takes time is really dialing in on setting for timing and fuel map to get the most out. Still today on Level 2 (No CANBus and No Wiretap) it possible for me to pull just enough power to spin the tires free on smooth pavement. This is where you really dial down and find that you building way more power with CANBus and Wiretap on top. So if Level 2 can slip a tire a little just think when I turn it all the way up and stomp it to the floor?
Pcm voltage issues
- Pilothouse/RAM3500 build
Nice... That should keep the front clip from flexing on you with that extra frame added to the front clip. I keep getting excited to see this thing done. But I know with any grewat artist it takes time to make a masterpiece. @PilotHouse2500you sir are a master at what your doing.- First road trip in my 2nd Gen
Sound like a upgrade is in your future...- Map sensor randomly tripping
Hence why I suggested to do a pin to pin test to absolutely find which line is actually causing the error and fault. Add one more test being between ground and the pins this will verify none of the wires are shorted to ground which is rare but does happen. Both plugs have to be disconnected.- First road trip in my 2nd Gen
Problem. Doesn't create any heat. 6 CYL high idle doesn't generate much more heat. Now when you use 3 CYL mode or even 6 CYL mode and exhaust brake different story now you have loaded the engine and it does warm up much faster. Even my truck is quick to warm up when the EGT's floating 600 to 800*F. Compared to 250 to 300*F which does take forever. If you use @JAG1 broom stick idea now the high idle there but you now cancelled the exhaust brake warm up feature.- Coolant leak at the back of the head
Zep or the HDX product work excellent for wheel stripping off all the brake dust on wheels. On oily or leaking oil mess it work good too just makes it rinse away. With greasy and grimy it might a few passes and some soaking time to get nasty stuff off. Personally I like power washing first it really does save my skin a lot of abuse of scrubbing nightly. Just a few warnings... Do NOT leaving on any aluminum for very long it will blacken aluminum in a short time Do NOT spray on the gear case tag it can erase that plate pretty quickly. Do NOT spray oven cleaner on aluminum as well it will blacken just the same. Another quick and cheap way to clean too.- Map sensor randomly tripping
Me. If I was face with that I would test from pin to pin between the MAP sensor plug and the ECM plug. @dripleyhas dealt with all kinds of mystery problems around the MAP sensor plug and wiring. There is a shared sensor ground for the MAP sensor which is where Dripley found his problem the ground was bad.- DAP 7x.010 VCO Injectors
I'm also running the DAP +150 HP injector (7 x 0.010) @ 320 bar. I'm running a HX35/40 Hybrid Turbo (60/60/12). Using my current tune I'm running its completely smoke free but seriously powerful enough you really have to dial back the power (Level 2 or 3) in the winter just to keep the tires with good traction. Yup typical as injectors wear the pop pressure fails and the sprayed fuel is with bigger droplets and injected too early since its easier to hit 260 to 280 bar vs 310 bar. Yes, the injection events was early and big droplet hence the white smoke in the mornings. This why with the new injectors your back up to a stockish pop pressure and atomizing much better. Just like myself I'm coming to a end even on my injectors I'm half way through the life of my injectors and soon I'll be replacing again. The 320 bar has really enhanced the life span for sure it used to idle at 13% engine load now I'm down to mere 6% engine load warm. Check out all the tunes there you might find another that fits your needs. I'll be uploading more in the spring time too.- Lithium Batteries for the RV, Good or Not so Good?
Still in all the quiet power is always welcome being I've been living off a battery power house for 24 years now. I can say that for sure nothing wrong with good old lead acid batteries. After killing my first set at about 12 to 13 years I learn never ignore the electrolyte level. I ran at least 1 cell on every battery low enough to expose some of the plate material and ruined the batteries in a short order. It really does help to have exact charging voltages and how to properly charge them. What is the max discharge voltage allowed etc. All these values are now programmed into the Inverter and it continues to charge and discharge those batteries daily. Solar wise those are eight 50 watt panels. Eventually I would like to upgrade them to a bigger set of 1,500 watts or more. That would do so much better in the winter time with the short amount of daylight. Still in all even the way I built the system its still a great fall back power source. Back to the batteries... The simple fact I can equalize charge and pull the sulphation back into the plates and change it back to lead is priceless. This is something a AGM battery can't do. Being that both AGM and Lithium batteries are sealed they can never be equalize charged. Being I've got lead acid batteries in the truck I can simple just pull the batteries and hook them up to the solar power bank and equalize them too as part of the solar bank. Hence my long life span on my truck batteries too. My last set I will admit I ran dead several times to 0.00 Volts (Lights left on in the cab) I mean dead so it shorten the last set to about 8 years and quit. I'm now on my 2nd set of Walmart batteries.- Giving the jeep some tlc.
I "had" a 1951 Willys that I use to run around in started having way too much issues with the axles and suspension and gave up and sold it. I was 4.88 gearing as well with 31 inch tires wasn't too bad at 65 MPH I was right near 4k RPM on the Chevy V8 I had under the hood. Then with the Turbo 350 trans behind it.- First road trip in my 2nd Gen
Correct. There is no way to shut it off. It's enabled by the Smarty without a way to disable. This is the way I got my high idle. I barrowed Bob Wagner's Smary and ran a few tunes found out I don't like it at all. In 24 hours sent it back. Still to this day it is enabled.- Lithium Batteries for the RV, Good or Not so Good?
I paid $4,800.00 for eight 6V batteries. These are not the small one each battery is roughly 125 pounds.- Pcm voltage issues
Basically in a nutshell the PCM turns on both green and blue wires when tach signal is sensed. It might be still a defective PCM yet... if the PCM isn't getting this signal then it won't charge.- Pcm voltage issues
Ok. Just checking...- Coolant leak at the back of the head
I typically use the Zep or HDX brand degreasers. Being acid based it works great on wheels and brake dust. Cut thick grease typically in one or two passes of degreaser being sprayed on. Slightly warm engine helps too. Then if you have the means of using warm water in the power washer really helps a bunch. Like at my other shop I've got access to Hotsy. At home I've got washer connection in the shop and make a fake Hotsy with my power washer. Either way the warmth will help peel the remaining grease and oil off.- Coolant leak at the back of the head
Two strongest I've found is "Home Depot Industrial Degreaser" and Common Household Oven Cleaner both are acid based so do leave on aluminum parts it will blacken them. Don't get on your skin it will burn up for sure. I typically use them at 100% strength and my soak time is limited to just at the tops of 1 to 2 minutes or less. Crud... HDX brand is no longer sold but the Zep brand is... Still works just the same. https://www.homedepot.com/p/ZEP-1-Gal-Fast-505-Degreaser-ZU505128/202790160- Coolant leak at the back of the head
Exactly.- Anyone In Tucson AZ? I Need Some Help! ***UPDATE***
I only use a small harbor freight box cutter. Take your time and slowly work the knife through the layers. Take your time and you'll get it opened up so you can get the wires exposed. I've done like a dozen of these mods now about an hour job to do. - Pilothouse/RAM3500 build
